C6 1/4 Mile Performance Challenge
2012
A6
Suspension stock
No Performance options
Tires utilized M/T bias 26x11.5x17 on C5Z fronts, GTO spares with M&H bias
Modifications: Vararam, ARH, muffler delete, Yank 4000, HpTuners
No Dyno numbers
3200rpm stall up, 35psi front, 18psi rear. 3304lbs race weight. Still went faster despite higher DA, making less HP evident by lower trap speed.
Fayetteville Dragstrip
13 December 2014
DA +40ft
___ 60'.............1.46
___ 330'...........4.39
___ 660'...........6.92
___ 660’ mph....96.46
___ 1000'.......... -----
___ 1320'..........10.89
___ 1320’ .........123.86
Haven't filled out one of these in quite a while so please let me know if I missed anything.
- Category: 1/8th mile
- 2007 Corvette
- Upgraded 6L80E transmission
- Stock suspension except for QA1 double adjustable shocks
- 335/35/17 Hoosier drag radials, M&H front runner tires on GTO spares
- LS7 engine, custom cam, ARH LS2 headers, Borla exhaust, no cats, 3.42 gears, Yank SS4000 converter, PAC 1207 valve springs, ported stock LS7 intake manifold, MSD 8733 launch controller, Cartek linelock, Aces-IV fuel additive
- DA was approximately -500ft at the time of this pass
- Tuned by me
- Launched at 2200RPM
- Haven't had the car dynoed in over 5 years so I have no idea how much power I'm actually making
- January 1, 2015
60'......................1.3857
330'....................4.0577
660'....................6.3542
660' MPH .............108.68
2012 Grand Sport
A6
Stock suspension
2.73 Gears
MT DR 345/35/18
Magnuson Heartbeat, pullies, cam
662/595whp
18 psi in rears.
Texas Motorplex, Ennis, TX
11/01/2014 -250 DA
60'.............1.571
330'...........4.270
660'...........6.476
660’ mph....111.58
1000'.......... 8.374
1320'..........9.980
1320’ mph….140.04
Video of run @ 23:15
- 2007 Corvette
- Tuned by me
- January 1, 2015
Category: LS3 bolt-ons
2008 Coupe
A6 w/stock 2.56 gear
F55
CAI, headers, ported IM, 4000 stall, tune, Z06 mufflers, skinnies, DR's at 18 PSI, both seats out (103#) and replaced with race seat and rollbar (82#)
DA ranged between -524 to -547, Launched at ~2500
A just-for-fun dyno pull (no tuning changes) last Nov netted 394 rwhp
Sacramento Raceway, CA
1-3-15
60'-----1.5422
330----4.4493
1/8----6.9134
MPH---101.27
1000--9.0208
MPH---115.78
1/4----10.8023
MPH---126.84
I was having some mis-fire issues at some point on every pass. Sometimes on the launch, but usually around mid-track. I managed to make 7 passes under 11.00. The best was the 10.8023 @ 126.84 on a 1.5422 launch (mis-fire on launch) and then the 10.8026 @ 124.87 on a 1.5157 60' (mis-fired several times on the back half). It should have run 10.7's easily and more likely into the 10'6's, since I had run 10.92 in Phoenix with 2100' air last April.
So back in Phoenix I pulled the plugs, hoping that was the cause of the mis-fires under heavy load. They weren't too good. Only 1 of the 8 had a full electrode remaining that was at the correct .040 gap. The other 7, which ranged from .072 to .080 gap, had the iridium tip completely missing, but still fired OK during normal driving. I guess I should have changed plugs before the trip, instead of rear hubs.
It was kind of a disappointment to make a 1700 mile round trip with the assumption that the 100,000 mile plugs would still be good enough after 50K of use.
I have a 2013 CTS-V now. If I can get the weather right I think it's going to out perform my 08.
There was a V at Sacramento running 10.4's, just so you know it's possible. Keep having fun.
New plugs are in now, so I'll see what happens tomorrow night. Expected DA to be around 1100', so I'm going full weight street trim and a full tank of gas too. If I can run a 10 at 3350#, I'll be real happy.
2008 Coupe
F55
1-3-15
60'-----1.5422
330----4.4493
1/8----6.9134
MPH---101.27
1000--9.0208
MPH---115.78
1/4----10.8023
MPH---126.84
Good luck on your next outing with new plugs.
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post # _____ posted below
3. The complete the details of your pass using this template in your post:
4. Year Corvette 2007
5. Manual 6 speed
6. Stock suspension
7. Stock Gears 3.42
8. Pontenza RE050A front 275/35ZR18 and Rear 305/30ZR19
9. Modifications: Vararam Cold air,LG Longtubes and mid pipe,Diablo Sport tune
10. Dyno numbers if you have them:None
11. Launch RPM about 2100,3/4 tank of gas,32 psi all around
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track Evadale Raceway, TX
___ Date of the pass & weather conditions 10/18/14 72 degrees muggy
___ 60'.............2.073
___ 330'...........5.544
____660'...........8.330
___ 1000'..........10.694
___ 1320'..........12.67
___ 1320’ mph….114.27
10.916 @ 124.55 C6GS
06.354 @ 108.68 The Subfloor@Centurytrans
09.980 @ 140.04 Monsta01
10.802 @ 126.84 HOXXOH **
12.673 @ 114.27 Diggy Moe
09.886 @ 150.38 DCI
10.926 @ 132.32 BoatRacer
If your time has not been posted it is because you have not followed the requirements for posting your time. I need the entire time slip as well as a completed copy of the template included in your request as required on page one.
**NOTE
Tom, once again gets honorable mention for beating the living hell out of GM parts. Previously destroying a LS3 put him in second place. At the top of the list is Joe who beat his drive train until it finally gave up the ghost after over 263 passes on the stock clutch assembly & then the super strong 05 rear
& trans (Joe correct me if I mis typed)
Showroom Stock LS2 (2005 -2007)
12.215 @ 115.45 - LS1LT1 - 06 A6 - (1278)
12.235 @ 115.58 - 06C6FVR - 06 M6 Z51 - (333)
12.290 @ 114.29 - Proney - 07 M6 - (4500)
12.314 @ 114.82 - CYA Vett - 05 M6 F55 - (675)
12.422 @ 113.90 - DrRichie - 05 M6 Z51
12.499 @ 114.90 - Jschindler - 05 M6 Z51
12.53x @ 113.00 - Wicked07C6 - 07 M6 Z51 - (914)
12.540 @ 113.59 - Tony 63 Vette - 06 A6 - (1510)
12.548 @ 113.74 - Tony96LT4 - 06 A6 Z51 - (1149)
12.56x @ 113.39 - Red Sleeper - 06 A6
12.56x @ 112.00 - Orange C6 - 05 A4 Z51 - (56)
12.650 @ 111.65 - Zippin Zee - 05 M6 Z51 - (48)
12.665 @ 113.03 - Mdrrandall - 07 M6 Z51 - (1675)
12.693 @ 114.88 - Prankster - 06 M6 - (1621)
12.69x @ 112.32 - Silverlx - 06 A6 - (872)
12.703 @ 112.43 - Jelsis - 06 A6 Z51 - (452)
12.70x @ 113.00 - Blackmajik - 07 A6 - (1627)
12.71x @ 111.30 - Flyin05 - 05 M6 Z51
12.71x @ 111.00 - Demented - 05 A4 Z51
12.74x @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.756 @ 112.57 - C5Pilot - 07 A6 Z51 - (903)
12.757 @ 109.25 - Ponchorello - 05 A4 3.15 - (990)
12.795 @ 112.17 - Jchazr - 05 M6 Z51 - (447)
12.80x @ 111.00 - SheDevilC6 - 07 A6 Z51 - (1668)
12.81x @ 112.83 - Vette-oholic - 05 M6 Z51 - (494)
12.817 @ 110.95 - SkyKing - 07 A6 F55 - (2480)
12.85x @ 114.53 - Mr Z51 - 06 M6 Z51
12.917 @ 111.67 - Brewcitygymratt - 06 A6 - (4578)
12.936 @ 111.40 - DiggyMoe - 07 M6 - (965)
12.97x @ 108.00 - Ginny C6 - 05 A4 F55 - (56)
12.98x @ 108.00 - Tampa Vet - 05 A4 3.15 - (119)
12.99x @ 111.70 - C64ME - 05 M6 Z51 - (329)
13.04x @ 109.15 - TMyers - 06 A6 - (528)
13.054 @ 113.31 - RDunn - 06 M6 - (982)
13.10x @ 108.70 - Rothchilds - 05 A4 F55 3.15
13.12x @ 110.40 - JDWK - 05 M6 Z51
13.25x @ 110.60 - C6 Matt - 05 M6 Z51 - (118)
13.267 @ 108.59 - Sfadchi - 06 A6 Z51 - (884)
13.26x @ 105.30 - Joeking - 05 A4 Z51 - (657)
13.30x @ 107.00 - Shurite44 - 06 A6 Z51 - (764)
13.35x @ 108.10 - Phatpharmd - 06 A6 - (591)
13.62x @ 106.18 - Rich28 - 05 A4 Z51
Showroom Stock LS3 (2008 - 2013)
11.718 @ 119.94 - AndrewZPSU - 08 M6 - (2586)
11.806 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3478)
11.974 @ 116.98 - Proney - 08 M6 Z51, NPP - (4652)
12.058 @ 122.05 - AndrewZPSU - 10 A6 NPP - (5051)
12.100 @ 115.19 - Odin - 09 A6 2.73 npp - (4325)
12.102 @ 117.60 - Dingrao - 08 A6 - (3561)
12.127 @ 116.59 - Pettvette - 08 A6 - (4278)
12.159 @ 115.59 - Old Goat - 09 A6 2.73 - (3708)
12.167 @ 117.15 - DarkOctane - 08 A6 NPP - (6310)
12.167 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2740)
12.186 @ 117.72 - Hardhattg - 08 M6 Z51 - (2686)
12.237 @ 112.86 - 940CACC - 08 A6 - (2871)
12.244 @ 117.83 - 74Vette - 08 M6 - (4617)
12.273 @ 117.32 - C6David - 08 A6 NPP - (6854)
12.305 @ 116.51 - JBrunoJC6 - 08 A6 NPP - (6722)
12.400 @ 116.36 - RandyDank23 - 08 A6 - (6059)
12.262 @ 115.22 - Oklahoma - 08 A6 - (3765)
12.276 @ 118.66 - EZ28 - 08 M6 Z51 NPP - (3247)
12.355 @ 117.47 - Bain - 08 A6 NPP 2.73 - (2755)
12.357 @ 116.94 - TNorman - 08 A6 NPP - (4227)
12.408 @ 116.11 - XtremeChubbles - 08 A6 Z51 - (6589)
12.409 @ 114.70 - Jschindler - 08 M6 Z51 NPP - (2132)
12.419 @ 116.15 - JTorchz06 - 09 A6 Z51 NPP - (3185)
12.412 @ 115.38 - HOXXOH - 08 A6 F55 - (2478)
12.428 @ 116.67 - Pea-Jay - 08 A6 - (4448)
12.494 @ 115.54 - 1.8T - 08 M6 Z51 - (2310)
12.500 @ 115.53 - Shane Fap - 08 A6 - (6298)
12.514 @ 116.73 - SK360 - 08 A6 2.73 - (6283)
12.552 @ 114.70 - Larry R - 08 A6 2.73 - (4054)
12.600 @ 114.12 - Beefcake - 08 A6 - (2875)
12.658 @ 114.99 - PhillyLS1 - 09 M6 - (3151)
12.668 @ 113.61 - CFP40 - 08 A6 NPP 2.73 - (2828)
12.689 @ 112.07 - Bfppt1 - 10 A6 - (5300)
12.747 @ 114.31 - Detoxx03 - 08 M6 NPP- (4057)
13.354 @ 110.78 - M453W - 09 A6 NPP- (5708)
13.428 @ 109.32 - Dan Wendling - 09 A6 NPP - (4032)
Showroom Stock LS3 Grand Sport (2010 - 2013)
12.319 @ 115.75 - Grand SportMan - 10 A6 - (5128)
12.374 @ 116.98 - Kuhnrod - 10 A6 - (6945)
12.461 @ 116.04 - SawBladz - 13 M6 - (6916)
12.499 @ 115.35 - Paristndude - 10 M6 - (6898)
12.559 @ 115.41 - Fastenuf - 11 A6 - (5269)
12.805 @ 113.33 - PhillyLS1 - 11 M6 NPP - (5085)
Showroom Stock LS7 Commemorative Edition 427 (2013)
11.647 @ 123.13 - Gxpz06 - 13 M6 - (6880)
________________________________
External Engine Modifications LS2 (Bolt-Ons)
10.626 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, hdr, ptb, tune, & more, DR - (3944)
10.788 @ 127.29 - LS1LT1 - 06 A6 - CAI, conv, fast, hdr, ptb, skinnies, tune, & more, DR - (5611)
10.936 @ 123.01 - Dicky - 06 A6 - CAI, conv, cutouts, fast, 3.42, hdr, & more tune, DR - (5485)
11.121 @ 124.49 - Teetheriot - 07 A6 - CAI, conv, fast, hdr,nc , Z06 muff, & more, tune, DR - (5869)
11.293 @ 122.24 - JMT1669 - 06 A6 - CAI, conv, cb, fast, 3.42, hdr, tune, DR - (4427)
11.295 @ 122.29 - FloydSummer of 68 - 07 A6 - CAI, conv, Pfast, hdr, no cats, tune, udp, DR - (5105)
11.342 @ 125.78 - Silvervette05 - 05 M6 – pfast/tb, gto skinnys, Z06 exhaust, tune, DR - (4422)
11.412 @ 119.27 - Devilish34 - 07 M6 - CAI, hdr, pfast, Z06 rear, tune, DR - (5536)
11.420 @ 124.60 - Vade 46 - 07 M6 Z51 - CAI, Fast, 4.10, GTO spares hdr, P/tb tune, DR - (6924)
11.495 @ 121.77 - NastyS1K M6 – Cai, cb 3.90,pfast/tb, gto skinnys, tune, DR - (6669)
11.594 @ 117.15 - Cold6.2 - 05 A4 Z51 - CAI, conv, C5 rear, hdr, tune, DR - (6823)
11.667 @ 118.76 - Its Stock - 06 M6 - CAI, hdr, udp, tune, DR - (4565)
11.747 @ 120.83 - Siffert - 07 A6 - CAI, cb, pfast, hdr, skinnies, tune, DR - (3982)
11.76x @ 119.00 - NastyC6 - 05 A4 Z51 - CAI, conv, 3.73, hdr, pi/tb, tune
11.775 @ 121.58 - Red06vette - 06 A6 Z51 - CAI, cb, hdr, pi/tb, tune - (2175)
11.792 @ 117.26 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 exhaust, tune, DR - (3225)
11.811 @ 118.76 - Joe G - 05 M6 Z51 - CAI, 3.90, hdr, pi, tune, DR - (1870)
11.879 @ 120.02 - C5pilot - - 07 A6 Z51 - CAI, hdr, pi, tune, DR - (3554)
11.87x @ 112.99 - Cucchiara - 05 A4 - CAI, cb, conv, hdr, tune, DR - (835)
11.937 @ 115.77 - DMcRacer - 07 A6 Z51 - CAI, conv, Z06 exhaust, tune, DR - (5438)
11.94x @ 117.99 - JimSpeed - 06 M6 Z51 - CAI, cb, hdr - (525)
11.969 @ 118.98 - GMRULZ - 06 M6 Z51 - Bilstein shocks, cai, hdr, pi, tune, DR - (2159)
11.98x @ 116.44 - C6speedjon - 07 M6 Z51 - CAI, cb, hdr, pi/tb, tune, DR - (1966)
12.01x @ 116.00 - Mr Z51 - 06 M6 Z51 - CAI, cb, hdr, pintake, tune, DR
12.03x @ 118.50 - Serendipity - 06 M6 - CAI, cb, hdr
12.035 @ 118.43 - Glennhl - 06 A6 Z51 - CAI, hdr, pi, tune, DR - (2273)
12.05x @ 117.02 - CYA Vett - 05 M6 F55 M6 - Hdr
12.052 @ 113.71 - Justasheet - 05 A4 Z51 - CAI, cb, 3.73, hdr, tune, DR - (4467)
12.084 @ 117.00 - Forrest - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1445)
12.091 @ 114.63 - 68RSSS -05 A4 F55 - CAI, hdr, tune - (5066)
12.133 @ 116.10 - ParisTNdude - 06 A6 - CAI, cb, hdr, tune, DR - (6566)
12.136 @ 115.15 - Ben Diss - 07 M6 F55 - CAI, hdr, tune, Nitto Ivos - (1915)
12.154 @ 118.81 - Blf0005 - 06 M6 - CAI, cb, eco, hdr, pfast, tune, - (6582)
12.169 @ 116.82 - Gmkillr - 07 M6 Z51 - CAI, cb, fast, hdr, x pipe, tune, Dr - (6345)
12.174 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, kdw - (2185)
12.17x @ 119.00 - RHecox - 06 A6 Z51 - CAI, cb, hdr - (1224)
12.18x @ 115.85 - Mdrrandall - 07 M6 Z51 - CAI, cb - (1818)
12.18x @ 114.00 - Toptoneone - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1820)
12.216 @ 115.98 - Mike Campbell - 06 A6 - CAI, DR - (5093)
12.219 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1319)
12.22x @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdr, tune - (1702)
12.26x @ 119.40 - Dstage - 06 M6 - CAI, cb, fast, hdr, - (654)
12.26x @ 116.65 - Waveblaster785 - 06 A6 Z51 - CB, fast, hdr, - (1114)
12.275 @ 115.94 - TNTC4Vette - 06 M6 Z51 - Bilstein shocks, cai, hdr, no cats, ptb, tune, Ps2 (5018)
12.278 @ 114.19 - Stanger383 - 05 A4 3.15 - CAI, hdr, Z06 Muff, tune - (4223)
12.285 @ 114.46 - AngeloC6 - 05 A4 F55 3.15 - CAI, cb, hdr, hankook tires, tune - (6300)
12.293 @ 118.41 - Ganador01 - 06 A6 F55 - CAI, Fast, hdr, tune (6263)
12.319 @ 115.85 - Dave2007 - 07 A6 Z51 - CAI, cb, hdr, tune - (3625)
12.371 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdr - (64)
12.378 @ 117.67 - Nicodemus - 05 M6 - CAI, cb, gears, hdr, tune - (364)
12.384 @ 116.78 - Goatdad - 06 A6 - CB - (6489)
12.391 @ 115.50 - Tony96 LT4 - 06 A6 Z51 - CAI, ptb, DR - (1469)
12.398 @ 115.47 - Berk4422 - 07 A6 - CAI, cb, hdr,ptb/I, tune - (6536)
12.42x @ 116.12 - YellowVette22 - 05 M6 F55 - CAI, cb, hdr, DR - (393)
12.483 @ 113.52 - EvlJake - 07 A6 - Cb, tune - (6051)
12.49x @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, cb, hdr
12.49x @ 113.50 - 12 Oh- 06 A6 - CAI, cb, hdr, tune, DR - (1245)
12.50x @ 118.00 - Larry Chip - 05 M6 - CAI, cb, tune - (173)
12.50x @ 115.20 - Flooznie - 05 A4 - tune - (212)
12.515 @ 113.56 - Jelsis - 06 A6 Z51 - CAI - (488)
12.522 @ 115.26 - Tony B4 - 06 A6 - CAI, cb, hdr, tune - (1598)
12.525 @ 115.10 - USAF_C6 - 06 A6 - CAI, cb, hdr, tune - (4408)
12.525 @ 112.09 - H-Z/28 - 06 M6 - Cb, no cats, tune - (6362)
12.534 @ 114.99 - BMT03-mach1 - 05 M6 - CAI, no cats, tune (4572)
12.539 @ 113.78 - Ultimate CC - 07 M6 Z51 - CAI - (1641)
12.54x @ 113.63 - Anky1631 - 05 M6 - CAI, cb
12.55x @ 114.95 - Shurite44 - 06 A6 Z51 - CAI, cb, hdr (839)
12.55x @ 111.98 - 2003Anniversary - 05 A4 Z51 - CAI, cb, hdr - (236)
12.590 @ 111.46 - 07Cobaltss/sc - 07 A6 F55 - CAI, cb, 3.42, RE11, tune - (5239)
12.59x @ 114.89 - AZVette2005 - 05 M6 Z51 - CB hdr, tune - (198)
12.59x @ 113.46 - Badassbu - 07 A6 - CAI - (1765)
12.60x @ 114.00 - SScamaro - 05 M6 Z51 - CAI, cb, hdrs, tune - (56)
12.627 @ 111.69 - GTkiller97 - 05 M6 Z51 - Ivos - (4521)
12.636 @ 112.93 - 05Vettelag - 05 A4 F55 3.15 - CAI, cb, tune
12.63x @ 112.35 - Lusky - 06 A6 Z51 - CAI, 325 tires
12.65x @ 113.70 - Hitman99 - 06 A6 - CAI, hdr, tune
12.673 @ 108.02 - DiggyMoe - 07 M6 - CAI, hdr, Tune - (6977)
12.683 @ 111.39 - 30Milesoffshore - 05 M6 - CAI, cb, tune - (2598)
12.68x @ 113.92 - Sditch - 05 A4 Z51 - CAI - (184)
12.712 @ 113.70 - C6Brian - 07 M6 - Tune - (1614)
12.770 @ 110.18 - CMB13 - 05 M6 Z51 - CB, DR - (1265)
12.78x @ 112.50 - Dan-t - 06 A6 - Tune - (1175)
12.797 @ 115.58 - Sebaj - 05 M6 - CB, pi/tb, ud, Z06 exhaust, tune - (4435)
12.83x @ 111.00 - TMyers - 06 A6 - CAI, tune - (764)
12.88x @ 112.50 - MickyC6 - 05 M6 - CAI, cb, tune
12.891 @ 112.57 - Bunk22 - 05 M6 Z51 - CAI, cb, hdr, rockers, tune - (856)
12.89x @ 112.00 - Tom400CFI - 05 M6 Z51 - CB -(826)
12.900 @ 114.83 - Normlunt - 05 M6 Z51 - tstat - (537)
12.933 @ 110.64 - C6Vette - 06 M6 Z51 - CAI, cb, tune - (1202)
12.97x @ 111.22 - Zoli007 - 06 M6 Z51 - CB - (222)
12.97x @ 109.00 - Tsnipe11 - 05 A4 Z51 - CAI, hdr, tune - (693)
12.994 @ 111.25 - Parkev - 05 M6 Z51 - CB - (79)
13.30x @ 110.00 - Chempowr - 05 M6 F55 - CAI, cb - (1037) high alt
13.32x @ 108.87 - CorvettePilot - 05 M6 Z51 - CB
13.953 @ 104.94 - Fright88 - 06 A6 - CB, hdr - (1679) high alt
External Engine Modifications LS3 (Bolt-Ons)
10.802 @ 126.84 - HOXXOH - 08 A6 F55 - CAI, conv, ptb, Z06 Exhaust, tune, & more, DR - (6966)
10.888 @ 125.25 - 8850 - 08 A6 NPP 2.73 - CAI, conv, gto skinnies, hdr, udp, tune, DR - (6178)
10.987 @ 124.66 - Theofel - 08 A6 - CAI, cb, conv, 3.15, hdr, tune, & more DR - (4739)
11.112 @ 121.80 - Shane Fap - 08 A6 - CAI, hdr, tune, Z06 muff, Nittos - (6531)
11.144 @ 123.49 - JBrunoJSBC6 - 08 A6 Z51 – CAI, conv, hdr, tune, DR - (6870)
11.252 @ 125.07 - Jbsblownc5 - 08 M6 Z51 - CAI, cb, 3.73, hdr, pi, torco & meth inj, tune, DR - (3739)
11.266 @ 123.52 - JohnDaMan - 08 A6 - CAI, cb, conv, hdr, ptb, udp, tune, DR - (6785)
11.468 @ 119.14 - HPAvette - 08 A6 Z51 NPP 2.73 – CAI, conv, hdr, tune, DR - (5241)
11.519 @ 122.72 - James1990 - 08 A6 Z51 NPP - CAI, cf/ hood, hdr, ptb, Z06rear, tune, Invos - (3565)
11.537 @ 121.20 - XStang - 08 A6 Z51 - CAI, Conv, hdr, ptb udp, tune, DR - (3735)
11.545 @ 123.09 - JerzeyLS3 - 08 A6 – CAI, CBx, hdr, tune, DR - (5146)
11.558 @ 120.71 - StageIt - 08 M6 Z51 - CB, hdr, fast, 3.90, Et St - (3085)
11.56x @ 120.02 - Quicktime - 08 M6 - CAI, cb, hdr, pi/tb, tune, DR - (2405)
11.562 @ 118.82 - MCV - 08 M6 Z51 - CAI, DR - (1848)
11.597 @ 124.34 - Cmorales515 - 08 M6 - CAI, hdr, ptb, tune, DR - (6762)
11.641 @ 122.03 - Chets LS3 - 08 M6 - CAI, hdr, ptb, skinnies, tune DR - (6772)
11.672 @ 118.89 - Justinjor - 08 M6 Z51 NPP - CAI, hdr, ptb, Removed fuse, DR - (5340)
11.688 @ 121.22 - Socalz06 - 08 A6 - CAI, hdr, DR - (2590)
11.706 @ 118.54 - Z51 6spd - 08 A6 Z51 NPP - Ewp, hdr, tune - (2171)
11.726 @ 118.81 - BSPC608 - 08 A6 Z51 NPP – CAI, hdr, tune, DR - (4421)
11.769 @ 120.88 - Dev1360 -09 M6 - CAI, cb, hdr, Nitto - (6704-16)
11.771 @ 122.28 - SK360 - 08 A6 2.73 - hdr, Z06 muff tune, DR - (6897)
11.783 @ 121.67 - Nosferatu -10 M6 - Bilstein, hdr, tune, michelin - (6795)
11.796 @ 122.65 - Y2K2Z28 -08 A6 Z51 - CAI, cb, hdr, tune, Ivos - (3785)
11.803 @ 121.56 - Cdaniel525 -08 M6 - CAI, hdr, no cats, Z06 exhaust, tune - (5437)
11.805 @ 121.34 - Cusvt - 08 A6 - Cb, hdr, propped shroud, DR - (6727)
11.922 @ 118.74 - JAvery20 - 08 A6 NPP - CAI, tune BFG - (6721)
11.942 @ 119.44 - Corvet786C - 08 M6 - cb, hdr, 3.90, DR - (5854)
11.989 @ 120.04 - Rock n' Blue08 - 08 M6 - CAI, 3.90, hdr, Xpipe, Z06 muff - (2890)
11.992 @ 120.25 - HeavyRightFoot - 08 M6 Z51 NPP - CAI, hdr, tune - (4432)
11.994 @ 120.44 - 1.8T - 08 M6 Z51 - CAI, cb, hdr, tune, DRs - (2464)
11.995 @ 118.34 - Oklahoma - 08 A6 Z51 NPP 2.73 - Z06 exhaust & h pipe, P2s - (5718)
12.017 @ 119.91 - Insom - 09 M6 Z51 NPP - CAI, hdr, pi, ud, tune, DR - (4473)
12.016 @ 116.26 - Pettvette - 08 A6 - propped shroud no af - (4598)
12.033 @ 120.42 - Quikag - 08 M6 Z51 - CAI, cb, hdr, tune - (2525)
12.034 @ 119.35 - SeeFiveOhFun - 09 A6 - Con Dws Tires,cut shroud - (6551)
12.041 @ 115.99 - Bain - 08 A6 NPP 2.73 - CAI - (3525)
12.058 @ 118.15 - DarthOctane - 08 A6 NPP - DR - (6327)
12.103 @ 118.03 - TorchZ06 - 09 A6 NPP 2.73 - CAI - (4220)
12.118 @ 116.77 - MBB - 08 A6 Z51 NPP 2.73 - CAI, hdr, tune, nittos - (6488)
12.122 @ 118.06 - Badassbu - 09 A6 NPP - Removed fuse - (3141)
12.144 @ 118.12 - Crisis - 09 A6 Z51 - Cai - (5234)
12.179 @ 117.24 - QuickZilver - 08 A6 Z51 NPP - Removed fuse - (3540)
12.231 @ 116.61 - Danieloneil01 - 08 M6 NPP - Hdr, NC, nittos - (5703)
12.267 @ 117.52 - Ragtop99 - 08 M6 Z51 - CAI, hdr - (3927)
12.344 @ 118.40 - Airbuspilot - 08 M6 - CB - (3711)
12.410 @ 119.65 - PeterPan - 09 A6 2.73 - CAI, Tune ZR1 exhaust, 325 generals - (5902)
12.467 @ 117.86 - MMartin - 08 A6 Z51 - CAI, hdr, tune - (2906)
12.561 @ 114.70 - Gfish - 08 A6 Z51 NPP - CAI, tune - (5181)
12.509 @ 117.89 - AudaciousNick - 08 A6 Z51 - tires - (6814)
13.336 @ 113.31 - Gaussian Mist - 08 M6 F55 NPP - Npp comander - (2704)
External Engine Modifications Grand Sport (Bolt-Ons)
10.916 @ 124.55 - C6GS - 12 A6 - CAI, conv, hdr, muff delete, tune, DR - (6962-6950)
11.328 @ 125.03 - GrandSportMan -10 A6 - CAIHM, hdr, tune, DR - (6738)
11.884 @ 121.44 - Red98C5 - 11 A6 - CAI, DR - (6936)
11.944 @ 117.06 - GXPZ06 - 13 M6 - CAI, hdr - (6853)
11.945 @ 118.55 - Agent White - 10 A6 NPP - CAI, hdr, tune - (4577)
12.185 @ 116.72 - EBF2K - 11 A6 NPP - CAI, hdr, tune, Ivos - (6398)
12.400 @ 115.45 - Thomasmoto - 11 A6 NPP - M2W switch - (6037)
12.506 @ 112.56 - Truth.B - 13 M6 F55 -non stock Tires - (6936)
External Engine Modifications LS7 Commemorative Edition 427 2013 (Bolt-Ons)
11.385 @ 122.38 - Gxpz06 - 13 M6 - DR (6932)
Internal Engine Modifications LS2
10.157 @ 129.43 - Stanger383 - 05 A4 - CAI, conv, 3.42, H&C, hdr, ptb, Z06muff, tune, & more, DR - (6370)
10.163 @ 131.08 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, H&C, hdr, ptb, tune, & more, DR - (6493)
10.585 @ 131.43 - DSP300C - 07 M6 – al/fw, CAI, cb, ewp, pfast, 4.10, H&C, hdr, 100maf, tune, DR - (4430)
10.665 @ 133.29 - Braciole - 07 M6 - CAI, cb, dp, ewp, pfast, 4.10, hdr, H&C, tune, DR - (4296)
10.672 @ 128.31 - Justasheet - 05 A4 Z51 - CAI, cb, H&C, conv, pfast, 3.73, hdr, ptb, mh, Z06 Muff, tune, DR - (6510)
10.815 @ 128.07 - Joe G - 05 M6 Z51 - CAI, cb, cam, pfast, 4.10, hdrs, tune, DR - (5758)
10.821 @ 127.85 - Silver93vert - 06 A6 - CAI, conv, fast, H&C, hdr, udp, tune, & more DR - (4579)
10.844 @ 125.83 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, ported int/tb, udp, tune, DR - (4010)
10.87x @ 125.33 - Tek-Newbie - 05 A4 - CAI, cb, conv, fast, 3.42, H&C, hdr, tune, DR
10.908 @ 126.00 - Thesubfloor - 07 A6 - CAI, cam, conv, 3.42, hdr, tune, DR - (3687)
10.951 @ 125.20 - Huggerorange73 - 06 A6 Z51 - Cam, cb, conv, fast, hdr, tune, udp, DR - (6843)
10.967 @ 125.59 - Mike4572 - 07 A6 - CAI, cam, conv, 3.42, hdr, pi/tb, Z06 Muff, tune, DR - (4412)
11.002 @ 124.60 - EvlJake - 07 A6 - Cai, cam, conv, cb, hdr Ls3 heads, tune, udp, Dr - (6384)
11.013 @ 127.04 - Pete@Championmotors - 06 A6 F55 - CAI, cb, conv, 3.15, H&C, hdr, tune, DR - (4611)
11.034 @ 126.46 - Isaiah48 - 05 M6 Z51 - CAI, cb, 3.90, H&C hdr, tune, DR - (3918)
11.192 @ 124.17 - C6Jack - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, DR - (4256)
11.199 @ 123.05 - Evilways - 06 A6 Z51 - CAI, cb, cam, hdr, L92/L76 combo, tune, Dr - (4075-76)
11.201 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdr, no muff, tune,DR - (2470)
11.23x @ 123.00 - Texas Ranger - 07 M6 - CAI, cb, cam, 4.10, hdr, udp, tune, Z06 tires - (1692)
11.243 @ 123.05 - Its Stock - 06 M6 - CAI, cam, hdr, udp, tune, DR - (5084)
11.247 @ 126.33 - Sebaj - 05 M6 - CB, Z06 Ex, H&C pi/tb, QA1 shocks, ud, Tune DR - (5934)
11.354 @ 121.70 - C6speedjon - 07 M6 Z51 - CAI, cb, cam, pfast, hdr, ptb, tune, DR - (3468)
11.390 @ 105.83 - Firefighter813x - 06 A6 Z51 - CAI, cb, 3.15, H&C, hdr, ptb, tune, , DR - (6630)
11.467 @ 122.96 - Superstock1200 - 06 A6 - CAI, cb, cam, hdr, pi tune, DR - (2572)
11.49x @ 125.62 - Wa$nt me - 06 M6 Z51 - CAI, cb, cam, fast, hdr, udp, tune, DR - (1606)
11.514 @ 122.48 - GTkiller97 - 05 M6 Z51 - CAI, cam, fast, hdr, tune, DR - (5462)
11.52x @ 125.73 - High Roller1 - 06 A6 Z51 - CAI, cb, H&C, hdr, udp, tune, DR - (1905)
11.535 @ 124.97 - Boiler RXC6 - 05 M6 F55 - CAI, cb, fast, H&C, hdr, tune, DR - (867)
11.552 @ 126.31 - Bowmanized - 07 M6 - CAI, cb, pfast, H&C, hdr, susp, tune, DR - (2757)
11.76x @ 116.76 - 1955 Belair - 05 A4 Z51 - CAI, cb, conv, fast, H&C, hdr, tune, DR
11.790 @ 120.12 - Greentank - 06 A6 - CAI, cb, 3.15, H&C, hdr - (1817)
11.982 @ 120.87 - Mr Z51 - 06 M6 Z51 - CAI, cam, 4.10, hdr, pi, udp, tune, DR - (1261)
11.994 @ 120.11 - Turboffr - 06 M6 Z51 - CAI, cam, hdr, fast udp, tune, DR - (4461)
12.31x @ 119.28 - Black02SS - 07 M6 - CAI, cam, hdr, tune
12.410 @ 120.10 - Covert Guy - 05 M6 Z51 - cam, hdr, tune - (5700)
13.12x @ 119.00 - Mitchell242 - 05 M6 - CAI, cb, fast, H&C, hdr, tune
Internal Engine Modifications LS3
10.125 @ 132.24 - Bspc608 - 08 A4 Z51 NPP - CAI, H&C, conv, 3.42, hdr, udp, tune, DR - (6894)
10.374 @ 133.59 - Matt@TuneTime - 08 M6 Z51- Cai, ewp, fast, hdr, H&C, 4.10, skinnies, tune, DR - (6378)
10.611 @ 131.81 - Turbovic - 08 M6 - cam, gto skinnies, hdr, mh, pi, tune, Z06 susp, tune, DR - (4609)
10.629 @ 126.77 - Shane Fap - 08 A6 - CAI, cam, conv, fast, hdr, tune, Z06 muff, Nittos - (6695)
10.633 @ 132.44 - Max@Cartek - 08 M6 - Cartek 4X H&C package, DR - (3640)
10.662 @ 131.68 - Doug@ECS - 08 M6 Z51 NPP - Blistens, cai, 3.90, H &C, hdr, tune, DR - (3193)
10.673 @ 129.31 - Justinjor - 08 M6 Z51 NPP - CAI, cam, hdr, ptb/int, no fuse, skinnies, udp, tune, Zo6spring DR - (5904)
10.684 @ 126.58 - RV00GT - 08 A4 NPP - CAI, conv, H&C hdr 3.42, tune, DR - (6807)
10.739 @ 131.28 - Ls3yeager - 08 M6 - CAI, cb, cam, gto skinnies, hdrs, pi/tb, udp, tune, DR - (3968)
10.793 @ 127.17 - Theofel - 08 A6 - CAI, cb, cam, conv, ewp, 3.15, hdr, tune, & more, DR - (5086)
10.974 @ 126.72 - LS3Chris - 08 M6 - CAI, cam, hdr, no muff, ptb, tune, DR - (6836)
10.996 @ 130.13 - AndrewZPSU -10 A6 NPP - CAI, cam, hdr, mhvj, ptb, tune, DR - (5571)
11.009 @ 128.08 - Dev1360 -09 M6 - CAI, cam cb, hdr, tune, DR - (6811)
11.032 @ 126.93 - Socalz06 - 08 A6 - CAI, cam, conv, hdr, tune, DR - (3896)
11.109 @ 123.70 - Xstang - 08 A6 - CAI, cam, conv, hdr, shaneTB, tune, DR - (4069)
11.143 @ 129.27 - AndrewZPSU - 08 M6 - CAI, cam, hdr, Z06 Exhaust, tune, DR - (4211)
11.179 @ 120.58 - Texasranger - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.328 @ 122.59 - Pitufina - 08 M6 - CAI, cam, hdr, ptb, z51npp, x pipe, tune, DR - (26820)
11.527 @ 125.42 - CBVette - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.946 @ 121.11 - Beefcake - 08 M6 - CAI, cam, hdr, udp, tune, DR - (5936)
Internal Engine Modifications Grand Sport
10.655 @ 129.16 - RmaC6 - 11 M6 - CAI, cam, drag pk, hdr, pheads, tune, DR - (6901)
10.982 @ 124.94 - Amwells1 -12 M6 - CAI, cam, cb, hdr, tune, DR - (6721)
11.086 @ 122.46 - RZ Ls3vette - 11 A6 - CAI, cam, hdr, fast, zo6 exhaust, tune, DR - (6925)
11.543 @ 121.55 - Racerxrick - 10 M6 - CAI, cam, hdr, ptb, tune, DR - (6893)
11.551 @ 121.66 - Turboffr - 10 A6 - CAI, cam, hdr, tune, - (6817)
Power Adders LS2 (supercharger, turbo, nitrous)
09.522 @ 144.71 - Tucan26 - 05 A4 - SC, alky, cam, conv, fast, hdr, RPM trans, tune, DR - (6729)
09.732 @ 143.17 - Doug@ECS - 05 A4 F55 -Novi 2200, alky, cam, conv, 3.42, hdr, RPM trans, tune, DR - (3258)
09.936 @ 136.88 - Tekhombre - 05 A4 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune, DR - (1153)
09.984 @ 135.44 - Shoaf85 - 07 M6 – Upp Twin Turbo, drag pk, fuel sys, twin disk, 4.10, tune, DR - (6363)
09.996 @ 138.90 - BlownC6 - 07 A6 – SC, alky, Cam, cb, conv, hdr, Fuel sys, tune, & more, DR - (6917)
10.065 @ 141.65 - Jutskin - 05 A4 Z51 – SC Cam, coil overs, Flipdrive, Fast 3.42, Z06rear, & more, DR - (5901)
10.154 @ 139.08 - Devilish34 - 07 M6 - SC, hdr, meth, pintake, Z06 rear, tune, DR - (6701)
10.227 @ 143.70 - FactoryRaceCar - 05 A4 – TTurbo & alky, conv, 3.42, Z06rear, RPM Trans, tune, & more, DR - (5375)
10.420 @ 133.25 - RealCanuk - 07 A6 NPP - SC, gears, hdr, HFcats, tune, DR - (6311)
10.582 @ 135.54 - BMT03-mach1 - 05 M6 - N2O, CAI, cam,no cats, tune, DR (6565
10.665 @ 136.52 - Carlrx7 - 06 M6 Z51 – TTurbo & E85 pfat coil overs, tune, udp, DR - (5544)
10.680 @ 136.70 - N77nxc - 07 A6 - SC, CAI, cam, conv, hdr, DR - (4217)
10.724 @ 128.68 - Xdemonx - 06 M6 - SC, cam, hdr, tune, DR - (6796)
10.866 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, cb, conv, 3.73, hdr, tune, DR - (476)
10.899 @ 129.93 - DTE - 05 A4 – Twin Turbo, gears, muff, DR - (935)
10.905 @ 134.14 - Javw - 07 M6 – APS Twin Turbo, bilsteins, tune, DR - (6357)
10.926 @ 133.32 - Boat Racer - 07 A6 F55 - SC, hdr, Meth, tune, DR - (6983)
10.960 @ 133.10 - NotStock22 - 06 A6 - SC, CAI, cb, hdr, tune, DR - (6821)
10.996 @ 125.65 - Z51 6spd - 06 A6 Z51 - SC, cam, cb, hdr, tune, DR - (3296)
11.074 @ 127.62 - Nextphasemarko - 06 A6 Z51 - MC, cb, hdr, DP, tune, DR - (3661)
11.094 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdr, DR - (2820)
11.18x @ 125.42 - Stuart3232 - 06 M6 Z51 - N2O, CAI, CB, DR
11.281 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, cb, hdr, tune, DR - (1800)
11.285 @ 126.48 - MCV - 06 A6 - SC, CAI, cb, tune, DR - (1648)
11.316 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdr, tune, DR - (1896)
11.370 @ 135.29 - Turboffr - 06 M6 Z51 - SC, cai, cam, fast hdr, meth, udp, tune, DR - (4516)
11.379 @ 126.64 - Nine Ball - 05 M6 Z51 - SC, cb, cam, hdr, tune, DR - (589)
11.402 @ 121.47 - C6 Roller - 05 A4 - SC, hdr, tune, DR - (1768)
11.482 @ 120.98 - AngeloC6 - 05 A4 3.15 - SC, cb, tune - (6600)
Power Adders LS3 (supercharger, turbo, nitrous)
09.556 @ 144.52 - Gsbowman - 08 A6 - SC, cam, conv, 3.42, hdr, Z06 muff, & more, tune, DR - (5347)
09.759 @ 139.83 - Silver Bullet C6 - 08 A6 - SC, alky, cam, cb, hdr, pi/tb, tune, DR - (4986)
10.030 @ 138.50 - Dekan513 - 08 A6 - CAI, cam, conv, hdr N2O, tune, DR - (6930)
10.034 @ 134.38 - Theofel - 08 A6 - SC, cam, cb, conv, 3.15, GTO sk, hdr, meth, pint/tb, tune, & more DR - (6617)
10.081 @ 137.45 - Soslow1 - 09 A6 - SC, cam, hdr, skinny, tune, DR - (6918)
10.150 @ 138.16 - RV00GT - 08 M6 NPP - CAI, cam, hdr gto skinny, N2O, tune, DR - (6498)
10.162 @ 138.72 - Krutch21 - 08 A6 - SC, cam, hdr, meth, tune, DR - (6907)
10.248 @ 139.15 - Slowsome - 08 M6 F55 - ECS Novi, cb, fuel system, H&C, hdr, meth, tune, DR - (5556)
10.276 @ 135.55 - Detoxx03 - 08 M6 - SC, alky, cam, pfadt, tune, DR - (6545)
10.482 @ 137.50 - Cusvt - 08 A6 NPP - Cam, hdr N2O, tune, DR - (6813)
10.551 @ 135.06 - The Game - 08 M6 Z51 NPP - ECS Novi2000, alky, hdr, tune, DR - (3232)
10.575 @ 135.18 - Winters 97 GT - 08 M6 - SC, alky, B&B mufflers, tune, DR - (5029)
10.704 @ 136.61 - ZbadestZ - 08 A6 NPP - ECS 2200, hdr, fuel system, tune DR - (5021)
10.732 @ 133.32 - Deecount - 09 A6 F55 NPP 2.73 - SC, boost a pump, tune, DR - (6262)
10.872 @ 131.13 - Beefcake - 08 A6 - CAI, cam, hdr, SC, tune, DR - (3899)
10.879 @ 129.37 - ShawnBrumley - 08 A6 - Eforce SC, tune, DR - (6627)
Power Adders Grand Sport (supercharger, turbo, nitrous)
09.886 @ 150.38 - DCI - 11 M6 GS - SC, cam, hdr,smaller pulley, tune, DR - (6979)
09.980 @ 140.04 - Monsta01 - 12 A6 GS - SC, cam, hdr, p/heads, ud, tune, DR - (6964)
10.657 @ 134.70 - Fordracer9 - 10 A6 GS - SC, hdr, meth, xpipe, tune, DR - (5654)
11.329 @ 124.01 - CaptainBob - 11 A6 GS - Eforce SC, hdr, DR - (6507)
11.399 @ 123.44 - Thomasmoto - 11 A6 NPP - Eforce SC, hdr, M2W switch, DR - (6503)
Larger Displacement (All entries)
07.982 @ 174.44 - Tluck - 05 A4 Z51 - 427cid, turbo, power glide, eldbrock intake, coil overs, & more, tune, DR - (6296)
09.513 @ 148.77 - Todd@RPM - 05 A4 -TT, 427cid, fuel sys, 3.42, L92 heads, RPM Trans, tune, DR - (4274)
09.680 @ 139.20 - JThurik - 10 A6 GS - 377 forged internals, SC, hdr, meth, xpipe, tune, DR - (6722)
09.681 @ 148.36 - Winters 97 GT - 08 M6 - 402, SC, alky, B&B mufflers, tune, DR - (5881)
09.751 @ 147.05 - Icevettez06 - 05 M6 - 402 APSTT, alky, fast, fuel system, Z06 trans, more, tune, DR - (6301)
09.890 @ 138.61 - Pete Champion Motors - 06 A6 – 502 cid, cam, conv, cust intake, hdr,3.15, ph, tune, DR - (6642)
09.895 @ 138.76 - Blue RacerC6 - 05 A4 Z51 - SC LPE 427,N20 (100) & RPM trans, tune, DR - (4273)
09.950 @ 139.26 - Thesubfloor - 07 A6 – LS7, CAI, cb, conv, 3.42 H&C forged int, tune, DR - (4465)
10.231 @ 136.86 - Deecount - 09 A6 Npp 2.73 - SC LPE 427, cam & pheads Ls9 Intake, more tune, DR - (6727)
10.416 @ 132.71 - RGSTOY - 07 A6 Z51 – LS7, conv, 3.42, hdr, tune, DR - (4194)
10.470 @ 130.89 - Craftfox - 07 A6 Z51 – 440cid, conv, fast, 3.42, hdr, tune, DR - (4444)
10.529 @ 138.03 - Icevettez06 - 05 M6 - 402cid, apsTT, alky, fast, hdr, qual, tune, DR - (5297)
10.689 @ 133.21 - Schilitj - 05 M6 Z51 - 402cid, SC, cb, H&C, hdr , tune, DR - (3525)
10.761 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (778)
11.439 @ 124.43 - Sheesnaz - 06 A6 Z51 - 416cid, conv, pfast, H &C, ptb, tune, Nitto Ivos - (3736)
11.689 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (658)
1/8 mile Please submit complete 1/8 mile time slip (All entries)
6.114 @ 118.10 - Shoaf85 - 07 M6 – Upp Twin Turbo, drag pk, fuel sys, twin disk, 3.90, tune, DR - (6523)
6.354 @ 108.68 - Thesubfloor - 07 A6 - CAI, cam, conv 3.42, hdr, tune, & more DR - (6963)
6.894 @ 104.37 - Rmac6 - 11 M6 GS - CAI, cb, drag pack, ported heads hdr, tune, DR - (6876)
6.945 @ 106.14 - Pmj341 - 07 A6 – CAI, conv, 427, fast, H&C, ptb, 100maf, tune, DR - (4357)
7.19x @ 97.56 - Socalz06 - 08 A6 - CAI, cam conv, hdr, DR - (3782)
7.145 @ 97.67 - Carlrx7 - 06 A6 - CAI, cam, conv hdr, tune, DR - (6393)
7.213 @ 95.10 - Joe G - 05 M6 Z51 - CAI, cam, 3.90, pfast, hdr, tune, DR - (3788)
7.279 @ 98.71 - XStang - 08 A6 Z51 - CAI, conv, hdr, ptb udp, tune, - (3786)
7.275 @ 92.27 - Sparo2 - 05 M6 Z51 – CAI, Cb, afw, ewp hdr, pi/tb, C5-3.90, tune DR - (4530)
7.342 @ 96.69 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, tune, DR - (3052)
7.353 @ 94.30 - Tiresmoke69 - 13 A6 - Conv, tune, Dr - (6808-6809)
7.36x @ 98.03 - StageIt - 08 M6 Z51 -Cb, fast, hdr, 3.90, Et Street - (2863)
7.460 @ 98.45 - Racerxrick - 10 M6 GS - CAI, cam, hdr, p/tb, tune DR - (6879-86)
7.50x @ 99.47 - Vettechictwins - 08 M6 Z51 - CAI, cam, cb, pi/tb, hdr, tune PS2s - (3081)
7.65x @ 93.64 - C5Pilot - 07 A6 Z51 - CAI, pi & tb, hdr, tune Dr - (3558)
7.676 @ 94.37 - DavetteGuy - 08 A6 - CAI, Ptb tune - (5064)
7.835 @ 92.14 - Bunk22 - 05 M6 Z51 - CAI cb, hdr, pi, nitto ivos - (4160)
7.866 @ 92.80 - Brywood - 08 A6 - Cai, cb, hdr, tune (6801)
8.096 @ 91.07 - Carmos - 08 A6 Z51 NPP - (4042)
8.215 @ 102.13 - ATLS2 - 06 A4 - SC, meth, cam. cb, hdr, tune, DR - (6837)
8.428 @ 85.00 - ByByBMW - 05 A4 3.15 – CAI, cb, tune - (1660)
Category: LS3 power adders grand sport
1. Yes
2. Entire time slip
3. Complete details of your pass. 58 degrees & 35% humitity
4. Year of corvette....2011
5. Type of trans....A6
6. Type of suspension.....base
7. Stock performance options...duel mode exhaust
8. Tires... Hoosier drag radials
9. Modifications....a&a supercharger kit, headers,cam, meth, Ported heads
10. Dino #'s. 713/634
11. 26 psi tires 1200 launch
12 track slip
South Georgia Motorsports park
....02/01/2015
....60' 1.621
....330 4.302
....1/8 6.471 @114.49
....1000 8.325
....1/4 9.886 @ 150.38
M
1. Yes
2. Entire time slip
12 track slip
....02/01/2015
....60' 1.621
....330 4.302
....1000 8.325
M
