Any difference between the '08 shifter?
Old Dec 9, 2007 | 12:01 PM
Miaugi's Avatar
Miaugi
Default Any difference between the '08 shifter?
I am curious is there is any difference (improvement?) between the '08 shifter and earlier C6's? I think I've read where the shift ***** are not interchangeable between the '08 and earlier cars as well?
Old Dec 9, 2007 | 12:52 PM
BlackZ51Vett's Avatar
BlackZ51Vett
Auto or manual ????
Old Dec 9, 2007 | 01:12 PM
ronsc1985's Avatar
ronsc1985
I don't know whether it is the shifter or the transmission but there is a night and day difference between the 06 C6 and my 08 Z06. In the 06 I had to put in RP Syncromax fluid to get the transmission to be even half smooth when changing gears especially when cold. When I picked up the Z06 yesterday the temperature was below 40 and the car shifted smoothly immediately with no warmup. It also seems to be a shorter throw but I could be mistaken as it has been a month since I sold the C6. I sure hope the smooth shifting lasts.
Old Dec 9, 2007 | 05:54 PM
Miaugi's Avatar
Miaugi
Originally Posted by BlackZ51Vett
Auto or manual ????
MN6
Old Dec 9, 2007 | 05:58 PM
Fuego's Avatar
Fuego
yes,they are different.new tranny and new shifter.
Old Dec 9, 2007 | 06:03 PM
NHRA95's Avatar
NHRA95
Yes, new trany and shifter. Pure pleasure to shift.
Old Dec 9, 2007 | 06:14 PM
Miaugi's Avatar
Miaugi
Has anyone tried installing the '08 shifter on a older C6?
Old Dec 9, 2007 | 06:19 PM
jschindler's Avatar
jschindler
I did not notice a big difference going from my 05 to 08. The most noticable difference is that it can be shifted into first while sitting still much easier. But that is a factor of the transmission, not the shifter. My opinion is that the shifter itself is either the same, or very close.
Old Dec 9, 2007 | 10:32 PM
mikesul's Avatar
mikesul
I replaced my '08 stock shifter with a Hurst billet shifter. The throws are much shorter and more positive, but there is a "notchiness" to the shifts. Still, glad I made the change for the shorter shifts.
Old Dec 10, 2007 | 12:03 AM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
According to the GM marketing materials, the shifter is not the source of the improvement, the new T6060 tranny is -- so replacing the shifter won't give you any better shifting feel.
Old Dec 10, 2007 | 07:03 AM
Miaugi's Avatar
Miaugi
Originally Posted by mneblett
According to the GM marketing materials, the shifter is not the source of the improvement, the new T6060 tranny is -- so replacing the shift won't give you any better shifting feel.
Thanks.
Old Dec 10, 2007 | 06:07 PM
Irv's Avatar
Irv
In my test drive of an '08 I noticed no difference in shifting at all compared to my 2006. Well, I did notice one difference - I wished the 2008 had the C5 clutch spring I put in my 2006.
Actually, for the all of the hype I've heard about the T6060 improvements I was expecting a lot more improvement than I felt. The steering, in contrast, felt a LOT better to my hands. Oh, and one more thing, the LS3 is simply killer. What an improvement over the LS2! If that's only 30hp I'll eat my hat.
I just wish they'd fix the damned transmission and linkage.
Old Dec 10, 2007 | 06:18 PM
NHRA95's Avatar
NHRA95
ARE YOU SURE YOU DROVE AN 08????
Unless mine is exceptional, which I don't think so, this new TR6060 trany shifts like butter. No T56 I have ever owned shifted as smooth.
Old Dec 10, 2007 | 06:25 PM
Modshack's Avatar
Modshack
this new TR6060 trany shifts like butter. .
Mine too..
Old Dec 10, 2007 | 06:26 PM
Fuego's Avatar
Fuego
the t6060 shifts a lot better at high rpm. That is where the t56's had the most notchiness to them.
Old Dec 11, 2007 | 09:51 AM
Irv's Avatar
Irv
Yes, I drove an '08. It's pretty difficult to mistake it for an '05-'07, what with the interior changes. Still not up to the ease of our '03 Z06. I had previously noted a lot of variability in shift and clutch feel with the C6 T56s, perhaps that's still true on the T6060.
Old Dec 11, 2007 | 11:42 AM
Hoonose's Avatar
Hoonose
Weird, my '05 shifts the easiest at highest rpms. I used to to tell people it was designed that way.
But I think variances related to quality control and simply luck of the draw.
Old Dec 11, 2007 | 12:21 PM
C6V3tt3's Avatar
C6V3tt3
My 05 z51 shifts great, of course its nochy when could, but when i test drove the 08 z06 it was the same, if not worse. You just have to shift slow at low rpms and not as hard as at redline.
To Any difference between the '08 shifter?
