High Oil Pressure
Old Dec 19, 2007 | 06:48 PM
nikic6's Avatar
nikic6
Default High Oil Pressure
I changed the oil in my 2006 Corvette today. Used Mobel One 5-30 with Fram PH 3506 filter. When I restarted the engine after the oil change, I got 78 PSI oil pressure at idle. After oil came to temp the pressure is still 66 PSI at idle and 91 psi at 3,000RPM. Before my oil pressure was about 36 PSI at idle. Could the new filter be defective and blocking oil flow? Any other suggestions or answers?
Old Dec 19, 2007 | 07:00 PM
carpe dm's Avatar
carpe dm
Originally Posted by nikic6
.Could the new filter be defective and blocking oil flow? Any other suggestions or answers?
Sounds like a good possibility; stick with AC.
Old Dec 19, 2007 | 07:03 PM
Ben Diss's Avatar
Ben Diss
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
Interesting. I thought oil filters had a high pressure bypass that prevented a blocked filter from blocking flow. Not sure if that's true or not but it does sound like you have a problem.
Old Dec 19, 2007 | 07:41 PM
nikic6's Avatar
nikic6
I just finished changing Fram filter to a AC filter and still have the high oil pressure. Now what?
Old Dec 19, 2007 | 07:46 PM
logansrun's Avatar
logansrun
Blue on Black
my be false reading
Old Dec 19, 2007 | 08:19 PM
SpinMonster's Avatar
SpinMonster
I think that the oil pressure sensor is at fault or beginning to fail. The part is 40 bucks and I have one that I know is good. To eliminate the variable I would install it for you to see. If there was no change then you move on down the list. It would make sense to get another oil change and see if it fixes the problem.
There would be no chanrge if youwere local but no one knows where you are to even offer since it seems that not a single new member ever fills out the bio informatin which is an issue wen you ask for help, recomendations of a tuner or parts place. Why dont you fill out the bio info? You cant buy or sell anything in the parts section either without listing your location.
Old Dec 19, 2007 | 09:54 PM
NYC6's Avatar
NYC6
Word around here is Fram is one of the worst filters sold. There was a test done that I read months ago saying the same thing. That might not be your problem but I would get that thing off your car.
Old Dec 19, 2007 | 10:15 PM
VET4LES's Avatar
VET4LES
In addition I would drive it a few miles and see if it returns to normal. If not take it to the dealer.
Old Dec 19, 2007 | 10:50 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
I would probably change the oil again using Mobil 1 and a fresh AC filter...this is something you can do and fairly cheaply to avoid a dealer visit. I have only seen this happen with cold oil and high engine speed.
Read the owner's manual to be SURE you are using the proper AC filter. After you remove the oil filter, inspect the filter adapter carefully for obstruction, debris, or anything out of the ordinary. Before opening the oil containers, inspect oil for tampering...I've seen some weird stuff done by people.
I suppose it's possible for the oil pressure sensor to be out of calibration, but remain within the extreme normal operating range...in that case, no codes would be set. If the sensor fails completely, you will get a code.
Old Dec 20, 2007 | 12:45 AM
SpinMonster
I just swapped a sensor that was pegged 2 weeks ago and it set no code. As they go they raise the pressure reading and nail the guage.
Old Dec 20, 2007 | 11:24 AM
JmpnJckFlsh
The service manual indicates:
P0521 - DTC is set when ECM does not detect a change in engine oil pressure of at least 5 psi over a predetermined variance of engine speed.
P0522 - DTC is set when ECM detects that the EOP sensor signal circuit is less than 0.4 volts for greater than 10 seconds.
P0523 - DTC is set when ECM detcts that the EOP sensor signal circuit is greater than 4.6 volts for greater than 9 seconds.
If you didn't get a code set, the only explanation is that the EOP was continuing to send a variable signal between 0.4 and 4.6 volts, or the ECM somehow overlooked the condition. To understand how, or if, such a signal would read on the dash gage would require understanding the sensor output calibration, and I haven't done that research yet.
Old Dec 22, 2007 | 07:21 AM
nikic6's Avatar
nikic6
The oil pressure sending unit was bad. The dealer replaced the unit under the warrenty. Problem sovled.
Old Dec 22, 2007 | 08:15 AM
timd38's Avatar
timd38
Glad you got it fixed!
To High Oil Pressure
