LS7 Swap
Old Dec 4, 2007 | 10:09 PM
alites's Avatar
alites
Default LS7 Swap
Hello everyone,I am debating on swapping out my LS2 engine for a LS7.I have a 07 MN6 Coupe and was seeking some advice on what other parts i would need(besides the 427)ECM,Harnesses,etc. Any input would be appreciated Thnak you again
Old Dec 4, 2007 | 10:42 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I'm not sure what is needed but from my breif reading on the subject, it appears a stroked LS2 would be easier and cheaper than an LS7 swap.
Old Dec 4, 2007 | 11:11 PM
TaylorMade's Avatar
TaylorMade
Old Dec 4, 2007 | 11:18 PM
amped1's Avatar
amped1
I swapped out my LS2 for a forged LS7 shortblock. The LS2 was damged when my timing chain broke. I reused my Trickfow 225 and FAST intake. Didn't have to change anything else. If your planning on swapping your stock LS2 for a stock LS7, it's gonna cost you a pretty penny. Don't forget, you'll need to cenvert the LS7 to a wet sump system.
Good luck.
Old Dec 4, 2007 | 11:29 PM
FreeBoost's Avatar
FreeBoost
Check out the Lingenfelter site.
http://www.lingenfelter.com/Merchant...Category_Code=
Old Dec 5, 2007 | 12:05 AM
Maui's Avatar
Maui
St. Jude Donor '08
Why not go with one of these?
MTI 454
Old Dec 5, 2007 | 12:09 AM
ProgGod's Avatar
ProgGod
Swapped out my LS2 for an LS7. LS2 is going in my solstice. You don't need an ECM or the wiring harness. Infact supposably is better to use the LS2 ECM, because more software is available for it..
Car should be starting for the first time tommorow. I went with a WET oil system, however you could easily do dry sump, and cheaply.
Old Dec 5, 2007 | 05:20 PM
k0bun's Avatar
k0bun
Originally Posted by FreeBoost
That's my point. It's an LS2 427. You're definately not getting a LS7 for $6k+.
Old Dec 5, 2007 | 05:33 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
My tuner just did a LS7 swap for a man and his 07 C6, the car acts and runs stock.
Old Dec 5, 2007 | 09:23 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
Do you seriously have an LS2 in your solstice?
Old Dec 5, 2007 | 10:46 PM
FreeBoost's Avatar
FreeBoost
check out
http://www.mallettcars.com/solstice-conversion.htm
follow it all the way to Turbocharged LS7 Package
Old Dec 5, 2007 | 11:16 PM
Maui's Avatar
Maui
St. Jude Donor '08
check out
That looks like fun
Old Dec 6, 2007 | 12:57 PM
gorillavet's Avatar
gorillavet
You would infinitely be better off to have your LS2 bored and sleeved (Darton) and then install all forged parts. It's cheaper, better and will give you much more power than the stock LS7. Good Luck!
Old Dec 6, 2007 | 09:52 PM
FreeBoost's Avatar
FreeBoost
Originally Posted by Maui
That looks like fun
If by fun you mean death on four wheels, ya fun
Old Dec 7, 2007 | 04:12 PM
Spritle's Avatar
Spritle
Or you could put a ProCharger D1 on it for 1/3 of the cost and go faster. Just my humble opinion.
Old Dec 7, 2007 | 06:25 PM
FreeBoost's Avatar
FreeBoost
It might be cheaper and easier to install but it will be it will never be faster. Turbo chargers don't have the parasitic losses that superchargers have. This size of supercharger will require ~50-75 hp to drive. Sized properly modern turbochargers (specifically ball bearing turbos) have virtually no turbo lag so will deliver the same or more boost as superchargers without the parasitic loss. The efficiency of the compressors can only be compared on a case by case basis but since they are both centrifugal compressors the efficiency will be comparable.
Old Dec 8, 2007 | 01:21 AM
rustyguns's Avatar
rustyguns
MTI 454
oh my god! what a fricken engine!
i think i did something on my shorts!
how much does the engine weigh with wet lubrication/oil pan?
To LS7 Swap
Old Dec 8, 2007 | 01:22 AM
rustyguns's Avatar
rustyguns
and a lot Hotter!
Old Dec 8, 2007 | 11:27 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I certainly recommend going with a naturally aspirated Lingenfelter package conversion. Their 403 package will produce more horsepower and torque than a stock Z06 and they do a 427 package as well if you want. You'll have a fully forged LPE built motor with a warranty....far better than using a stock LS7 IMHO.
If you live closer to Texas than Indiana, 21st Century Muscle Cars is an authorized Lingenfelter dealer/installer. From my experience, 21CMC was a pleasure to deal with both professionally and personally. My 403 package has been incredibly reliable and needless to say...the car blasts!
Old Dec 9, 2007 | 12:23 AM
Thrill6's Avatar
Thrill6
No parasitic loss with turbo chargers? Where does the power come from to run the turbo charger? It certain doesn't come out of hot air (no pun intended!)
