intake issues.... ?
Old Nov 24, 2007 | 04:41 PM
michelin man's Avatar
michelin man
Default intake issues.... ?
ideas on where i can get a larger coupling? the one i have now has come off 3x in the past couple of months.
Old Nov 24, 2007 | 05:50 PM
NIGHTSTALKER's Avatar
NIGHTSTALKER
You have a PM
Old Nov 24, 2007 | 11:52 PM
journeyc6's Avatar
journeyc6
I sent you a PM, I have 4 inch diameter red silicone hose, what lenght you want?
Old Nov 25, 2007 | 11:11 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
You might want to consider replacing the accordion as it has a tendencyto hunch up . LGM has replacements for $29.00. Then
you will need a longer "RED PIECE" 3"x 3 3/4. EXTREME PSI MAKES THEM
Old Nov 25, 2007 | 02:53 PM
michelin man
i was going to order the new hoses from Extreme but they wanted $7 handling for a $9 part (plus shipping).
Old Nov 25, 2007 | 05:45 PM
timd38's Avatar
timd38
I looked for the part on LGM's website, but could not find it. Could you post a link?
Old Nov 26, 2007 | 05:25 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I bet Vararam will send you one free, they are here on the forum a lot. Mine is quite a bit longer than that. While you're looking check the foam tape sealing the upper and lower together. I think they will send you some more of that too. Mine is a mess but I haven't bothered replacing it, I've got a K&N filter in the upper that seals nicer than the green filter that came with it.
Old Nov 26, 2007 | 09:56 AM
askiles's Avatar
askiles
You need to make sure that the coupler and mating surfaces are free of oil and debris before installing it. Use a good solvent to clean it up. With an oil on there, it will keep sliding off.
-Andy
Old Nov 27, 2007 | 09:08 PM
NIGHTSTALKER
Thats weird...My shipping was free and it was $7 for handling. Here are some pics of how mine turned out. I know my camera sucks, but you get the idea.
Old Nov 28, 2007 | 12:58 AM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
Call me at 866-507-2648 and I should be able to help you - unfortunately I can't help with the shipping charges - UPS gets $10 to send even the smallest package - but let us help you with the coupling and the gaskets!!
Steve
Old Nov 30, 2007 | 07:37 PM
Tarheels1's Avatar
Tarheels1
Default I got my varam in Carlisle for my c6 and the fellow told me it did not come
Steve
I had my Vararam unit installed in Carlisle and the rep. told me it did not come with the smooth couplers. He said all LS2 had to use the bellows (acordian) stock piece back to the throttleplate. He said that the Z06's got the smooth couplers only. Can you help?
Old Nov 30, 2007 | 08:37 PM
VaraRam Industries
Supporting Vendor
C6 units come with a coupler to the MAF. The kit for the Z06 and the LS3 08 come with the billet air meter adaptor the essentially replaces the accordian!
Steve
Old Feb 5, 2008 | 08:32 PM
michelin man
small update.
scored the silicon coupler at a local performance shop that does turbo work.
$10
i had a hard time justifying the shipping charges people were demanding for a part this small.
is the plastic cover that goes over the radiator necessary (the part right under the intake)?
To intake issues.... ?
