C6 1/4 Mile Performance Challenge
Old Nov 15, 2008 | 12:46 AM
  #3381
HOXXOH's Avatar
HOXXOH
Originally Posted by dennis50nj
i would agree with that but my car says tire pressure not recommended or lowest just states tire size and air pressure 30 lbs. i drove 17-18 thousand miles on mine 24lbs rear 26-30 front still look good. and never had a problem with going sideways sliding or excessive tire spin, i drive now with skinnies and drs at 21lbs rear30 lbs front, have been 170 150 160 many times car handled great, i am going by experience, try it lower your backs to 24 hot fronts 30 hot drive around step on it to the floor at different speeds and you decide what pressures are better for all around street driving, the ones i stated and it works great for the 1/4 in the range of the tpms is totally acceptable
I state again that I quoted my '08 manual. I don't think my '08 manual is stuck to the door jamb of your '05 car. or your personal experience trumps the factory manual.
Your personal experience is not inherent in the brain of an 18 year old, but your advice to them should be conservative so they can live long enough to have their own experience.
Old Nov 15, 2008 | 12:52 AM
  #3382
HOXXOH's Avatar
HOXXOH
are you serious, maybe you can take the bet that no one else has, i follow the bolt/on rules 100% my car has been inspected numerous videos, i will let you inspect the car, i will make the pass let you inspect again seal the hood take it to a qualified gm tech, or tuners corvette shop of your choice they can inspect and tear the motor down to see if its the stock heads cam pistons, that the oil pan timing chain cover or valve covers have never been off, the price of tear down and put back together plus 10,000 dollars to the winner, some easy money for you if your so sure im cheating, i am in the top 5%
No need to get defensive. I don't remember anyone challenging you personally, only one person's perspective of how he interprets the list.
BTW, can you post a link to the bolt-on rules. I'm in that catagory now and haven't been able to find anything.
Old Nov 15, 2008 | 01:01 AM
  #3383
LS1LT1's Avatar
LS1LT1
Originally Posted by HOXXOH
I consider myself somewhat experienced and had a NHRA comp license years ago, yet I noticed a significant handling difference on a 1/4 mile track between 25 psi and 30psi. You're probably right that under normal driving conditions the average driver will not notice a difference. However, we're not discussing normal here. These are severe conditions and inexperienced drivers.
Yes, it is dangerous, which is all the more reason to act responsibly when advising the uninitiated.
So basically you're saying that a Corvette C6, a world class handling car with Active Handling, Traction Control and ABS, with the only change to the car being tire pressures in the rear lowered to 24psi is like a loaded gun, a ticking time bomb that is SO dangerous and on the edge out of control that absolute death will ensue if anyone other than John Force dare tries to make a pass in it?
Please.
Old Nov 15, 2008 | 01:02 AM
  #3384
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
You guys are absolutely amazing a year ago we all agreed upon the rules and regulations. The list was a worthless piece of garbage because our members did not have the integrity to do what was right. We made changes to the format and I put up with a lot of stuff to get it to where it is today.
If there is so much discord with regard to our rules, because someone thinks it is a topic of concern or wants to start a debate, then lets go back to the old list. It takes a lot less of my time. I could just record the BS times and garbage as I did when we started.
Old Nov 15, 2008 | 01:07 AM
  #3385
LS1LT1's Avatar
LS1LT1
The Corvette Forum generally follows the parameters set by the premier LSx motor drag racing forum LS1 Tech.
This is a very basic definition of a bolt on LSx car:
Originally Posted by WILWAXU
*Bolt on's ONLY. Naturally aspirated. Stock internals motor, intake to oil pan, stock long block (as it came from GM). LS6/LSx style intake swaps allowed.
Old Nov 15, 2008 | 01:11 AM
  #3386
dennis50nj's Avatar
dennis50nj
in a straight line on the track you couldn't tell what the pressure is. if it was 10lbs you could, if 24lbs was unsafe then why does the low pressure alarm sound at 23 and the high at 42, why not at 30 and 32
Old Nov 15, 2008 | 01:17 AM
  #3387
Tommy D's Avatar
Tommy D
Please.
Sometimes we forget.....last December on a very cold day two guys with basically stock C6's were tasked with warming up the track for the faster guys. The first had a A6 and got a bit of a dance.... the second had a A4 and got a bit sideways.
Both were experienced and kept their cars away from the wall.......
stuff happens.....
Then there was the guy with a Z06..........
Old Nov 15, 2008 | 01:18 AM
  #3388
LS1LT1's Avatar
LS1LT1
Please people, DON'T RUN YOUR CORVETTE'S REAR TIRES AT ANYTHING UNDER 30PSI OR YOU WILL SURELY DIE IMMEDIATELY!
Old Nov 15, 2008 | 01:20 AM
  #3389
dennis50nj's Avatar
dennis50nj
Tommy your doing a great job!! but you know every once and a while someone tries to scam the rules to get a good spot on the list because its so easy to get on and all the bleeding hearts want an easy way up the ladder. the rules for stock are common sense
Old Nov 15, 2008 | 01:23 AM
  #3390
LS1LT1's Avatar
LS1LT1
stuff happens.....
That's true, I remember those two days very well LOL.
But tire pressure had little or nothing to do with those incidents, cold weather and a moist track played the main roles there. If anything the lower rear pressures actually helped...higher pressures (I was at 26 or 27psi) could've resulted in even less traction and a potentially greater loss of control, at least in my car's situation.
Old Nov 15, 2008 | 01:26 AM
  #3391
Tommy D's Avatar
Tommy D
I guess we have to get another crash test dummy to take a 08/09 C6 with npp to ATCO or Englishtown on a very cold night and tell them to run 30 PSI with everything off......or better yet after the track has been oiled down when one of the ricers blows a rear.......
Come on guys we all know why we lower the tire pressure in the rears and why we raise the front tire pressure (then there are those who REALLY raise the front tire pressure ).
Once again we are beating something to death that we all know the answer ....... I guess we all have nothing better to do
Old Nov 15, 2008 | 01:28 AM
  #3392
Tommy D's Avatar
Tommy D
My point exactly.... but if we had been at 30 PSI ...... we would not have made it look so easy
BTW I had 25 lbs in the rears
Old Nov 15, 2008 | 02:04 AM
  #3393
Z51 6spd's Avatar
Z51 6spd
the line is drawn, stock is stock no ifs ands or buts. off course the stock LS3 should beat the stock LS2 it has more hp. they shouldn't be on the same list. it beats so many Z06s maybe it should be on the Z06 list as far as me with my little LS2 im still waiting, im not just #1 at cf but also ls1 tech, i guess there list means nothing either
Bro, it doesn't take a rocket scientist to figure out that an LS3 corvette with your exact mods will outrun your car.
Just Saying I want to say that I love your car. It's an example of what a bolt on vette can do, but still has room for improvement. With that said, if it didn't 60ft like it does. It really wouldn't be that impressive, because it really doesn't make that much power.
Stock is stock, I get it. But a switch to open the NPP before 3500 rpm is crazyness. That's like saying a Midget can't race my stock car because he weighs 75 pounds, and that's not enough weight in the car.I mean the guy listed the switch in his mod list, can I ask were else is he supposed to list it? I moddified my corvette when i fist got it with some wax. It cut through the air a lot better than any other corvette. Aerodynamics were on my side in the 1/4 mile.
Old Nov 15, 2008 | 02:09 AM
  #3394
LS1LT1's Avatar
LS1LT1
Just Saying
Oh, like this one?:
http://forums.corvetteforum.com/c6-t...-1-4-mile.html
Old Nov 15, 2008 | 02:21 AM
  #3395
LS1LT1's Avatar
LS1LT1
Well, umm, yeah...if John Force didn't 1/8th mile so well his ET might not be all that impressive either.
What kind of logic/statement is that?!
Either Dennis's car is fast or it isn't.
You do know that the car trapped in excess of 124mph+ right?
Only a handful of C6s on ANY of the lists are actually matching exceeding that number.
Old Nov 15, 2008 | 02:23 AM
  #3396
HOXXOH's Avatar
HOXXOH
While I may choose to take risks with my own life, based on my experiences, I choose to dispense conservative advice to the inexperienced in an effort to expose them to lesser risks.
You may choose otherwise.
BTW, how come you east coast guys aren't in the sack yet?
Old Nov 15, 2008 | 02:27 AM
  #3397
LS1LT1's Avatar
LS1LT1
As a true bone stock car he shouldn't have to list it anywhere, it shouldn't even be there.
Cars are often washed/waxed as part of the dealer prep process...does the dealership often pull fuses out during that process as well?
To C6 1/4 Mile Performance Challenge
Old Nov 15, 2008 | 02:28 AM
  #3398
HOXXOH's Avatar
HOXXOH
I already looked there to no avail. I'm looking for specifics, not generally or basically.
Got a link?
Old Nov 15, 2008 | 02:32 AM
  #3399
LS1LT1's Avatar
LS1LT1
While I may choose to take risks with my own life, based on my experiences, I choose to dispense conservative advise to the inexperienced in an effort to expose them to lesser risks.
That's fair enough. Nothing wrong with being a little extra cautious when giving racing/speed advise to an inexperienced driver, especially one with a potent machine like these car tend to be.
Never, I don't log off until at least 3 or 4am.
Old Nov 15, 2008 | 02:38 AM
  #3400
HOXXOH's Avatar
HOXXOH
Gotta go. Wife's offering and I'm not gonna pass it up. You're on your own.
