TC/Stability Control codes
Old Jan 7, 2008 | 10:08 PM
tmak26b's Avatar
tmak26b
Default TC/Stability Control codes
Is there anyway to pull it?
Old Jan 7, 2008 | 10:35 PM
willhaveC6's Avatar
willhaveC6
you mean turn off T\C? yes but you need a tuner
Old Jan 14, 2008 | 12:32 AM
tmak26b's Avatar
tmak26b
My ABS/Active Handling/Traction Control message had been popping on every 50 miles. It goes away after I restart the car. Everything seems to work fine, but I would like to see what the heck it is before i take it to the dealer. Can you put a pin in a jumpbox and get the codes
Old Jan 14, 2008 | 11:03 AM
BEZ06's Avatar
BEZ06
Hmmm.....you may be confusing TM (Torque Mgt) with TC (Traction Control).
You can tune out TM.
You can turn off TC (as well as go into Comp Mode, or turn AH completely off) with the button on the console.
Bob
Old Jan 14, 2008 | 11:08 AM
BEZ06's Avatar
BEZ06
If you're getting a DIC message about Active Handling, there is a TSB about a problem with the wiring in the cars with the extending steering column. You can make the repair, or you can take it in to the dealer to get it repaired.
You say "ABS/Active Handling/Traction Control" - are messages relating to all three coming on at different times? What exactly does the message say?
Bob
Old Jan 14, 2008 | 08:54 PM
tmak26b's Avatar
tmak26b
Bob
All three popping out at the same time, it says service active handling, service abs and service traction control. It goes away after restart. Any idea of the TSB? I have an extended warranty, but really dont feel like paying $100 for something simple.
Old Jan 14, 2008 | 09:23 PM
BEZ06's Avatar
BEZ06
I'm not sure, but I think this thread may have the solution to your problem:
http://forums.corvetteforum.com/show....php?t=1720949
Bob
Old Jan 31, 2008 | 10:09 PM
tmak26b's Avatar
tmak26b
The thread is not very clear. There is no way my hand can sneak behind the metal bracket without cutting off half of the hand ahhh..
To TC/Stability Control codes
