how do you check a code
Old Dec 17, 2007 | 07:31 PM
Rada 1's Avatar
Rada 1
Default how do you check a code
Driving home tonight and notices the idle when shifting gears was staying high Around 3000rpm and then falling off after a few seconds, about the time I got home the check engine light came on, how can I check the code??I just installed 4.10 gears and had to drop the exhaust when we did it.?
Thanks for any help!
Old Dec 17, 2007 | 07:37 PM
LEAVINU's Avatar
LEAVINU
I bought one of those OBDII handhelds from Adv Auto for $40 bucks and has helped me alot. The one I got also came with a book of the generic P0XXX codes that makes it easy to identify what the codes mean.
Plugging this thing up also allows you to clear the codes.
Old Dec 17, 2007 | 08:26 PM
VET4LES's Avatar
VET4LES
Buy a code reader or take it to Auto Zone and they will loan you one at no charge.
Old Dec 17, 2007 | 09:20 PM
MENWOB's Avatar
MENWOB
Default Autoxray Code Reader
These people make a great code reader.
http://www.autoxray.com/index.php
Old Dec 18, 2007 | 09:57 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Go to AutoZone or buy a code reader. I have a mid-range Innova CAN/OBDII code reader...I can update it via the interweb and it does everything I want.
Old Dec 18, 2007 | 10:09 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I check and clear mine with HP Tuners. Kind of overkill I guess.
Kinda hacks me off that they removed that functionality that existed in the C5's to check the codes via the DIC controls.
To how do you check a code
