He listed this as his differences at each rpm. There could be other varyance accounting for some of the change but I wanted to know what other people experienced.
These are the values measured (and I said values "measured" so please spare me the "it isnt actually lost power from the motor"......I know, Capt. Obvious...the engine is still producing the same HP) that he saw lower at each rpm:
And please dont post about how dyno's read the power and inertia loss, yada yada. I am asking for people's observed lower readings not a lesson on how dyno's work. Please excuse the abruptness, I dont want this thread deteriorating into a 'how a dyno works' thread. Just looking for some comparative data.
Spin, in the past I have seen other tables posted on LS1TECH.COM showing the measured drivetain losses for several different gears (3.73, 3.90, 4.10), using the 3.42 gear as a baseline. I don't remember the actual percentages, just that it was a fairly linear progression.
That's a little higher than what we've observed, but for all practicle purposes, that's fairly comparitive to what we've documented here with our Dynoject 248c in-ground chassis dyno here +/- 1-2.
The one thing we do twice a year that most shops probably don't, is that we go down into the dyno pit and thoroughly clean the accumulation of dirt, dust, grease, grime and rubber that add weight to the roller drums.
We inject synthetic grease into all 4 saddle bearings twice a year also, just to keep the stacked-parasitic drag from accruing over time. Any additional weight or parasitic drag that accumulates over time that would otherwise not have been there as delivered new from Dynojet, would skew any power readings as the machine aged, because the system software has the original weight/drag tagged specifically to each drum roller set sold.
Keeping clean maintainance of this machine by keeping those original weight/drag co-efficients as close to as-delivered-when-new specs is paramount to keeping data results accurate over time.
I asked OCC to do a before / after with the gear install. The result was a 19 HP loss at the 400RWHP level. I don't have the dyno sheet but I remember this well, because I was intially shocked it was this much.
However, this was on freshly installed gears that were not even broken in, so true losses are probably closer to 10-12 or so, but that is just a guess. This was a real before/after however.
Pretty close to what we see. Add that to a high stall convertor and it adds up to quite a bit.
Hope that helps.
Phil
Thanks for the time you put into that and I was shocked to see it was as much as that. Makes me feel very happy with what my L92's did recently even though I hate to admit it.
Anyway, I didnt even think about other variances with the dyno but those wouldnt apply to a baseline and after gearing redyno unless the clean-up was in between.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
I went from 3.42's to 3.91's in my GTO and observed a 12rwhp loss shown on the dyno. This was the same dyno, different days as the gears had to break in.
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I actually recall asking this same question after my CoW 4.10s were installed. I believe you (Spin) estimated an 8-10rwhp loss. Just curious as to where you came up with that number?
Dave at Cartek didnt quote as high a loss but I think he was averaging the loss over a wider rpm band. His answer was a little more tech than I was looking for at the time. Peak readings are where the highest loss is read but the 4k-5k range may only be a few HP.
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
I had my '05 MN6 w/4.10s dyno'd when I got my tune in Gettysburg last month and it pulled 347.95 RWHP and 348.25 RWTQ. I never dyno'd the car before the 4.10s so I don't have anything to compare it against.
Were there any torque changes from your list above? I once did a "FORD" from 3.55 to 4.10s. Same hp, ~25 more ftlb more peak torque though.
Basically, when you have a HP loss, you'll have a torque loss (and vice-versa). HP and torque are mathematically related by the equation HP=T*RPM/5252. To figure the corresponding torque loss for the HP loss at a particular RPM, use the equation T=HP*5252/RPM. From the chart above, the 16 HP loss at 6000 RPM will have a corresponding loss of ~14 LB-FT of torque.
Not really sure how you got a torque increase or how HP stayed the same...stranger things have happened I guess. Maybe there was something wrong with the 3.55 gears/gear setup that was corrected with the 4.10s.
ive read on the forum that there would be a 10hp to lose on the dyno w the additions of 4.10's. However when i brought this up to the dyno shop owner he said the dyno "adjusts" or somthing to that nature and there wouldnt be any significant hp lose...like maybe 2-3hp. Im wondering...id like to compare to hp #'s to someone w/o gears as a benchmark to see if there is substantial difference????
The dyno does adjust for the final gear ratio, but that doesn't mean that it still will not show a loss.
When I dynoed my car, I did one pull in 3rd gear (since that is what gear the car will be in as it goes through the traps), and one in 4th gear. There was about a 10 HP difference, if I remember correctly.
