first time at track with c6
Nov 18, 2007 | 09:23 PM
first time at track with my car 05 m6. stock motor with f1 procharger and borla exhaust.very frustrating with street tires on.no traction until 1/8 mile. here is my time slip.
2.49 60ft
6.07 330ft
8.82 1/8 at 90.59
12.97 1/4 at 120.56
any one know what it should run on drag radials?
and what is a good cam for a procharger?
thanks for any advice.
Nov 19, 2007 | 12:50 PM
With 120mph it should run 11s anyday of the week.
Nov 19, 2007 | 01:28 PM
Drag radials will make a HUGE difference, they really could be enough to get you right into the 11s with no other changes.
Heat 'em up well though.
Nov 19, 2007 | 02:09 PM
Quote:
Originally Posted by
lynnb
Should run low low 11's
Nov 19, 2007 | 03:34 PM
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
MT ET Street Radials 315/35-17" Buy 17"x11" wheels. I got so much traction I dead hooked @ 3500 rpm launch & blew my rear.
Send a PM
Nov 22, 2007 | 05:17 PM
JFTaylor
Send a PM
dynoed car it made 509rwhp with 447ft.lbs of torque.next mod longtubes and cam.
Nov 22, 2007 | 10:15 PM
lynnb
For that power, your 60 ft time should be well under 2.0
You need Drag Radials and a good launch.
Nov 23, 2007 | 12:25 PM
You should be able to cut 1.7 60 fts with sticky tires. Rule of thumb is every tenth in the 60ft is two on the other end. So if you could cut a 1.7 60ft you should technically go 11.30 or so.
Nov 23, 2007 | 12:30 PM
Nov 23, 2007 | 03:13 PM
I ran a 7.63 in the 1/8th on street tires with the procharger. a4 05 convertible.
