Ethanol in a Vette
Old Dec 16, 2007 | 04:26 PM
Sandyc01's Avatar
Sandyc01
6th Gear
Default Ethanol in a Vette
The warning LOW FUEL had been on for a while and traffic was heavy when I spotted a Husky Gas station. When I pulled up to the pumps, the whole station was "Green" meaning they had only a mixed ethanol / gas at the pumps. Without much choice, I filled up with 94 octane green gas. I can't find anything in my 05 C6 owners manual mentioning ethanol one way or another, so without wanting to ignite the ethanol vs gas wars, can the LS2 handle it?
Old Dec 16, 2007 | 04:28 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
>10% ethanol is OK
Old Dec 16, 2007 | 04:53 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Originally Posted by C6400hp
>10% ethanol is OK
If your troubled by that gas as soon as your down a few gallons put in some other gas. Then after a couple more gallons do it again. By now you will have got the first gas mixed up perty good.
Old Dec 17, 2007 | 01:03 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Sounds like all that 'Green' may of been 85% ethanol station,
they don't do that for 10%, only small labels on the pumps saying
"contains up to 10% ethanol". where are you from? or where was the station?
Old Dec 17, 2007 | 03:50 AM
vette-oholic's Avatar
vette-oholic
> 10 % translates to "greater than 10%"
did you mean less than 10%?
Old Dec 17, 2007 | 03:59 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
85% Ethanol would have been a HELL of a lot higher Octane than 94.
Corvettes, and any other car sold in this country, will run on any motor fuel that is sold for road use in this country aside from Diesel or Ethanol that is labelled as not for use in gasoline only engines. Your engine doesn't know or care if it has 10% Ethanol.
Old Dec 17, 2007 | 05:51 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
however, power output is not the same.
Old Dec 17, 2007 | 07:36 AM
tscales's Avatar
tscales
St. Jude Donor '07
Why not? It would certainly run cooler with the ethanol.
I filled up at WalMart the other day with 10% ethanol and sure can't feel any difference.
Old Dec 17, 2007 | 09:05 AM
vdavenp802's Avatar
vdavenp802
Mine came with it in the tank from the dealer. I've used it for many many years, with no ill effects on the engine. Performance? Not sure, but I don't notice any. The manual says for agressive dirving use 91 octane. That's where you will find the real difference. Mileage slightly less, but again I don't notice that either. The 85% stuff you will notice these differences.
Old Dec 17, 2007 | 09:15 AM
not08crmanymore's Avatar
not08crmanymore
I questioned this a while ago.Don't make it a habit or the internals of your engine will wear out in a hurry.It's not designed for that much ETHANOL.
Old Dec 17, 2007 | 10:40 AM
scottycards's Avatar
scottycards
St. Jude Donor '08 thru '13
We have no other choice here in Colorado, but to run the 10% ethanol blend in the winter.
It'll bump the octane a bit, your car will run great, and it's fully approved by GM and Chevrolet.
Full details here:
http://www.ncga.com/ethanol/main/your_car.htm
Old Dec 17, 2007 | 12:49 PM
PowerLabs's Avatar
PowerLabs
Yes. It. Is.
Let me repeat what I just said:
EVERY VEHICLE
produced or sold in this country will run on
EVERY FUEL available for it at any gas station in this country. That is the whole principle behind certification. Gas stations aren't randomly experimenting with "miracle brews" that will work on some cars but not on others. 93 octane is 93 octane and will run every single car that is designed to run on 93 octane gasoline.
The only fuels you will EVER find in a gas station that will not run your Corvette, or any other gasoline only car for that matter, are diesel and ethanol. Not ethanol containing gasoline; ethanol. BIG difference.
10% will make zero perceptible difference. Ethanol has a higher octane rating than gasoline and as such it is used as an octane booster. It is also an oxygenated fuel that is used to reduce emissions; there is nothing wrong with using it, virtually all fuel sold in this country contains at least some small amount of it, and I would venture saying that we have all used oxygenated gasoline (I.E. Ethanol containing gas) at some point in time.
Old Dec 17, 2007 | 12:56 PM
Michrider's Avatar
Michrider
You'll lose a little power because Ethanol has only 84,000 BTUs compared to gasoline at 115,000. At only 10% though it will be hardly noticeable. At 85% it will be noticeable, so will the fuel guage going down extremely fast.
The great myth of Ethanol is that it is so "green." It's made from corn, wow, what a great renewable environmentally friendly fuel... Only they neglect to tell you it takes 131,000 BTUs of energy to make one gallon of 84,000 BTU Ethanol. A net energy loss, subsidized by yours truly the tax payer.
Old Dec 17, 2007 | 01:09 PM
rcknusa's Avatar
rcknusa
Not only does it take more energy to make ethanol the amount of fertilizer used to grow the corn is amazing and then the run off into the river, lake and so on. We need to cut this out and just start drilling again and add some more nuclear facilities.
Old Dec 17, 2007 | 01:26 PM
Zig's Avatar
Zig
What is Ethanol?
Ethanol works well in internal combustion engines. In fact, Henry Ford and other early automakers thought ethanol would be the world's primary fuel before gasoline became so readily available. A gallon of ethanol contains one-third less energy than a gallon of gasoline.
Ethanol is a high-octane fuel. Octane helps prevent engine knocking and is extremely important in engines designed to operate at a higher compression ratio, so they generate more power. These engines tend to be found in high-performance vehicles. Because ethanol has high octane, it is sometimes blended with gasoline in small amounts to boost octane rating. This mixture, in turn, can be used in high-performance engines.
Low-level blends of ethanol, such as E10 (10% ethanol, 90% gasoline), generally have a higher octane rating than unleaded gasoline. Low-octane gasoline can be blended with 10% ethanol to attain the standard 87 octane requirement.
http://www.eere.energy.gov/afdc/fuel...l_what_is.html
Ethanol Benefits
Ethanol is a renewable, largely domestic transportation fuel. Whether used in low-level blends, such as E10 (10% ethanol, 90% gasoline), or in E85 (85% ethanol, 15% gasoline), ethanol helps reduce imported oil and greenhouse gas emissions.
E85: An Alternative FuelE85 (85% ethanol, 15% gasoline) is considered an alternative fuel under the Energy Policy Act of 1992. It is used to fuel E85-capable flexible fuel vehicles (FFVs), which are available in a variety of models from U.S. and foreign automakers.
Other than lower gas mileage, motorists will see little difference when using E85 versus gasoline. E85 has about 27% less energy per gallon than gasoline. For more information on ethanol's energy content, see the E85 Fuel Properties section. Use the FFV Cost Calculator to quantify the effect of E85's lower energy content on FFV fuel economy and fuel costs.
http://www.eere.energy.gov/afdc/fuels/ethanol_e85.html
Ethanol has issues with water, it absorbs more and is therefore subject to condensation. unless the tanks are kept full it will suffer from water contamination.
much higher compression (14/15:1) is required to fully recognize the same performance level that is obtained from a comparable amount of gasoline.
ethanol is used to raise to octane level of the gasoline, however, even after the addition of the 10% (or more) i have yet to see higher than 93 octane offered for sale at any of the top-tier stations (recommended fuel).
that leads me to believe that ethanol is being blended with lower grade fuel to achieve the same octane rating that was obtained without the blend.
for example: if 10% ethanol raises the octane rating by 2-3 points, one can use 85 octane with a 10% ethanol blend and get 87 octane. 90 octane with 10% ethanol would become 93 octane. combine that with the lower power output of ethanol (at the same compression level) and you end up with less performance from the same amount of fuel. lower gas mileage (which is a result of less efficiency which in turn is a result of the lower power production).
Old Dec 17, 2007 | 01:47 PM
jimhild's Avatar
jimhild
Yes. It. Is.
EVERY VEHICLE
I thought the car had to be rated for "FlexFuel" if it was acceptable to run the E85 fuel. 85% Ethanol, 15% gas.
I don't think the Corvette is yet a "FlexFuel" automobile.
Better Check, and I will too.
Old Dec 17, 2007 | 01:59 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I didnt even know it was still possible to get gas that didnt contain the 10% ethanol.
They certainly dont have anything other than that in the houston area.
To Ethanol in a Vette
3 Z06ZR1's Avatar
3 Z06ZR1
Don't think it will run on the 85 stuff!
Old Dec 17, 2007 | 06:14 PM
calemasters's Avatar
calemasters
10% ethanol, or less.
I prefer a Top Tier gasoline with 0% ethanol and 91 (R+M)/2 octane, minimum (93 preferred).
The C6 is not an E85 Flex Fuel vehicle, except for this one:
Old Dec 17, 2007 | 07:26 PM
kmthor00's Avatar
kmthor00
I guess if it were me I would have let's say put in a few gallons, not fill er up!
