M2W problem
Old Dec 8, 2007 | 03:16 PM
08Z51's Avatar
08Z51
Default M2W problem
Anyone else have a problem pulling the fuse to install their Mild 2 Wild exhaust controller? The fuse doesn't want to come out and i am afraid I might break it if i force it. Is there some "trick" to pulling the fuses that I am not aware of?
Old Dec 8, 2007 | 03:34 PM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
theres a fuse puller in the box that you can use to pull the fuse
Old Dec 8, 2007 | 04:05 PM
EuroRod's Avatar
EuroRod
Yup !! Use the fuse puller. That's what GM spent $2m designing it for!
Old Dec 8, 2007 | 04:21 PM
timd38's Avatar
timd38
I see a cost reduction coming!
Old Dec 9, 2007 | 12:17 AM
Thrill6's Avatar
Thrill6
The terminals that the fuses plug into can be pretty tight, and sometimes the plastic fuse pullers can even break off trying to pull them out. If this happens just use a pair of needle nose pliers. You can't break anything (other than the fuse) by pulling on them too hard.
Old Jan 30, 2008 | 12:43 PM
1st time owner's Avatar
1st time owner
I'm waiting for my M2W to be delivered,,is the fuse puller pretty obvious when you open the fuse box,,,also on the C-6 is that a spare fuse thats being replaced? Thanks.
Old Jan 30, 2008 | 02:55 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
This thread might help:
http://forums.corvetteforum.com/show....php?t=1854837
Old Jan 30, 2008 | 08:44 PM
1st time owner
Thanks for the link,,very clear instructions.
Old Jan 30, 2008 | 09:55 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
I have pull my share and if you dont use the puller you can have problems gripping the fuse. You could also use a needle nose. In almost 2 years and over 2000 sold never heard that problem
Old Jan 31, 2008 | 12:26 PM
1st time owner
Received mine in the mail today,, ,,before I install it,,the blue wire is cut and seems to do nothing,,is that normal,,thanks.
Old Jan 31, 2008 | 02:11 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
The blue wire is the antenna
Old Jan 31, 2008 | 02:39 PM
*FAÇADE*'s Avatar
*FAÇADE*
Here's a link that may help:
http://nakidparts.com/sitebuildercon...rfiles/m2w.pdf
Old Jan 31, 2008 | 08:21 PM
1st time owner
Thanks guys,,I was wondering after hearing it was the antenna if it had to be strecthed out and I see by the picture you should.
To M2W problem
