C6 1/4 Mile Performance Challenge
stock pulley
stock thermostat
stock TB home ported
Z06 injectors
3.42 c5 diff
yank 4000
l92 heads l76 intake both unported
custom grind cam
CAI
lt headers hi flo cats z06 mufflers
hoosier 275 DR
DA was 2230 temp was 75 degrees
track prep was great dead hooked
I think at the very least it will go 10.83 or 84 in better weather
Orp indianapolis
8-10-11
1.496 - 60'
4.437 - 330'
6.946 - 660'
97.74 - 660’ mph
9.114 - 1000'
10.947- 1320'
123.00- 1320’ mph
What range is that cam? Did you have to cut the pistons?
What lightening mods have you done? What's the car weigh with driver/
BTW my skinnies and taking the seat out was worth .2 and 2 mph.....you should be securing some before winter...
p.s. tell Mike Norris I said hi. He's a great guy. Indy got one heck of a tuner/wrench/gentleman when he moved back.
123 for 2000 DA is fine. I run that in that weather. I'm a manual of course so normally run a little faster than an auto but I'm stock heads. Well I was....
Looks like we might have some competition on this board after a long time.....
whew...close.
The FAST was worth .3 and 3 mph for me. Your gains will be less as the ls3 intake is better than the ls2.
For my money, I'd buy skinnies first and see how you do. A lot less money for an almost guaranteed .1-.2 gain. Also, at your level, fooling with suspension makes sense too. /swaybar..etc.
I'll tell Jeremy to call you, but try the shop. I think he's back.
http://i959.photobucket.com/albums/a...dragwheels.jpg
how much converter are putting in?
Shawn, you are welcome to use my skinnies. If we can just find a night of good air that the track isn't packed we will have a go at it. Just be sure to bring your jack and lifting pucks.
Would be interesting to see what yours runs with stock tires then swap on my skinnies. Assuming we both don't get thrown off the track!
2.
3. pass was made on 13 psi of boost.
4. Year Corvette 2005
5. Type of Trans 2009 Z06 TR6060
6. Type of Suspension stock with QA1 front and rear
7. 3.42 gears
8. Tire MT DR 345X30X18 with 18psi
9. Modifications Trckflow 315 CNC heads ,Fast intake, Fuel system ,Alky,
10. N/A
11. Lunched at 2500 RPM. I did make 3 passes and first pass was 11.15 at 138,46 MPH with 2,281 sek 60” second was 10,624 at 137.60 with 1,904 60” Car has more to give when I turn the boost up to 16-17 psi.
12.
_Kvartmílubrautin Kapelluhrauni Iceland
Date and weather conditions 8/14/11 65 degrees and 68
1,751 60"
107,9 MPH Mid speed
6,889 1/8 et.
138,03 MPH 1/4
10,529 ET at 1/4
http://s700.photobucket.com/albums/w...t=1052C6TT.jpg
Frank "Evilways" warming up for another 11 second pass
Please see page 1 post # 6 for instructions & rules. In order to be placed on the list I need a complete timeslip & completed template in your post per the example.
THE LIST
Regarding correction factors:
Times are received from all over the country and are not corrected. Because track and weather conditions vary, this list ranking does not, and can not, identify the fastest cars or drivers in any particular order. It only lists the recorded times, regardless of conditions, in order from quickest to slowest. In cases where ET is the same, the higher MPH determines list order. The bold numbers refer to the post number utilized to report the elapsed times in this thread.
________________________________________ _________________
NEW or IMPROVED ELASPED TIMES
10.94 @ 123.00 Stanger383
10.52 @ 138.03 Icevettez06
Showroom Stock LS2 (2005 -2007)
12.21 @ 115.45 - LS1LT1 - 06 A6 - (1282)
12.23 @ 115.58 - 06C6FVR - 06 M6 Z51 - (337)
12.29 @ 114.29 - Proney - 07 M6 - (4504)
12.31 @ 114.82 - CYA Vett - 05 M6 F55 - (679)
12.42 @ 113.90 - DrRichie - 05 M6 Z51
12.49 @ 114.90 - Jschindler - 05 M6 Z51
12.53 @ 113.00 - Wicked07C6 - 07 M6 Z51 - (918)
12.54 @ 113.59 - Tony 63 Vette - 06 A6 - (1514)
12.54 @ 113.74 - Tony96LT4 - 06 A6 Z51 - (1153)
12.56 @ 113.39 - Red Sleeper - 06 A6
12.56 @ 112.00 - Orange C6 - 05 A4 Z51 - (60)
12.63 @ 114.88 - Prankster - 06 M6 - (1625)
12.65 @ 111.65 - Zippin Zee - 05 M6 Z51 - (51)
12.66 @ 113.03 - Mdrrandall - 07 M6 Z51 - (1679)
12.69 @ 112.32 - Silverlx - 06 A6 - (876)
12.70 @ 112.43 - Jelsis - 06 A6 Z51 - (456)
12.70 @ 113.00 - Blackmajik - 07 A6 - (1631)
12.71 @ 111.30 - Flyin05 - 05 M6 Z51
12.71 @ 111.00 - Demented - 05 A4 Z51
12.74 @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.75 @ 109.25 - Ponchorello - 05 A4 3.15 - (994)
12.76 @ 112.57 - C5Pilot - 07 A6 Z51 - (907)
12.79 @ 112.17 - Jchazr - 05 M6 Z51 - (451)
12.80 @ 111.00 - SheDevilC6 - 07 A6 Z51 - (1672)
12.81 @ 112.83 - Vette-oholic - 05 M6 Z51 - (498)
12.81 @ 110.95 - SkyKing - 07 A6 F55 - (2488)
12.85 @ 114.53 - Mr Z51 - 06 M6 Z51
12.91 @ 111.67 - Brewcitygymratt - 06 A6 - (4582)
12.93 @ 111.40 - DiggyMoe - 07 M6 - (969)
12.97 @ 108.00 - Ginny C6 - 05 A4 F55 - (60)
12.98 @ 108.00 - Tampa Vet - 05 A4 3.15 - (123)
12.99 @ 111.70 - C64ME - 05 M6 Z51 - (333)
13.04 @ 109.15 - TMyers - 06 A6 - (532)
13.05 @ 113.31 - RDunn - 06 M6 - (986)
13.10 @ 108.70 - Rothchilds - 05 A4 F55 3.15 - (1087)
13.12 @ 110.40 - JDWK - 05 M6 Z51
13.25 @ 110.60 - C6 Matt - 05 M6 Z51 - (122)
13.26 @ 108.59 - Sfadchi - 06 A6 Z51 - (888)
13.26 @ 105.30 - Joeking - 05 A4 Z51 - (661)
13.30 @ 107.00 - Shurite44 - 06 A6 Z51 - (769)
13.35 @ 108.10 - Phatpharmd - 06 A6 - (595)
13.62 @ 106.18 - Rich28 - 05 A4 Z51
Showroom Stock LS3 (2008 - ????)
11.71 @ 119.94 - AndrewZPSU - 08 M6 - (2590)
11.80 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3482)
11.97 @ 116.98 - Proney - 08 M6 Z51, NPP - (4656)
12.05 @ 122.05 - AndrewZPSU - 10 A6 NPP - (5055)
12.10 @ 117.60 - Dingrao - 08 A6 - (3567)
12.10 @ 115.19 - Odin - 09 A6 2.73 npp - (4329)
12.12 @ 116.59 - Pettvette - 08 A6 - (4282)
12.15 @ 115.59 - Old Goat - 09 A6 2.73 - (3712)
12.16 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2744)
12.18 @ 117.72 - Hardhattg - 08 M6 Z51 - (2690)
12.23 @ 112.86 - 940CACC - 08 A6 - (2880)
12.24 @ 117.83 - 74Vette - 08 M6 - (4621)
12.26 @ 115.22 - Oklahoma - 08 A6 - (3767)
12.27 @ 118.66 - EZ28 - 08 M6 Z51 NPP - (3251)
12.35 @ 117.47 - Bain - 08 A6 NPP 2.73 - (2759)
12.26 @ 116.94 - TNorman - 08 A6 NPP - (4231)
12.40 @ 114.70 - Jschindler - 08 M6 Z51 NPP - (2138)
12.41 @ 116.15 - JTorchz06 - 09 A6 Z51 NPP - (3190)
12.41 @ 115.38 - HOXXOH - 08 A6 F55 - (2486)
12.42 @ 116.67 - Pea-Jay - 08 A6 - (4453)
12.49 @ 115.54 - 1.8T - 08 M6 Z51 - (2314)
12.55 @ 114.70 - Larry R - 08 A6 2.73 - (4058)
12.60 @ 114.12 - Beefcake - 08 A6 - (2882)
12.65 @ 114.99 - PhillyLS1 - 09 M6 - (3156)
12.66 @ 113.61 - CFP40 - 08 A6 NPP 2.73 - (2834)
13.35 @ 110.78 - M453W - 09 A6 NPP- (4061)
13.42 @ 109.32 - Dan Wendling - 09 A6 NPP - (4036)
Showroom Stock LS3 Grand Sport (2010 - ????)
12.31 @ 115.75 - Grand SportMan - 10 A6 - (5132)
12.59 @ 115.41 - Fastenuf - 11 A6 - (5273)
12.80 @ 113.33 - PhillyLS1 - 11 M6 NPP - (5089)
External Engine Modifications LS2 (Bolt-Ons)
10.62 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, hdrs, 3.73, ptb, tune, & more DR - (3948)
10.92 @ 125.13 - LS1LT1 - 06 A6 - CAI, Conv, fast, hdrs, ptb, skinnies, tune, DR - (4305)
11.12 @ 123.23 - Dicky - 06 A6 - CAI, Conv, cutouts, fast, 3.42, hdrs, tune, DR - (4358)
11.29 @ 122.24 - JMT1669 - 06 A6 - CAI, Conv, cb, hdrs, fast, 3.42, tune, DR - (4431)
11.29 @ 122.29 - FloydSummer of 68 - 07 A6 - CAI, Conv, hdrs, no cats, Pfast, tune, udp, DR - (5109)
11.34 @ 125.78 - Silvervette05 - 05 M6 – Z06 exhaust, pfast/tb, gto skinnys nitto555 tune - (4426)
11.67 @ 118.76 - Its Stock - 06 M6 - CAI, , hdrs, udp, tune, DR - (4569)
11.74 @ 120.83 - Siffert - 07 A6 - CAI, cb, hdrs, pfast, tune, DR - (3986)
11.76 @ 119.00 - NastyC6 - 05 A4 Z51 - CAI, conv, hdrs, 3.73, pi & tb, tune
11.77 @ 121.58 - Red06vette - 06 A6 Z51 - CAI, cb, hdrs, pi & tb, tune - (2179)
11.79 @ 117.26 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 exhaust, muff, tune, DR - (3231)
11.81 @ 118.76 - Joe G - 05 M6 Z51 - CAI, hdrs, 3.90, pi, tune - (1874)
11.87 @ 120.02 - C5pilot - - 07 A6 Z51 - CAI, hdrs, pi, tune, DR - (3558)
11.87 @ 112.99 - Cucchiara - 05 A4 - CAI, cb, conv, hdrs, tune, DR - (839)
11.94 @ 117.99 - JimSpeed - 06 M6 Z51 - CAI, cb, hdrs - (521)
11.96 @ 118.98 - GMRULZ - 06 M6 Z51 -CAI, hdrs, pi, bilstein shocks, tune, DR - (2163)
11.98 @ 116.44 - C6speedjon - 07 M6 Z51 - CAI, cb, hdrs, pi & tb, tune, DR - (1970)
12.01 @ 116.00 - Mr Z51 - 06 M6 Z51 - CAI, cb, hdrs, pintake, tune, DR
12.03 @ 118.50 - Serendipity - 06 M6 - CAI, cb, hdrs
12.03 @ 118.43 - Glennhl - 06 A6 Z51 - CAI, hdrs, pi, tune, DR - (2277)
12.05 @ 117.02 - CYA Vett - 05 M6 F55 M6 - Hdrs
12.05 @ 113.71 - Justasheet - 05 A4 Z51 - CAI, cb, hdrs, tune, 3.73, DR - (4471)
12.08 @ 117.00 - Forrest - 06 M6 Z51 - CAI, cb, hdrs, tune, DR - (1449)
12.09 @ 114.63 - 68RSSS -05 A4 F55 - CAI, hdrs, tune, - (5078)
12.13 @ 115.15 - Ben Diss -07 M6 F55 - CAI, hdrs, tune, Nitto Ivos - (1919)
12.17 @ 119.00 - RHecox - 06 A6 Z51 - CAI, cb, hdrs - (1228)
12.17 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, kdw - (2189)
12.18 @ 115.85 - Mdrrandall - 07 M6 Z51 - CAI, cb - (1822)
12.18 @ 114.00 - Toptoneone - 06 M6 Z51 - CAI, cb, hdrs, tune, DR - (1824)
12.21 @ 115.98 - Mike Campbell - 06 A6 - CAI, DR - (5097)
12.21 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1323)
12.22 @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdrs, tune - (1706)
12.26 @ 119.40 - Dstage - 06 M6 - CAI, cb, fast, hdrs, - (659)
12.26 @ 116.65 - Waveblaster785 - 06 A6 Z51 - CB, fast, hdrs, - (1118)
12.27 @ 115.94 - TNTC4Vette - 06 M6 Z51 - CAI, bilsteins, hdrs, mufflers, ptb, tune Ps2 (5022)
12.27 @ 114.19 - Stanger383 - 05 A4 3.15 - CAI, hdrs, Z06 Muff, tune - (4227)
12.31 @ 115.85 - Dave2007 - 07 A6 Z51 - CAI, cb, hdrs, tune - (3629)
12.36 @ 114.03 - DMcRacer - 07 A6 Z51 - CAI, Continental tires - (5069)
12.37 @ 117.67 - Nicodemus - 05 M6 - CAI, cb, hdrs, gears, tune - (368)
12.37 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdrs - (69)
12.39 @ 115.50 - Tony96 LT4 - 06 A6 Z51 - CAI, ptb, DR - (1473)
12.39 @ 114.83 - DMcRacer - 07 A6 Z51 – CAI, Continental tires - (4526)
12.42 @ 116.12 - YellowVette22 - 05 M6 F55 - CAI, cb, hdrs, DR - (393)
12.49 @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, cb, hdrs
12.49 @ 113.50 - 12 Oh- 06 A6 - CAI, cb, hdrs, tune, DR - (1249)
12.50 @ 118.00 - Larry Chip - 05 M6 - CAI, cb, tune - (177)
12.50 @ 115.20 - Flooznie - 05 A4 - tune - (216)
12.51 @ 113.56 - Jelsis - 06 A6 Z51 - CAI - (492)
12.52 @ 115.26 - Tony B4 - 06 A6 - CAI, cb, hdrs, tune - (1602)
12.52 @ 115.10 - USAF_C6 - 06 A6 - CAI, cb, hdrs, tune - (4408)
12.53 @ 113.78 - Ultimate CC - 07 M6 Z51 - CAI - (1641)
12.53 @ 113.53 - Vade46 - 07 M6 Z51 - CAI, CB - (4280)
12.54 @ 114.99 - BMT03-mach1 - 05 M6 - CAI, no cats, tune (4576)
12.54 @ 113.63 - Anky1631 - 05 M6 - CAI, cb
12.55 @ 114.95 - Shurite44 - 06 A6 Z51 - CAI, cb, hdrs (843)
12.55 @ 111.98 - 2003Anniversary - 05 A4 Z51 - CAI, cb, hdrs - (240)
12.59 @ 114.89 - AZVette2005 - 05 M6 Z51 - CB hdrs, tune - (202)
12.59 @ 113.46 - Badassbu - 07 A6 - CAI - (1769)
12.59 @ 111.46 - 07Cobaltss/sc - 07 A6 F55 - CAI, cb, 3.42, RE11, tune - (5243)
12.60 @ 114.00 - SScamaro - 05 M6 Z51 - CAI, cb, hdrs, tune - (59)
12.62 @ 111.69 - GTkiller97 - 05 M6 Z51 - Ivos - (4525)
12.63 @ 112.93 - 05Vettelag - 05 A4 F55 3.15 - CAI, cb, tune
12.63 @ 112.35 - Lusky - 06 A6 Z51 - CAI, 325 tires
12.65 @ 113.70 - Hitman99 - 06 A6 - CAI, hdrs, tune
12.65 @ 111.39 - 30Milesoffshore - 05 M6 - CAI, cb, tune - (2601)
12.68 @ 113.92 - Sditch - 05 A4 Z51 - CAI - (188)
12.71 @ 113.70 - C6Brian - 07 M6 - Tune - (1616)
12.72 @ 110.85 - AngeloC6 - 05 A4 F55 3.15 open shroud - (1654)
12.77 @ 110.18 - CMB13 - 05 M6 Z51 - CB, DR - (1269)
12.78 @ 112.50 - Dan-t - 06 A6 - Tune - (1179)
12.79 @ 115.58 - Sebaj - 05 M6 - CB, Z06EM, pi & tb, ud, Tune - (4439)
12.80 @ xxx.xx - Thanos - 05 A4 Z51 - CB - (59)
12.83 @ 111.00 - TMyers - 06 A6 - CAI, tune - (768)
12.88 @ 112.50 - MickyC6 - 05 M6 - CAI, cb, tune
12.89 @ 112.57 - Bunk22 - 05 M6 Z51 - CAI, cb, hdrs rockers, tune - (860)
12.89 @ 112.00 - Tom400CFI - 05 M6 Z51 - CB -(830)
12.90 @ 114.83 - Normlunt - 05 M6 Z51 - tstat - (541)
12.90 @ 111.82 - Goatdad - 06 A6 - CB - (5203)
12.93 @ 110.64 - C6Vette - 05 M6 Z51 - CAI, cb, tune - (1206)
12.97 @ 111.22 - Zoli007 - 06 M6 Z51 - CB - (226)
12.97 @ 109.00 - Tsnipe11 - 05 A4 Z51 - CAI, hdrs, tune - (697)
12.99 @ 111.25 - Parkev - 05 M6 Z51 - CB - (83)
13.30 @ 110.00 - Chempowr - 05 M6 F55 - CAI, cb - (1041) high alt
13.32 @ 108.87 - CorvettePilot - 05 M6 Z51 - CB
13.95 @ 104.94 - Fright88 - 06 A6 - CB, hdrs - (1683) high alt
External Engine Modifications LS3 (Bolt-Ons)
10.82 @ 125.82 - HOXXOH - 08 A6 F55 - CAI, conv, ptb, Z06 Exhaust, tune, & more DR - (4808)
10.98 @ 124.66 - Theofel - 08 A6 - CAI, cb, conv, hdrs, 315, tune, & more DR - (4743)
11.22 @ 125.83 - 8850 - 08 A6 NPP 2.73 - CAI, hdrs, tune Dr - (4854)
11.25 @ 125.07 - Jbsblownc5 - 08 M6 Z51 - CAI, cb, hdrs, pi, 3.73, torco & meth inj, tune DR - (3743)
11.46 @ 119.14 - HPAvette - 08 A6 Z51 NPP 2.73 – CAI, conv hdrs tune DR - (5245)
11.51 @ 122.72 - James1990 - 08 A6 Z51 NPP - CAI, cf/ hood, hdrs, ptb, Z06rear, tune, Invos - (3569)
11.53 @ 121.20 - XStang - 08 A6 Z51 - CAI, Conv, hdrs, ptb udp, tune, - (3737)
11.54 @ 123.09 - JerzeyLS3 - 08 A6 – CAI, CBx hdrs, tune (5150)
11.55 @ 120.71 - StageIt - 08 M6 Z51 - CB, hdrs, fast, 3.90, Et St - (3089)
11.56 @ 120.02 - Quicktime - 08 M6 - CAI, cb, hdrs, pi & tb, tune DR - (2409)
11.56 @ 118.82 - MCV - 08 M6 Z51 - CAI, DR - (1852)
11.68 @ 121.22 - Socalz06 - 08 A6 - CAI, hdrs, DR - (2594)
11.70 @ 118.54 - Z51 6spd - 08 A6 Z51 NPP - Ewp, hdrs, tune - (2175)
11.72 @ 118.81 - BSPC608 - 08 A6 Z51 NPP – CAI, hdrs, tune DR - (4425)
11.79 @ 122.65 - Y2K2Z28 -08 A6 Z51 - CAI, cb, hdrs, tune Nitto Ivos - (3790)
11.98 @ 120.04 - Rock n' Blue08 - 08 M6 -CAI, hdrs, 3.90, Xpipe Z06 muff, - (2894)
11.99 @ 120.44 - 1.8T - 08 M6 Z51 - CAI, cb, hdrs, tune, DRs - (2471)
11.99 @ 120.25 - HeavyRightFoot - 08 M6 Z51 NPP - CAI, hdrs, tune - (4436)
12.00 @ 116.49 - Chets Z06 - 08 M6 - Nittos - (4479)
12.01 @ 119.91 - Insom - 09 M6 Z51 NPP - CAI, hdrs, pi, ud, tune, DR-(4477)
12.01 @ 116.26 - Pettvette - 08 A6 - propped shroud no af - (4602)
12.03 @ 120.42 - Quikag - 08 M6 Z51 - CAI, cb, hdrs, tune - (2529)
12.04 @ 115.99 - Bain - 08 A6 NPP 2.73 - CAI - (3529)
12.10 @ 118.03 - TorchZ06 - 09 A6 NPP 2.73 - CAI - (4224)
12.12 @ 118.06 - Badassbu - 09 A6 NPP - Removed fuse - (3145)
12.14 @ 118.12 - Crisis - 09 A6 Z51 - Cai - (5238)
12.17 @ 117.24 - QuickZilver - 08 A6 Z51 NPP - Removed fuse - (3544)
12.26 @ 117.52 - Ragtop99 - 08 M6 Z51 - CAI, hdrs - (3931)
12.34 @ 118.40 - Airbuspilot - 08 M6 - CB - (3715)
12.46 @ 117.86 - MMartin - 08 A6 Z51 - CAI, hdrs, tune - (2910)
12.56 @ 114.70 - Gfish - 08 A6 Z51 NPP - CAI, tune - (5185)
13.33 @ 113.31 - Gaussian Mist - 08 M6 F55 NPP - Npp comander - (2706)
External Engine Modifications Grand Sport (Bolt-Ons)
11.94 @ 118.55 - Agent White - 10 A6 NPP- CAI, hdr tune - (4581)
12.01 @ 117.15 -GrandSportMan -10 A6 - CAIHM - (5159)
Internal Engine Modifications LS2
10.58 @ 131.43 - DSP300C - 07 M6 – al/fw, CAI, cb, ewp, pfast H&C, hdrs, 4.10, 100maf, tune, DR - (4334)
10.59 @ 130.09 - Dennis50NJ - 05 A4 Z51 - CAI, cam, cb, conv, ewp, pfast, hdrs, 3.73, ptb, tune, DR - (4302)
10.66 @ 133.29 - Braciole - 07 M6 - CAI, cb, dp, ewp, hdrs, H&C pfast, 4.10 tune, DR - (4300)
10.82 @ 127.85 - Silver93vert - 06 A6 - CAI, conv, fast, H&C hdrs, udp, tune, & more DR - (4583)
10.84 @ 125.83 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdrs, ported int/tb, udp DR - (4014)
10.87 @ 125.33 - Tek-Newbie - 05 A4 - CAI, cb, conv, H&C, hdrs, 3.42, intake, tune, DR
10.90 @ 126.00 - Thesubfloor - 07 A6 - CAI, cam, conv, 3.42, hdrs, tune, DR - (3691)
10.94 @ 123.00 - Stanger383 - 05 A4 - CAI, conv, 3.42, H&C, hdrs, ptb, tune, z06muff, DR - (5285)
10.96 @ 125.59 - Mike4572 - 07 A6 - CAI, cam, conv, 3.42, hdrs, PI, PTB, Z06 Muff, tune, DR - (4416)
10.99 @ 126.67 - Joe G - 05 M6 Z51 - CAI, cb, cam, hdrs, 4.10, pfast, tune, DR - (4710)
11.01 @ 127.04 - Pete@Championmotors - 06 A6 F55 - CAI, cb, Conv, H&C hdrs, 3.15, tune, DR - (4615)
11.03 @ 126.46 - Isaiah48 - 05 M6 Z51 - CAI, cb, 3.90, H&C hdrs, tune, DR - (3923)
11.19 @ 124.17 - C6Jack - 06 A6 - CAI, cam, cb, conv, hdrs, pi & tb, udp DR - (4260)
11.19 @ 123.05 - Evilways - 06 A6 Z51 - CAI, cb, cam, hdrs, L92/L76 combo tune, Dr - (4079-80)
11.20 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdrs, no muff, tune,DR - (2478)
11.23 @ 123.00 - Texas Ranger - 07 M6 - CAI, cb, cam, hdrs, 4.10, udp, tune, Z06 tires - (1696)
11.24 @ 123.05 - Its Stock - 06 M6 - CAI, cam, hdrs, udp, tune, DR - (5088)
11.31 @ 121.49 - Justasheet - 05 A4 Z51 - CAI, cb, cam, conv, hdrs, ptb pfast, Z06 Muff, tune, 3.73, DR - (5037)
11.35 @ 121.70 - C6speedjon - 07 M6 Z51 - CAI, cb, cam, hdrs, pfast/tb, tune, DR - (3472)
11.44 @ 120.11 - Justasheet - 05 A4 Z51 - CAI, cam, conv, pitb, hdrs, Z06 muff, 3.73, tune, DR - (4791)
11.46 @ 122.96 - Superstock1200 - 06 A6 - CAI, cb, cam, hdrs, pi - (2847)
11.49 @ 125.62 - Wa$nt me - 06 M6 Z51 - CAI, cb, cam, fast hdrs, udp, tune - (1610)
11.52 @ 125.73 - High Roller1 - 06 A6 Z51 - CAI, cb, H&C, hdrs, udp, tune, DR - (1909)
11.53 @ 124.97 - Boiler RXC6 - 05 M6 F55 - CAI, cb, fast, H&C, hdrs, tune -(871)
11.55 @ 126.31 - Bowmanized - 07 M6 - CAI, cb, pfast, H&C, hdrs, susp, tune, DR - (2757)
11.56 @ 122.88 - Sebaj - 05 M6 - CB, Z06EM, H&C pi & tb, QA1 shocks, ud, Tune - (5269)
11.76 @ 116.76 - 1955 Belair - 05 A4 Z51 - CAI, cb, conv, fast, H&C, hdrs, tune, DR
11.79 @ 120.12 - Greentank - 06 A6 - CAI, cb, 3.15, H&C, hdrs - (1821)
11.98 @ 120.87 - Mr Z51 - 06 M6 Z51 - CAI, cam, 4.10, hdrs, pi, udp, DR - (1265)
11.99 @ 120.11 - Turboffr - 06 M6 Z51 - CAI, cam, hdrs, fast udp, tune, DR - (4465)
12.12 @ 118.27 - Sebaj - 05 M6 - CB, H&C,Z06EM, pi & tb, ud, Tune PS2 - (4547)
12.31 @ 119.28 - Black02SS - 07 M6 - CAI, cam, hdrs, tune
13.12 @ 119.00 - Mitchell242 - 05 M6 - CAI, cb, fast, H&C, hdrs, tune
Internal Engine Modifications LS3
10.61 @ 131.81 - Turbovic - 08 M6 - cam, gto skinnies, hdrs, pi, tune, Z06 susp,DR - (4621)
10.63 @ 132.44 - Max@Cartek - 08 M6 - Cartek 4X H&C package, DR - (3644)
10.66 @ 131.68 - Doug@ECS - 08 M6 Z51 NPP - Blistens, H &C CAI, hdrs, 3.90, tune, DR - (3198)
10.73 @ 131.28 - Ls3yeager - 08 M6 - CAI, cb, cam, gto skinnies, hdrs, ported tb/int, udp tune, DR - (3972)
10.78 @ 127.17 - Theofel - 08 A6 - CAI, cb, cam, conv, ewp, hdrs, 315, tune, & more DR - (5107)
11.03 @ 126.93 - Socalz06 - 08 A6 - CAI, cam, conv, hdrs, tune, DR - (3900)
11.10 @ 123.70 - Xstang - 08 A6 - CAI, cam, conv, hdrs, shaneTB, tune, DR - (4073)
11.14 @ 129.27 - AndrewAPSU - 08 M6 - CAI, cam, hdrs, Z06 Exhaust, DR - (4211)
11.17 @ 120.58 - Texasranger - 08 A6 - CAI, cam, hdrs, 3.15, tune, DR - (2805)
11.94 @ 121.11 - Beefcake - 08 A6 - CAI, cam, hdrs, tune -(3039)
Power Adders LS2 (supercharger, turbo, nitrous)
9.73 @ 143.17 - Doug@ECS - 05 A4 F55 -Novi 2200, alky, cam, conv, hdrs, RPM trans, 3.42 , tune, DR - (3262)
9.93 @ 136.88 - Tekhombre - 05 M6 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune - (1157)
10.29 @ 138.17 - BlownV6 - 06 A6 – N2O, CAI, cb, H&C, hdrs, tune, DR
10.29 @ 135.00 - Willisfast - 06 M6 Z51 - SC with meth, cam, CB, hdrs, DR
10.37 @ 143.19 - FactoryRaceCar - 05 A4 – TTurbo with alky, Conv, 3.42gears, z06 rear, RPM Trans,Nittos & more - (5240)
10.68 @ 136.70 - N77nxc - 07 A6 - SC, CAI, cam, conv, hdrs, DR - (4221)
10.86 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, cb, conv, 3.73, hdrs, tune, DR - (480)
10.89 @ 129.93 - DTE - 05 A4 – Twin Turbo, gears, muff, DR - (939)
10.99 @ 125.65 - Z51 6spd - 06 A6 Z51 - SC, CAI, cb, hdrs, tune, - (3300)
11.07 @ 127.62 - Nextphasemarko - 06 A6 Z51 - MC, cb, hdrs, DP, DR - (3665)
11.09 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdrs, DR - (2825)
11.18 @ 125.42 - Stuart3232 - 06 M6 Z51 - N2O, CAI, CB, DR
11.28 @ 126.48 - MCV - 06 A6 - SC, CAI, cb, tune, DR - (1652)
11.28 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, cb, hdrs - (1804)
11.31 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdrs, tune - (1900)
11.37 @ 135.29 - Turboffr - 06 M6 Z51 - CAI, cam, hdrs, fast SC, meth, udp, tune, DR - (4520)
11.37 @ 126.64 - Nine Ball - 05 M6 Z51 - SC, cb, cam, hdrs, tune, DR - (589)
11.40 @ 121.47 - C6 Roller - 05 A4 - SC, hdrs, DR - (1772)
11.89 @ 120.20 - FLC6 - 05 A4 3.15 - N2O, CAI, cb
Power Adders LS3 (supercharger, turbo, nitrous)
9.75 @ 139.83 - Silver Bullet C6 - 08 A6 - supercharger, alky, cam, cb, hdrs, pi & pt, DR - (5000)
10.55 @ 135.06 - The Game - 08 M6 Z51 NPP - ECS Novi2000, alky, hdrs, tune, DR - (3238)
10.57 @ 135.18 - Winters 97 GT - 08 M6 - SC, alky, B&B mufflers, tune, DR - (5033)
10.74 @ 136.61 - ZbadestZ - 08 A6 NPP - ECS 2200, hdrs, fuel system, tune DR - (3238)
10.87 @ 131.13 - Beefcake - 08 A6 - CAI, cam, hdrs, SC, tune, DR - (3903)
11.30 @ 124.45 - Deecount - 09 A6 F55 NPP 2.73 - SC, boost a pump, tune - (4222)
Larger Displacement (All entries)
9.51 @ 148.77 - Todd@RPM - 05 A4 -TT, 427, fuel sys, L92 heads, 3.42, RPM Trans DR (4278)
9.65 @ 141.11 - Tluck - 05 A4 Z51 - 402 cid, ccw drag pack, 373, N20 & more, DR - (3922)
9.89 @ 138.76 - Blue RacerC6 - 05 A4 Z51 - SC LPE 427,N20 (100) & RPM trans, DR - (4277)
9.95 @ 139.26 - Thesubfloor - 07 A6 – LS7, CAI, cb, conv, 3.42 H&C forged int, Tune, DR (4469)
10.36 @ 134.42 - Pete Champion Motors - 06 A6 – LS7, cb, conv, 3.15, Cam, fast, forged int, ph, Tune, DR (5157)
10.41 @ 132.71 - RGSTOY - 07 A6 Z51 – LS7, conv, .3.42, hdrs, tune, DR - (4198)
10.41 @ 132.71 - Craftfox - 07 A6 Z51 – 440, conv, fast, 3.42, hdrs, tune, DR - (4469)
10.52 @ 138.03 - Icevettez06 - 05 M6 - 402, apsTT, alky, fast, hdrs, qual, DR (5301)
10.68 @ 133.21 - Schilitj - 05 M6 Z51 - 402, SC, cb, H&C, hdrs - (3529)
10.76 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (782)
11.43 @ 124.43 - Sheesnaz - 06 A6 Z51 - 416 cid, conv, H &C p/fast,& tb, tune, Nitto Ivos - (3740)
11.68 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (662)
1/8 mile Please submit complete 1/8 mile time slip (All entries)
6.51 @ 107.03 - Thesubfloor - 07 A6 - CAI, cam, conv 3.42, hdrs, tune, & more DR - (4693)
6.94 @ 106.14 - Pmj341 - 07 A6 – CAI, conv, 427, H&C, fast, ptb, 100maf, tune, DR - (4361)
7.19 @ 97.56 - Socalz06 - 08 A6 - CAI, cam conv, hdrs, DR - (3782)
7.21 @ 95.10 - Joe G - 05 M6 Z51 - CAI, Cam, 3.90, pfast, hdrs, - (3793)
7.27 @ 98.71 - XStang - 08 A6 Z51 - CAI, conv, hdr, ptb udp, tune, - (3786)
7.27 @ 92.27 - Sparo2 - 05 M6 Z51 – CAI, Cb, afw, ewp hdrs, pi & tb, C5-3.90, tune DR - (4534)
7.34 @ 96.69 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdrs, pintake/TB, udp, tune, DR - (3056)
7.36 @ 98.03 - StageIt - 08 M6 Z51 -Cb, fast, hdrs, 3.90, Et Street - (2863)
7.50 @ 99.47 - Vettechictwins - 08 M6 Z51 - CAI, cam, cb, pi & tb, hdrs, tune PS2s - (3081)
7.65 @ 93.64 - C5Pilot - 07 A6 Z51 - CAI, pi & tb, hdrs, tune Dr - (3558)
7.67 @ 94.37 - DavetteGuy - 08 A6 - CAI, Ptb tune - (5068)
7.83 @ 92.14 - Bunk22 - 05 M6 Z51 - CAI cb, hdrs, pi, nitto ivos - (4164)
8.09 @ 91.07 - Carmos - 08 A6 Z51 NPP - (4046)
8.45 @ 85.00 - ByByBMW - 05 A4 3.15 – CAI, cb, tune - (1664)
DA http://www.dragtimes.com/da-density-...calculator.php
Thank You Twenty First Century Muscle Cars for sponsoring the C6 Tech & Perf section & making this list possible
2. A copy of your entire time slip below (it is there)
3. The complete the details of your pass using this template in your post:
4. Year Corvette 2010
5. Type of Trans A6
6. Type of Suspension base
7. Stock Performance options none
8. Tires utilized stock
9. Modifications if any none
10. Dyno numbers if you have them na
11. The folks at the track were super-nice. The first run I staged with my rear tires (insert idiot face here) and so the starter backed me up. I absolutely had a blast. During my second run I was sleeping at the light and a very cool Camaro has about 0.5 seconds on me. But I "ran him down" and actually "won" the race which put some thrill into it. I was in "S" and let the car shift. I would have liked to run more, but having these runs and thinking about what I did and what I could do differently will make it more useful next time.
EDIT: I had taken the Hawley class and was scared silly by the Super Gas cars. Incredibly great instruction by the Hawley folks, horrible matriculation by me. They did their best with me though. My plan was to try my car out and get some experience before trying the class again. So yes first time at this track with my car. Sorry if that was misleading… Hence the title of the post. :-)
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track
___ Route 66 Chicago Speedway
___ September 10, 2011, overcast ~75 degrees
___ 60'.............2.035
___ 330'...........5.529
___ 660'...........8.304
___ 660’ mph....89.71
___ 1000'.........10.688
___ 1320'.........12.684
___ 1320’ mph…112.07
Last edited by bfppt1; Sep 15, 2011 at 06:35 AM. Reason: Forgot some stuff for the quarter mile list
THE LIST
12.68 @ 112.07 Bfppt1
12.68 @ 112.07 - Bfppt1 - 10 A6 - (5304)
