my light is blinking
Old Nov 15, 2007 | 09:50 AM
mo-shy's Avatar
mo-shy
Default my light is blinking
my light is blinking , i changed the battrey twice and still have the problem.
what is the charging system worth? cause i think i need to change it
Old Nov 15, 2007 | 10:07 AM
not08crmanymore's Avatar
not08crmanymore
If you're referring to your check engine light,stop driving it and get it to the dealer immediately.Are you still under warranty??
Old Nov 15, 2007 | 10:24 AM
mo-shy's Avatar
mo-shy
No
Old Nov 15, 2007 | 10:29 AM
mo-shy's Avatar
mo-shy
I noticed this since the car have 1000 km (before 2 yers i have 05)
i went to the dealer told me this is normally cause the blinking was not very clear, NOW
Old Nov 15, 2007 | 11:10 AM
rws.1's Avatar
rws.1
Which light(s) are blinking?
Old Nov 15, 2007 | 11:14 AM
not08crmanymore
I don't know what that means!Anyway,a BLINKING ENGINE LIGHT is serious and needs attention.ALSO,Do not drive the car that way or you may damage the motor.Have it towed to a MECHANIC you trust.If that's the light you're talking about.
Old Nov 15, 2007 | 11:47 AM
mo-shy's Avatar
mo-shy
loool not the ENGINE light,
i mean all the small light in the car (fog light,plate light,all interiro light...etc)
Old Nov 15, 2007 | 12:31 PM
not08crmanymore
OH!! Might be the battery then.
Old Nov 15, 2007 | 01:07 PM
mo-shy's Avatar
mo-shy
when the car come hot i noticed the blinking come very clear.
Old Nov 15, 2007 | 01:52 PM
not08crmanymore
Possibly the ALTERNATOR then.If the battery's keep dying and the lights flicker,that might be it.Also,it could be a loose connection somewhere,bad fuse somewhere......There's a couple of possibilities.
Old Nov 15, 2007 | 01:58 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
Good luck...electrical gremlins can be fun. When did you replace the battery(s)? I'd start by having the alternator tested. What is your voltage gauge doing when the lights flicker?
Old Nov 15, 2007 | 02:06 PM
HAIL THI$'s Avatar
HAIL THI$
I'm gonna go with bad connection or fuse as well.
I'm not sure the Alternator would make the lights blink off and on. It would more than likely make the car run a little off and act like its going to die. Is the car running fine after you have the battery hooked up? If so, I would take it in to the dealership (you will have to pay labor and parts) and have them run a test to find the problem.
FYI- Details are key for help. When asking every ones questions its key to give us all as much INFO as you can.
Old Nov 15, 2007 | 06:38 PM
mo-shy's Avatar
mo-shy
As i said i went to the delaer when the car have 1000 only i told him the problem he did test then told me the car ok!
i went to Electrician he did test he told me he didn`t sure! but may be the ALTERNATOR but the car ok!!
i changed the last battrey before 2 month when the battrey was like new i didn`t noticed this blinking like now!!
now when the car come hot the blinking come very clear it look like this looool
i thinking of changeing the ALTERNATOR but i dunno what they coast and the problem still not sure if the problem from it
ah and my battrey voltage around 13- 12 (with AC AND HID)
what i must check?
Old Nov 16, 2007 | 06:06 PM
mo-shy's Avatar
mo-shy
To my light is blinking
