C6 1/4 Mile Performance Challenge
The clutch master cylinder failed on my vette (see tsb) so I replaced it with a tick version which is still a stock piece that allows the car to be shifted normally and function as it should, It's not like it makes the car accelerate faster.
I just feel as if this were a competition that my car would be judged 'stock' and not put to run against modified cars with more power that's all.
Oh well, if my point isn't agreed then I guess it really doesn't matter as next year my car will indeed have performance enhancing bolt ons and I'll run it again but in the 11's. ..
your times are impressive and Good Job
with that said you can print out the top 10 and slip your time and or slip next to it in your home/garage for bragging rights... thats worth as much as a time posted on the web... you make the same money
Tom.The clutch master cylinder failed on my vette (see tsb) so I replaced it with a tick version which is still a stock piece that allows the car to be shifted normally and function as it should, It's not like it makes the car accelerate faster.
I'll give you an example from 10 years ago.
I ran an 11.98 with my C5Z with a drop in K&N air filter (not a CAI). There is no gain with that filter over the OEM filter. The car had no other modifications other that. I too assumed it was "bonestock". Well, I was added to the section to what the C5Z Fast List calls C5 Z06 CAI and DOT Tire Times (drag radial and bias ply) . The rules stated : Bone-stock, except just an air intake or modified air-path and drag radial tires or non-stock tires. I did not argue but I did request clarification which I did receive. I was determined to better my performance and abide by the rules. Subsequently, I purchased an OEM filter and proceeded to run a couple more 11 second passes which were better than that K&N filter pass. Mission accomplished.
On another note, different street tires can enhance a pass. I am not saying that it did, just only it can. As for your Tick Master, I can definitively state that I run faster with one.
Good luck with the future Bolt-Ons and looking forward to some new times.
Category: Power Adders Grand Sport
1. Your entire profile completed & read Instructions:
2. A copy of your entire time slip posted to the thread as in post # _____
3. The complete the details of your pass using this template in your post:
4. 2010
5. MN6
6. Stock
7. Stock Performance options :NPP
8. MT Street R's 315/35/17
9. A&A V3 w/supplied 3.8 pulley, Alky Control meth, Quality Motorsports tune, cam, Kooks headers and X pipe, McLeod RXT, drag pack
10. 702/617
11. 4000 launch, still a slight bog, 1/8mph was down to 104 (have run several 108's, headwind dashed hopes for a 138+ run
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Texas Motorplex
___ 11/8/15, mid 60's headwind 10-13mph, I heard DA was 1100-1200
___ 60'.............1.714
___ 330'...........4.657
___ 660'...........7.000
___ 660’ mph....104.91
___ 1000'.........9.025
___ 1320'.........10.700
___ 1320’ mph…135.36
Copy of Time Slip Below:
4. 2008
5. MN6
6. Stock
7. Stock Performance options :NOne
8. Hoosier drag radials 275/40/17, skinnies
9. Cam, headers, FAST, UDP, McLeod RXT, vararam
10. 470/448
11. 5000 launch
___ Sonoma raceway. Sonoma ca
___ 11/11/15 little headwind -1000 da
___ 60'.............1.506
___ 330'...........4.440
___ 660'...........6.887
___ 660’ mph....100.97
___ 1000'.........8.957
___ 1320'.........10.711
___ 1320’ mph…129.38
I bought the car a few weeks ago and love it. Former Supra owner here...
4. Year Corvette: 2008
5. Type of Trans : A6
6. Type of Suspension: Stock
7. Stock Performance options (as in optional gears with the automatic, & etc.)
8. Tires utilized: Crappy firehawk 275/35/19 runflats
9. Modifications: B&B Exhaust
10. Dyno numbers if you have them: N/A
___ Name of the Track: Englishtown, NJ
___ Date of the pass & weather conditions: October 21st, 59 Degrees, DA is -30 Ft.
___ 60'.............1.986
___ 330'...........5.360
___ 660'...........8.07
___ 660’ mph....89.48
___ 1000'.........10.396
___ 1320'.........12.343
___ 1320’ mph…116.35
Had some problems at the track and didn't get many quality runs but this one wasn't too bad. The car has been having problems with wheel hop my last 2 times out. Never did this before, I'm not sure what to do. I've ran my tires everywhere from 16psi all the way to 25psi and have tried many different launch techniques but no matter what I'm getting wheel hop. Maybe something is broken.
A better 60' without wheelhop and I know it would've ran 11.1x's todayCategory : LS2 External Modification
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post # _7087_
3. The complete details of your pass using this template in your post:
4. Year Corvette : 2007
5. Type of Trans : M6
6. Type of Suspension : Z51
7. Stock Performance options (as in optional gears with the automatic, & etc.) : Z51
8. Tires utilized : 275/40/17 Hoosier DR's on chrome C5 ZO6 replica's/ GTO spares with M&H Racemaster Bias-Ply
9. Modifications if any : AR Headers w/Cats, Corsa Extreme CB, Callaway CAI, MGW shifter, Ported FAST 102, Ported stock TB, RPM stage 4 rear w/4.10 gears, ATI 10% UDP, Mantic 9000 Clutch, 160 t-stat, Deka Battery, Kaltech Tune
10. Dyno numbers if you have them : 417hp/419tq
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc : 21psi rear tires/ 40psi fronts, passenger seat and front sway bar removed, 1/8th tank of gas, 230lb driver
___ Name of the Track - Atco
___ Date of the pass & weather conditions - 11/13/15 - 55 degrees +300DA
___ 60'.............1.537
___ 330'...........4.649
___ 660'...........7.213
___ 660’ mph....96.79
___ 1000'.........9.411
___ 1320'.........11.254
___ 1320’ mph….122.82
Copy of Time Slip Below: (the tracks time was 1hr 10min fast for some reason)
4. Year Corvette -2012 Grand Sport
5. Type of Trans- M6
6. Type of Suspension- Stock
8. Tires utilized- Hoosier Drag Radials
9. Modifications if any- K&N CAI, ZO6 exhaust, tune, Dual disc clutch
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc- 48 degree night
___ Name of the-Track Sonoma
___ Date of the pass & weather conditions-11/11/2015
___ 60'.............1.846
___ 330'...........5.091
___ 660'...........7.755
___ 660’ mph....93.38
___ 1000'.........10.059
___ 1320'.........11.991
___ 1320’ mph…117.17
Yes I did and I knew with -1600 ft density altitude that it was now or never. May not see those condition again for a long time.
If I could get my 60' time down from 1.8 to 1.6 (where it should be) I will really be happy. My Hoosier's would not heat up. Anyway, everynight is another learning curve.
Good luck man.
Good luck man.
Get yourself a 17 inch c5z wheel and put the 275/40/17 Hoosier drag radial, 18psi, 2nd gear burnout at 5k RPM. You'll trap higher too since the tire is shorter 👍🏽
10.700 @ 135.36 Racerxrick
10.711 @ 129.38 LS3Chris
11.991 @ 117.17 Rocket-J
11.254 @ 122.82 Vade46
If your time has not been posted it is because you have not followed the requirements for posting your time. I need the entire time slip as well as a completed copy of the template included in your request as required on page one.
Showroom Stock LS2 (2005 -2007)
12.215 @ 115.45 - LS1LT1 - 06 A6 - (1278)
12.235 @ 115.58 - 06C6FVR - 06 M6 Z51 - (333)
12.290 @ 114.29 - Proney - 07 M6 - (4500)
12.314 @ 114.82 - CYA Vett - 05 M6 F55 - (675)
12.422 @ 113.90 - DrRichie - 05 M6 Z51
12.499 @ 114.90 - Jschindler - 05 M6 Z51
12.53x @ 113.00 - Wicked07C6 - 07 M6 Z51 - (914)
12.540 @ 113.59 - Tony 63 Vette - 06 A6 - (1510)
12.548 @ 113.74 - Tony96LT4 - 06 A6 Z51 - (1149)
12.56x @ 113.39 - Red Sleeper - 06 A6
12.56x @ 112.00 - Orange C6 - 05 A4 Z51 - (56)
12.650 @ 111.65 - Zippin Zee - 05 M6 Z51 - (48)
12.665 @ 113.03 - Mdrrandall - 07 M6 Z51 - (1675)
12.693 @ 114.88 - Prankster - 06 M6 - (1621)
12.69x @ 112.32 - Silverlx - 06 A6 - (872)
12.703 @ 112.43 - Jelsis - 06 A6 Z51 - (452)
12.70x @ 113.00 - Blackmajik - 07 A6 - (1627)
12.71x @ 111.30 - Flyin05 - 05 M6 Z51
12.71x @ 111.00 - Demented - 05 A4 Z51
12.74x @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.756 @ 112.57 - C5Pilot - 07 A6 Z51 - (903)
12.757 @ 109.25 - Ponchorello - 05 A4 3.15 - (990)
12.795 @ 112.17 - Jchazr - 05 M6 Z51 - (447)
12.80x @ 111.00 - SheDevilC6 - 07 A6 Z51 - (1668)
12.81x @ 112.83 - Vette-oholic - 05 M6 Z51 - (494)
12.817 @ 110.95 - SkyKing - 07 A6 F55 - (2480)
12.85x @ 114.53 - Mr Z51 - 06 M6 Z51
12.917 @ 111.67 - Brewcitygymratt - 06 A6 - (4578)
12.936 @ 111.40 - DiggyMoe - 07 M6 - (965)
12.97x @ 108.00 - Ginny C6 - 05 A4 F55 - (56)
12.98x @ 108.00 - Tampa Vet - 05 A4 3.15 - (119)
12.99x @ 111.70 - C64ME - 05 M6 Z51 - (329)
13.04x @ 109.15 - TMyers - 06 A6 - (528)
13.054 @ 113.31 - RDunn - 06 M6 - (982)
13.10x @ 108.70 - Rothchilds - 05 A4 F55 3.15
13.12x @ 110.40 - JDWK - 05 M6 Z51
13.25x @ 110.60 - C6 Matt - 05 M6 Z51 - (118)
13.267 @ 108.59 - Sfadchi - 06 A6 Z51 - (884)
13.26x @ 105.30 - Joeking - 05 A4 Z51 - (657)
13.30x @ 107.00 - Shurite44 - 06 A6 Z51 - (764)
13.35x @ 108.10 - Phatpharmd - 06 A6 - (591)
13.62x @ 106.18 - Rich28 - 05 A4 Z51
Showroom Stock LS3 (2008 - 2013)
11.718 @ 119.94 - AndrewZPSU - 08 M6 - (2586)
11.806 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3478)
11.974 @ 116.98 - Proney - 08 M6 Z51, NPP - (4652)
12.058 @ 122.05 - AndrewZPSU - 10 A6 NPP - (5051)
12.100 @ 115.19 - Odin - 09 A6 2.73 npp - (4325)
12.102 @ 117.60 - Dingrao - 08 A6 - (3561)
12.127 @ 116.59 - Pettvette - 08 A6 - (4278)
12.159 @ 115.59 - Old Goat - 09 A6 2.73 - (3708)
12.167 @ 117.15 - DarkOctane - 08 A6 NPP - (6310)
12.167 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2740)
12.186 @ 117.72 - Hardhattg - 08 M6 Z51 - (2686)
12.201 @ 114.07 - DerekSDickens - 08 A6 2.73 - (7061)
12.237 @ 112.86 - 940CACC - 08 A6 - (2871)
12.244 @ 117.83 - 74Vette - 08 M6 - (4617)
12.305 @ 116.51 - JBrunoJC6 - 08 A6 NPP - (6722)
12.400 @ 116.36 - RandyDank23 - 08 A6 - (6059)
12.262 @ 115.22 - Oklahoma - 08 A6 - (3765)
12.276 @ 118.66 - EZ28 - 08 M6 Z51 NPP - (3247)
12.355 @ 117.47 - Bain - 08 A6 NPP 2.73 - (2755)
12.357 @ 116.94 - TNorman - 08 A6 NPP - (4227)
12.408 @ 116.11 - XtremeChubbles - 08 A6 Z51 - (6589)
12.409 @ 114.70 - Jschindler - 08 M6 Z51 NPP - (2132)
12.419 @ 116.15 - JTorchz06 - 09 A6 Z51 NPP - (3185)
12.412 @ 115.38 - HOXXOH - 08 A6 F55 - (2478)
12.428 @ 116.67 - Pea-Jay - 08 A6 - (4448)
12.494 @ 115.54 - 1.8T - 08 M6 Z51 - (2310)
12.500 @ 115.53 - Shane Fap - 08 A6 - (6298)
12.514 @ 116.73 - SK360 - 08 A6 2.73 - (6283)
12.552 @ 114.70 - Larry R - 08 A6 2.73 - (4054)
12.600 @ 114.12 - Beefcake - 08 A6 - (2875)
12.658 @ 114.99 - PhillyLS1 - 09 M6 - (3151)
12.668 @ 113.61 - CFP40 - 08 A6 NPP 2.73 - (2828)
12.689 @ 112.07 - Bfppt1 - 10 A6 - (5300)
12.747 @ 114.31 - Detoxx03 - 08 M6 NPP- (4057)
12.828 @ 113.20 - C6David - 08 A6 NPP - (6854)
13.354 @ 110.78 - M453W - 09 A6 NPP- (5708)
13.428 @ 109.32 - Dan Wendling - 09 A6 NPP - (4032)
Showroom Stock LS3 Grand Sport (2010 - 2013)
12.319 @ 115.75 - Grand SportMan - 10 A6 - (5128)
12.374 @ 116.98 - Kuhnrod - 10 A6 - (6945)
12.461 @ 116.04 - SawBladz - 13 M6 - (6916)
12.499 @ 115.35 - Paristndude - 10 M6 - (6898)
12.559 @ 115.41 - Fastenuf - 11 A6 - (5269)
12.805 @ 113.33 - PhillyLS1 - 11 M6 NPP - (5085)
Showroom Stock LS7 Commemorative Edition 427 (2013)
11.647 @ 123.13 - Gxpz06 - 13 M6 - (6880)
________________________________
External Engine Modifications LS2 (Bolt-Ons)
10.626 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, hdr, ptb, tune, & more, DR - (3944)
10.788 @ 127.29 - LS1LT1 - 06 A6 - CAI, conv, fast, hdr, ptb, skinnies, tune, & more, DR - (5611)
10.936 @ 123.01 - Dicky - 06 A6 - CAI, conv, cutouts, fast, 3.42, hdr, & more tune, DR - (5485)
11.121 @ 124.49 - Teetheriot - 07 A6 - CAI, conv, fast, hdr,nc , Z06 muff, & more, tune, DR - (5869)
11.254 @ 122.82 - Vade 46 - 07 M6 Z51 - CAI, Fast, 4.10, GTO spares hdr, P/tb tune, DR - (7089)
11.293 @ 122.24 - JMT1669 - 06 A6 - CAI, conv, cb, fast, 3.42, hdr, tune, DR - (4427)
11.295 @ 122.29 - FloydSummer of 68 - 07 A6 - CAI, conv, Pfast, hdr, no cats, tune, udp, DR - (5105)
11.342 @ 125.78 - Silvervette05 - 05 M6 – pfast/tb, gto skinnys, Z06 exhaust, tune, DR - (4422)
11.412 @ 119.27 - Devilish34 - 07 M6 - CAI, hdr, pfast, Z06 rear, tune, DR - (5536)
11.495 @ 121.77 - NastyS1K M6 – Cai, cb 3.90,pfast/tb, gto skinnys, tune, DR - (6669)
11.532 @ 117.13 - Da6speed - 06 A6 - CAI, conv, hdr, tune, DR - (7065)
11.594 @ 117.15 - Cold6.2 - 05 A4 Z51 - CAI, conv, C5 rear, hdr, tune, DR - (6823)
11.667 @ 118.76 - Its Stock - 06 M6 - CAI, hdr, udp, tune, DR - (4565)
11.747 @ 120.83 - Siffert - 07 A6 - CAI, cb, pfast, hdr, skinnies, tune, DR - (3982)
11.76x @ 119.00 - NastyC6 - 05 A4 Z51 - CAI, conv, 3.73, hdr, pi/tb, tune
11.775 @ 121.58 - Red06vette - 06 A6 Z51 - CAI, cb, hdr, pi/tb, tune - (2175)
11.792 @ 117.26 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 exhaust, tune, DR - (3225)
11.811 @ 118.76 - Joe G - 05 M6 Z51 - CAI, 3.90, hdr, pi, tune, DR - (1870)
11.879 @ 120.02 - C5pilot - - 07 A6 Z51 - CAI, hdr, pi, tune, DR - (3554)
11.87x @ 112.99 - Cucchiara - 05 A4 - CAI, cb, conv, hdr, tune, DR - (835)
11.937 @ 115.77 - DMcRacer - 07 A6 Z51 - CAI, conv, Z06 exhaust, tune, DR - (5438)
11.94x @ 117.99 - JimSpeed - 06 M6 Z51 - CAI, cb, hdr - (525)
11.969 @ 118.98 - GMRULZ - 06 M6 Z51 - Bilstein shocks, cai, hdr, pi, tune, DR - (2159)
11.98x @ 116.44 - C6speedjon - 07 M6 Z51 - CAI, cb, hdr, pi/tb, tune, DR - (1966)
12.01x @ 116.00 - Mr Z51 - 06 M6 Z51 - CAI, cb, hdr, pintake, tune, DR
12.03x @ 118.50 - Serendipity - 06 M6 - CAI, cb, hdr
12.035 @ 118.43 - Glennhl - 06 A6 Z51 - CAI, hdr, pi, tune, DR - (2273)
12.05x @ 117.02 - CYA Vett - 05 M6 F55 M6 - Hdr
12.052 @ 113.71 - Justasheet - 05 A4 Z51 - CAI, cb, 3.73, hdr, tune, DR - (4467)
12.084 @ 117.00 - Forrest - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1445)
12.091 @ 114.63 - 68RSSS -05 A4 F55 - CAI, hdr, tune - (5066)
12.133 @ 116.10 - ParisTNdude - 06 A6 - CAI, cb, hdr, tune, DR - (6566)
12.136 @ 115.15 - Ben Diss - 07 M6 F55 - CAI, hdr, tune, Nitto Ivos - (1915)
12.154 @ 118.81 - Blf0005 - 06 M6 - CAI, cb, eco, hdr, pfast, tune, - (6582)
12.169 @ 116.82 - Gmkillr - 07 M6 Z51 - CAI, cb, fast, hdr, x pipe, tune, Dr - (6345)
12.174 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, kdw - (2185)
12.17x @ 119.00 - RHecox - 06 A6 Z51 - CAI, cb, hdr - (1224)
12.18x @ 115.85 - Mdrrandall - 07 M6 Z51 - CAI, cb - (1818)
12.18x @ 114.00 - Toptoneone - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1820)
12.216 @ 115.98 - Mike Campbell - 06 A6 - CAI, DR - (5093)
12.219 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1319)
12.22x @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdr, tune - (1702)
12.26x @ 119.40 - Dstage - 06 M6 - CAI, cb, fast, hdr, - (654)
12.26x @ 116.65 - Waveblaster785 - 06 A6 Z51 - CB, fast, hdr, - (1114)
12.275 @ 115.94 - TNTC4Vette - 06 M6 Z51 - Bilstein shocks, cai, hdr, no cats, ptb, tune, Ps2 (5018)
12.278 @ 114.19 - Stanger383 - 05 A4 3.15 - CAI, hdr, Z06 Muff, tune - (4223)
12.285 @ 114.46 - AngeloC6 - 05 A4 F55 3.15 - CAI, cb, hdr, hankook tires, tune - (6300)
12.293 @ 118.41 - Ganador01 - 06 A6 F55 - CAI, Fast, hdr, tune (6263)
12.319 @ 115.85 - Dave2007 - 07 A6 Z51 - CAI, cb, hdr, tune - (3625)
12.371 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdr - (64)
12.378 @ 117.67 - Nicodemus - 05 M6 - CAI, cb, gears, hdr, tune - (364)
12.384 @ 116.78 - Goatdad - 06 A6 - CB - (6489)
12.391 @ 115.50 - Tony96 LT4 - 06 A6 Z51 - CAI, ptb, DR - (1469)
12.398 @ 115.47 - Berk4422 - 07 A6 - CAI, cb, hdr,ptb/I, tune - (6536)
12.42x @ 116.12 - YellowVette22 - 05 M6 F55 - CAI, cb, hdr, DR - (393)
12.483 @ 113.52 - EvlJake - 07 A6 - Cb, tune - (6051)
12.49x @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, cb, hdr
12.49x @ 113.50 - 12 Oh- 06 A6 - CAI, cb, hdr, tune, DR - (1245)
12.50x @ 118.00 - Larry Chip - 05 M6 - CAI, cb, tune - (173)
12.50x @ 115.20 - Flooznie - 05 A4 - tune - (212)
12.515 @ 113.56 - Jelsis - 06 A6 Z51 - CAI - (488)
12.522 @ 115.26 - Tony B4 - 06 A6 - CAI, cb, hdr, tune - (1598)
12.525 @ 115.10 - USAF_C6 - 06 A6 - CAI, cb, hdr, tune - (4408)
12.525 @ 112.09 - H-Z/28 - 06 M6 - Cb, no cats, tune - (6362)
12.534 @ 114.99 - BMT03-mach1 - 05 M6 - CAI, no cats, tune (4572)
12.539 @ 113.78 - Ultimate CC - 07 M6 Z51 - CAI - (1641)
12.54x @ 113.63 - Anky1631 - 05 M6 - CAI, cb
12.55x @ 114.95 - Shurite44 - 06 A6 Z51 - CAI, cb, hdr (839)
12.55x @ 111.98 - 2003Anniversary - 05 A4 Z51 - CAI, cb, hdr - (236)
12.590 @ 111.46 - 07Cobaltss/sc - 07 A6 F55 - CAI, cb, 3.42, RE11, tune - (5239)
12.59x @ 114.89 - AZVette2005 - 05 M6 Z51 - CB hdr, tune - (198)
12.59x @ 113.46 - Badassbu - 07 A6 - CAI - (1765)
12.60x @ 114.00 - SScamaro - 05 M6 Z51 - CAI, cb, hdrs, tune - (56)
12.627 @ 111.69 - GTkiller97 - 05 M6 Z51 - Ivos - (4521)
12.636 @ 112.93 - 05Vettelag - 05 A4 F55 3.15 - CAI, cb, tune
12.63x @ 112.35 - Lusky - 06 A6 Z51 - CAI, 325 tires
12.65x @ 113.70 - Hitman99 - 06 A6 - CAI, hdr, tune
12.673 @ 108.02 - DiggyMoe - 07 M6 - CAI, hdr, Tune - (6977)
12.683 @ 111.39 - 30Milesoffshore - 05 M6 - CAI, cb, tune - (2598)
12.68x @ 113.92 - Sditch - 05 A4 Z51 - CAI - (184)
12.712 @ 113.70 - C6Brian - 07 M6 - Tune - (1614)
12.770 @ 110.18 - CMB13 - 05 M6 Z51 - CB, DR - (1265)
12.78x @ 112.50 - Dan-t - 06 A6 - Tune - (1175)
12.797 @ 115.58 - Sebaj - 05 M6 - CB, pi/tb, ud, Z06 exhaust, tune - (4435)
12.83x @ 111.00 - TMyers - 06 A6 - CAI, tune - (764)
12.88x @ 112.50 - MickyC6 - 05 M6 - CAI, cb, tune
12.891 @ 112.57 - Bunk22 - 05 M6 Z51 - CAI, cb, hdr, rockers, tune - (856)
12.89x @ 112.00 - Tom400CFI - 05 M6 Z51 - CB -(826)
12.900 @ 114.83 - Normlunt - 05 M6 Z51 - tstat - (537)
12.933 @ 110.64 - C6Vette - 06 M6 Z51 - CAI, cb, tune - (1202)
12.97x @ 111.22 - Zoli007 - 06 M6 Z51 - CB - (222)
12.97x @ 109.00 - Tsnipe11 - 05 A4 Z51 - CAI, hdr, tune - (693)
12.994 @ 111.25 - Parkev - 05 M6 Z51 - CB - (79)
13.30x @ 110.00 - Chempowr - 05 M6 F55 - CAI, cb - (1037) high alt
13.32x @ 108.87 - CorvettePilot - 05 M6 Z51 - CB
13.953 @ 104.94 - Fright88 - 06 A6 - CB, hdr - (1679) high alt
External Engine Modifications LS3 (Bolt-Ons)
10.802 @ 126.84 - HOXXOH - 08 A6 F55 - CAI, conv, ptb, Z06 Exhaust, tune, & more, DR - (6966)
10.888 @ 125.25 - 8850 - 08 A6 NPP 2.73 - CAI, conv, gto skinnies, hdr, udp, tune, DR - (6178)
10.987 @ 124.66 - Theofel - 08 A6 - CAI, cb, conv, 3.15, hdr, tune, & more DR - (4739)
11.112 @ 121.80 - Shane Fap - 08 A6 - CAI, hdr, tune, Z06 muff, Nittos - (6531)
11.144 @ 123.49 - JBrunoJSBC6 - 08 A6 Z51 – CAI, conv, hdr, tune, DR - (6870)
11.252 @ 125.07 - Jbsblownc5 - 08 M6 Z51 - CAI, cb, 3.73, hdr, pi, torco & meth inj, tune, DR - (3739)
11.266 @ 123.52 - JohnDaMan - 08 A6 - CAI, cb, conv, hdr, ptb, udp, tune, DR - (6785)
11.468 @ 119.14 - HPAvette - 08 A6 Z51 NPP 2.73 – CAI, conv, hdr, tune, DR - (5241)
11.519 @ 122.72 - James1990 - 08 A6 Z51 NPP - CAI, cf/ hood, hdr, ptb, Z06rear, tune, Invos - (3565)
11.537 @ 121.20 - XStang - 08 A6 Z51 - CAI, Conv, hdr, ptb udp, tune, DR - (3735)
11.545 @ 123.09 - JerzeyLS3 - 08 A6 – CAI, CBx, hdr, tune, DR - (5146)
11.558 @ 120.71 - StageIt - 08 M6 Z51 - CB, hdr, fast, 3.90, Et St - (3085)
11.56x @ 120.02 - Quicktime - 08 M6 - CAI, cb, hdr, pi/tb, tune, DR - (2405)
11.562 @ 118.82 - MCV - 08 M6 Z51 - CAI, DR - (1848)
11.597 @ 124.34 - Cmorales515 - 08 M6 - CAI, hdr, ptb, tune, DR - (6762)
11.641 @ 122.03 - Chets LS3 - 08 M6 - CAI, hdr, ptb, skinnies, tune DR - (6772)
11.672 @ 118.89 - Justinjor - 08 M6 Z51 NPP - CAI, hdr, ptb, Removed fuse, DR - (5340)
11.688 @ 121.22 - Socalz06 - 08 A6 - CAI, hdr, DR - (2590)
11.706 @ 118.54 - Z51 6spd - 08 A6 Z51 NPP - Ewp, hdr, tune - (2171)
11.726 @ 118.81 - BSPC608 - 08 A6 Z51 NPP – CAI, hdr, tune, DR - (4421)
11.769 @ 120.88 - Dev1360 -09 M6 - CAI, cb, hdr, Nitto - (6704-16)
11.771 @ 122.28 - SK360 - 08 A6 2.73 - hdr, Z06 muff tune, DR - (6897)
11.783 @ 121.67 - Nosferatu -10 M6 - Bilstein, hdr, tune, michelin - (6795)
11.796 @ 122.65 - Y2K2Z28 -08 A6 Z51 - CAI, cb, hdr, tune, Ivos - (3785)
11.803 @ 121.56 - Cdaniel525 -08 M6 - CAI, hdr, no cats, Z06 exhaust, tune - (5437)
11.805 @ 121.34 - Cusvt - 08 A6 - Cb, hdr, propped shroud, DR - (6727)
11.922 @ 118.74 - JAvery20 - 08 A6 NPP - CAI, tune BFG - (6721)
11.942 @ 119.44 - Corvet786C - 08 M6 - cb, hdr, 3.90, DR - (5854)
11.983 @ 116.57 - The Nigel - 08 A6 - CB Z06 muff, Tune, DR - (7060)
11.989 @ 120.04 - Rock n' Blue08 - 08 M6 - CAI, 3.90, hdr, Xpipe, Z06 muff - (2890)
11.992 @ 120.25 - HeavyRightFoot - 08 M6 Z51 NPP - CAI, hdr, tune - (4432)
11.994 @ 120.44 - 1.8T - 08 M6 Z51 - CAI, cb, hdr, tune, DRs - (2464)
11.995 @ 118.34 - Oklahoma - 08 A6 Z51 NPP 2.73 - Z06 exhaust & h pipe, P2s - (5718)
12.017 @ 119.91 - Insom - 09 M6 Z51 NPP - CAI, hdr, pi, ud, tune, DR - (4473)
12.016 @ 116.26 - Pettvette - 08 A6 - propped shroud no af - (4598)
12.033 @ 120.42 - Quikag - 08 M6 Z51 - CAI, cb, hdr, tune - (2525)
12.034 @ 119.35 - SeeFiveOhFun - 09 A6 - Con Dws Tires,cut shroud - (6551)
12.041 @ 115.99 - Bain - 08 A6 NPP 2.73 - CAI - (3525)
12.058 @ 118.15 - DarthOctane - 08 A6 NPP - DR - (6327)
12.103 @ 118.03 - TorchZ06 - 09 A6 NPP 2.73 - CAI - (4220)
12.118 @ 116.77 - MBB - 08 A6 Z51 NPP 2.73 - CAI, hdr, tune, nittos - (6488)
12.122 @ 118.06 - Badassbu - 09 A6 NPP - Removed fuse - (3141)
12.144 @ 118.12 - Crisis - 09 A6 Z51 - Cai - (5234)
12.179 @ 117.24 - QuickZilver - 08 A6 Z51 NPP - Removed fuse - (3540)
12.231 @ 116.61 - Danieloneil01 - 08 M6 NPP - Hdr, NC, nittos - (5703)
12.267 @ 117.52 - Ragtop99 - 08 M6 Z51 - CAI, hdr - (3927)
12.289 @ 113.89 - Z51LS3 - 08 M6 Z51 NPP - Michelins - (7030)
12.344 @ 118.40 - Airbuspilot - 08 M6 - CB - (3711)
12.410 @ 119.65 - PeterPan - 09 A6 2.73 - CAI, Tune ZR1 exhaust, 325 generals - (5902)
12.467 @ 117.86 - MMartin - 08 A6 Z51 - CAI, hdr, tune - (2906)
12.561 @ 114.70 - Gfish - 08 A6 Z51 NPP - CAI, tune - (5181)
12.509 @ 117.89 - AudaciousNick - 08 A6 Z51 - tires - (6814)
13.063 @ 111.26 - Denk - 08 A6 Z51 - tires - (7062)
13.336 @ 113.31 - Gaussian Mist - 08 M6 F55 NPP - Npp comander - (2704)
External Engine Modifications Grand Sport (Bolt-Ons)
10.916 @ 124.55 - C6GS - 12 A6 - CAI, conv, hdr, muff delete, tune, DR - (6962-6950)
11.328 @ 125.03 - GrandSportMan -10 A6 - CAIHM, hdr, tune, DR - (6738)
11.884 @ 121.44 - Red98C5 - 11 A6 - CAI, DR - (6936)
11.944 @ 117.06 - GXPZ06 - 13 M6 - CAI, hdr - (6853)
11.945 @ 118.55 - Agent White - 10 A6 NPP - CAI, hdr, tune - (4577)
11.991 @ 117.17 - Rocket-J - 12 M6 - CAI, tune, - (7089)
12.185 @ 116.72 - EBF2K - 11 A6 NPP - CAI, hdr, tune, Ivos - (6398)
12.400 @ 115.45 - Thomasmoto - 11 A6 NPP - M2W switch - (6037)
12.506 @ 112.56 - Truth.B - 13 M6 F55 -non stock Tires - (6936)
External Engine Modifications LS7 Commemorative Edition 427 2013 (Bolt-Ons)
11.385 @ 122.38 - Gxpz06 - 13 M6 - DR (6932)
Internal Engine Modifications LS2
10.157 @ 129.43 - Stanger383 - 05 A4 - CAI, conv, 3.42, H&C, hdr, ptb, Z06muff, tune, & more, DR - (6370)
10.163 @ 131.08 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, H&C, hdr, ptb, tune, & more, DR - (6493)
10.585 @ 131.43 - DSP300C - 07 M6 – al/fw, CAI, cb, ewp, pfast, 4.10, H&C, hdr, 100maf, tune, DR - (4430)
10.665 @ 133.29 - Braciole - 07 M6 - CAI, cb, dp, ewp, pfast, 4.10, hdr, H&C, tune, DR - (4296)
10.672 @ 128.31 - Justasheet - 05 A4 Z51 - CAI, cb, H&C, conv, pfast, 3.73, hdr, ptb, mh, Z06 Muff, tune, DR - (6510)
10.815 @ 128.07 - Joe G - 05 M6 Z51 - CAI, cb, cam, pfast, 4.10, hdrs, tune, DR - (5758)
10.821 @ 127.85 - Silver93vert - 06 A6 - CAI, conv, fast, H&C, hdr, udp, tune, & more DR - (4579)
10.844 @ 125.83 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, ported int/tb, udp, tune, DR - (4010)
10.87x @ 125.33 - Tek-Newbie - 05 A4 - CAI, cb, conv, fast, 3.42, H&C, hdr, tune, DR
10.908 @ 126.00 - Thesubfloor - 07 A6 - CAI, cam, conv, 3.42, hdr, tune, DR - (3687)
10.951 @ 125.20 - Huggerorange73 - 06 A6 Z51 - Cam, cb, conv, fast, hdr, tune, udp, DR - (6843)
10.967 @ 125.59 - Mike4572 - 07 A6 - CAI, cam, conv, 3.42, hdr, pi/tb, Z06 Muff, tune, DR - (4412)
10.972 @ 120.95 - RRbob - 07 A6 Z51 - CAI, cam, Fast102, hdr, tune, DR - (7015)
11.002 @ 124.60 - EvlJake - 07 A6 - Cai, cam, conv, cb, hdr Ls3 heads, tune, udp, Dr - (6384)
11.013 @ 127.04 - Pete@Championmotors - 06 A6 F55 - CAI, cb, conv, 3.15, H&C, hdr, tune, DR - (4611)
11.034 @ 126.46 - Isaiah48 - 05 M6 Z51 - CAI, cb, 3.90, H&C hdr, tune, DR - (3918)
11.171 @ 125.13 - Curtisb23 - 07 M6 Z51 - Cam, cb, hdr, p/fast102, pi/tb, tune, DR - (7011)
11.192 @ 124.17 - C6Jack - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, DR - (4256)
11.199 @ 123.05 - Evilways - 06 A6 Z51 - CAI, cb, cam, hdr, L92/L76 combo, tune, Dr - (4075-76)
11.201 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdr, no muff, tune,DR - (2470)
11.23x @ 123.00 - Texas Ranger - 07 M6 - CAI, cb, cam, 4.10, hdr, udp, tune, Z06 tires - (1692)
11.243 @ 123.05 - Its Stock - 06 M6 - CAI, cam, hdr, udp, tune, DR - (5084)
11.247 @ 126.33 - Sebaj - 05 M6 - CB, Z06 Ex, H&C pi/tb, QA1 shocks, ud, Tune DR - (5934)
11.354 @ 121.70 - C6speedjon - 07 M6 Z51 - CAI, cb, cam, pfast, hdr, ptb, tune, DR - (3468)
11.390 @ 105.83 - Firefighter813x - 06 A6 Z51 - CAI, cb, 3.15, H&C, hdr, ptb, tune, , DR - (6630)
11.467 @ 122.96 - Superstock1200 - 06 A6 - CAI, cb, cam, hdr, pi tune, DR - (2572)
11.49x @ 125.62 - Wa$nt me - 06 M6 Z51 - CAI, cb, cam, fast, hdr, udp, tune, DR - (1606)
11.514 @ 122.48 - GTkiller97 - 05 M6 Z51 - CAI, cam, fast, hdr, tune, DR - (5462)
11.52x @ 125.73 - High Roller1 - 06 A6 Z51 - CAI, cb, H&C, hdr, udp, tune, DR - (1905)
11.535 @ 124.97 - Boiler RXC6 - 05 M6 F55 - CAI, cb, fast, H&C, hdr, tune, DR - (867)
11.552 @ 126.31 - Bowmanized - 07 M6 - CAI, cb, pfast, H&C, hdr, susp, tune, DR - (2757)
11.76x @ 116.76 - 1955 Belair - 05 A4 Z51 - CAI, cb, conv, fast, H&C, hdr, tune, DR
11.790 @ 120.12 - Greentank - 06 A6 - CAI, cb, 3.15, H&C, hdr - (1817)
11.982 @ 120.87 - Mr Z51 - 06 M6 Z51 - CAI, cam, 4.10, hdr, pi, udp, tune, DR - (1261)
11.994 @ 120.11 - Turboffr - 06 M6 Z51 - CAI, cam, hdr, fast udp, tune, DR - (4461)
12.31x @ 119.28 - Black02SS - 07 M6 - CAI, cam, hdr, tune
12.410 @ 120.10 - Covert Guy - 05 M6 Z51 - cam, hdr, tune - (5700)
13.12x @ 119.00 - Mitchell242 - 05 M6 - CAI, cb, fast, H&C, hdr, tune
Internal Engine Modifications LS3
10.125 @ 132.24 - Bspc608 - 08 A4 Z51 NPP - CAI, H&C, conv, 3.42, hdr, udp, tune, DR - (6894)
10.374 @ 133.59 - Matt@TuneTime - 08 M6 Z51- Cai, ewp, fast, hdr, H&C, 4.10, skinnies, tune, DR - (6378)
10.611 @ 131.81 - Turbovic - 08 M6 - cam, gto skinnies, hdr, mh, pi, tune, Z06 susp, tune, DR - (4609)
10.627 @ 127.93 - JBrunoJSBC6 - 08 A6 Z51 – CAI, cam, conv, hdr, ptb/int, Z06 Muff, Z06 rear, tune, DR - (7064)
10.629 @ 126.77 - Shane Fap - 08 A6 - CAI, cam, conv, fast, hdr, tune, Z06 muff, Nittos - (6695)
10.633 @ 132.44 - Max@Cartek - 08 M6 - Cartek 4X H&C package, DR - (3640)
10.662 @ 131.68 - Doug@ECS - 08 M6 Z51 NPP - Blistens, cai, 3.90, H &C, hdr, tune, DR - (3193)
10.673 @ 129.31 - Justinjor - 08 M6 Z51 NPP - CAI, cam, hdr, ptb/int, no fuse, skinnies, udp, tune, Zo6spring DR - (5904)
10.684 @ 126.58 - RV00GT - 08 A4 NPP - CAI, conv, H&C hdr 3.42, tune, DR - (6807)
10.711 @ 129.38 - LS3Chris - 08 M6 - CAI, cam, hdr, no muff, ptb, tune, DR - (7085)
10.739 @ 131.28 - Ls3yeager - 08 M6 - CAI, cb, cam, gto skinnies, hdrs, pi/tb, udp, tune, DR - (3968)
10.783 @ 126.26 - C6David - 08 A6 NPP - Cam, conv, hdr, no muff, tune, DR (6946)
10.793 @ 127.17 - Theofel - 08 A6 - CAI, cb, cam, conv, ewp, 3.15, hdr, tune, & more, DR - (5086)
10.868 @ 128.18 - Dev1360 - 09 M6 - CAI, cam cb, hdr, tune, DR - (7003)
10.996 @ 130.13 - AndrewZPSU -10 A6 NPP - CAI, cam, hdr, mhvj, ptb, tune, DR - (5571)
11.032 @ 126.93 - Socalz06 - 08 A6 - CAI, cam, conv, hdr, tune, DR - (3896)
11.109 @ 123.70 - Xstang - 08 A6 - CAI, cam, conv, hdr, shaneTB, tune, DR - (4069)
11.143 @ 129.27 - AndrewZPSU - 08 M6 - CAI, cam, hdr, Z06 Exhaust, tune, DR - (4211)
11.179 @ 120.58 - Texasranger - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.328 @ 122.59 - Pitufina - 08 M6 - CAI, cam, hdr, ptb, z51npp, x pipe, tune, DR - (26820)
11.527 @ 125.42 - CBVette - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.946 @ 121.11 - Beefcake - 08 M6 - CAI, cam, hdr, udp, tune, DR - (5936)
Internal Engine Modifications Grand Sport
10.414 @ 129.53 - C6GS - 12 A6 - CAI, cam, conv, hdr, muff delete, tune, DR - (6995)
10.655 @ 129.16 - RmaC6 - 11 M6 - CAI, cam, drag pk, hdr, pheads, tune, DR - (6901)
10.982 @ 124.94 - Amwells1 -12 M6 - CAI, cam, cb, hdr, tune, DR - (6721)
11.086 @ 122.46 - RZ Ls3vette - 11 A6 - CAI, cam, hdr, fast, zo6 exhaust, tune, DR - (6925)
11.543 @ 121.55 - Racerxrick - 10 M6 - CAI, cam, hdr, ptb, tune, DR - (6893)
11.551 @ 121.66 - Turboffr - 10 A6 - CAI, cam, hdr, tune, - (6817)
Power Adders LS2 (supercharger, turbo, nitrous)
09.522 @ 144.71 - Tucan26 - 05 A4 - SC, alky, cam, conv, fast, hdr, RPM trans, tune, DR - (6729)
09.732 @ 143.17 - Doug@ECS - 05 A4 F55 -Novi 2200, alky, cam, conv, 3.42, hdr, RPM trans, tune, DR - (3258)
09.936 @ 136.88 - Tekhombre - 05 A4 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune, DR - (1153)
09.984 @ 135.44 - Shoaf85 - 07 M6 – Upp Twin Turbo, drag pk, fuel sys, twin disk, 4.10, tune, DR - (6363)
09.996 @ 138.90 - BlownC6 - 07 A6 – SC, alky, Cam, cb, conv, hdr, Fuel sys, tune, & more, DR - (6917)
10.065 @ 141.65 - Jutskin - 05 A4 Z51 – SC Cam, coil overs, Flipdrive, Fast 3.42, Z06rear, & more, DR - (5901)
10.154 @ 139.08 - Devilish34 - 07 M6 - SC, hdr, meth, pintake, Z06 rear, tune, DR - (6701)
10.227 @ 143.70 - FactoryRaceCar - 05 A4 – TTurbo & alky, conv, 3.42, Z06rear, RPM Trans, tune, & more, DR - (5375)
10.420 @ 133.25 - RealCanuk - 07 A6 NPP - SC, gears, hdr, HFcats, tune, DR - (6311)
10.582 @ 135.54 - BMT03-mach1 - 05 M6 - N2O, CAI, cam,no cats, tune, DR (6565
10.665 @ 136.52 - Carlrx7 - 06 M6 Z51 – TTurbo & E85 pfat coil overs, tune, udp, DR - (5544)
10.680 @ 136.70 - N77nxc - 07 A6 - SC, CAI, cam, conv, hdr, DR - (4217)
10.724 @ 128.68 - Xdemonx - 06 M6 - SC, cam, hdr, tune, DR - (6796)
10.866 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, cb, conv, 3.73, hdr, tune, DR - (476)
10.899 @ 129.93 - DTE - 05 A4 – Twin Turbo, gears, muff, DR - (935)
10.905 @ 134.14 - Javw - 07 M6 – APS Twin Turbo, bilsteins, tune, DR - (6357)
10.926 @ 133.32 - Boat Racer - 07 A6 F55 - SC, hdr, Meth, tune, DR - (6983)
10.960 @ 133.10 - NotStock22 - 06 A6 - SC, CAI, cb, hdr, tune, DR - (6821)
10.996 @ 125.65 - Z51 6spd - 06 A6 Z51 - SC, cam, cb, hdr, tune, DR - (3296)
11.074 @ 127.62 - Nextphasemarko - 06 A6 Z51 - MC, cb, hdr, DP, tune, DR - (3661)
11.094 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdr, DR - (2820)
11.18x @ 125.42 - Stuart3232 - 06 M6 Z51 - N2O, CAI, CB, DR
11.281 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, cb, hdr, tune, DR - (1800)
11.285 @ 126.48 - MCV - 06 A6 - SC, CAI, cb, tune, DR - (1648)
11.316 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdr, tune, DR - (1896)
11.370 @ 135.29 - Turboffr - 06 M6 Z51 - SC, cai, cam, fast hdr, meth, udp, tune, DR - (4516)
11.379 @ 126.64 - Nine Ball - 05 M6 Z51 - SC, cb, cam, hdr, tune, DR - (589)
11.402 @ 121.47 - C6 Roller - 05 A4 - SC, hdr, tune, DR - (1768)
11.411 @ 126.13 - Jaimevrod - 05 M6 - SC, cb, hdr, tune, DR - (7019)
11.482 @ 120.98 - AngeloC6 - 05 A4 3.15 - SC, cb, tune - (6600)
11.502 @ 126.92 - Ptroxx - 06 A6 - SC, Zo6 Exhaust, tune - (7034)
Power Adders LS3 (supercharger, turbo, nitrous)
09.556 @ 144.52 - Gsbowman - 08 A6 - SC, cam, conv, 3.42, hdr, Z06 muff, & more, tune, DR - (5347)
09.759 @ 139.83 - Silver Bullet C6 - 08 A6 - SC, alky, cam, cb, hdr, pi/tb, tune, DR - (4986)
10.030 @ 138.50 - Dekan513 - 08 A6 - CAI, cam, conv, hdr N2O, tune, DR - (6930)
10.034 @ 134.38 - Theofel - 08 A6 - SC, cam, cb, conv, 3.15, GTO sk, hdr, meth, pint/tb, tune, & more DR - (6617)
10.081 @ 137.45 - Soslow1 - 09 A6 - SC, cam, hdr, skinny, tune, DR - (6918)
10.150 @ 138.16 - RV00GT - 08 M6 NPP - CAI, cam, hdr gto skinny, N2O, tune, DR - (6498)
10.162 @ 138.72 - Krutch21 - 08 A6 - SC, cam, hdr, meth, tune, DR - (6907)
10.248 @ 139.15 - Slowsome - 08 M6 F55 - ECS Novi, cb, fuel system, H&C, hdr, meth, tune, DR - (5556)
10.276 @ 135.55 - Detoxx03 - 08 M6 - SC, alky, cam, pfadt, tune, DR - (6545)
10.482 @ 137.50 - Cusvt - 08 A6 NPP - Cam, hdr N2O, tune, DR - (6813)
10.548 @ 134.08 - PituFina - 08 M6 - SC, alky, cam, hdr, twin clutch, X pipe, ZR1 X pipe tune, DR - (7040)
10.551 @ 135.06 - The Game - 08 M6 Z51 NPP - ECS Novi2000, alky, hdr, tune, DR - (3232)
10.575 @ 135.18 - Winters 97 GT - 08 M6 - SC, alky, B&B mufflers, tune, DR - (5029)
10.704 @ 136.61 - ZbadestZ - 08 A6 NPP - ECS 2200, hdr, fuel system, tune DR - (5021)
10.732 @ 133.32 - Deecount - 09 A6 F55 NPP 2.73 - SC, boost a pump, tune, DR - (6262)
10.872 @ 131.13 - Beefcake - 08 A6 - CAI, cam, hdr, SC, tune, DR - (3899)
10.879 @ 129.37 - ShawnBrumley - 08 A6 - Eforce SC, tune, DR - (6627)
11.710 @ 132.21 - FormulaS1 - 08 M6 NPP - SC, hdr, meth, tune - (7032)
11.790 @ 134.73 - Nosferatu -10 M6 - ECS Novi 1500, alky, Bilstein, hdr, tune, michelin - (6986)
Power Adders Grand Sport (supercharger, turbo, nitrous)
09.835 @ 144.95 - DCI - 11 M6 GS - SC, cam, hdr,smaller pulley, tune, DR - (6984)
09.980 @ 140.04 - Monsta01 - 12 A6 GS - SC, cam, hdr, ud, tune, DR - (6964)
10.657 @ 134.70 - Fordracer9 - 10 A6 GS - SC, hdr, meth, xpipe, tune, DR - (5654)
10.700 @ 135.36 - Racerxrick - 10 M6 GS - SC, alky, drag pak, hdr, xpipe, tune, DR - (7085)
11.329 @ 124.01 - CaptainBob - 11 A6 GS - Eforce SC, hdr, DR - (6507)
11.399 @ 123.44 - Thomasmoto - 11 A6 NPP - Eforce SC, hdr, M2W switch, DR - (6503)
Larger Displacement (All entries)
07.982 @ 174.44 - Tluck - 05 A4 Z51 - 427cid, turbo, power glide, eldbrock intake, coil overs, & more, tune, DR - (6296)
09.513 @ 148.77 - Todd@RPM - 05 A4 -TT, 427cid, fuel sys, 3.42, L92 heads, RPM Trans, tune, DR - (4274)
09.680 @ 139.20 - JThurik - 10 A6 GS - 377 forged internals, SC, hdr, meth, xpipe, tune, DR - (6722)
09.681 @ 148.36 - Winters 97 GT - 08 M6 - 402, SC, alky, B&B mufflers, tune, DR - (5881)
09.751 @ 147.05 - Icevettez06 - 05 M6 - 402 APSTT, alky, fast, fuel system, Z06 trans, more, tune, DR - (6301)
09.803 @ 141.05 - Pete Champion Motors - 06 A6 – 502 cid, cam, conv, cust intake, hdr,3.15, ph, tune, DR - (7066)
09.895 @ 138.76 - Blue RacerC6 - 05 A4 Z51 - SC LPE 427,N20 (100) & RPM trans, tune, DR - (4273)
09.950 @ 139.26 - Thesubfloor - 07 A6 – LS7, CAI, cb, conv, 3.42 H&C forged int, tune, DR - (4465)
10.231 @ 136.86 - Deecount - 09 A6 Npp 2.73 - SC LPE 427, cam & pheads Ls9 Intake, more tune, DR - (6727)
10.416 @ 132.71 - RGSTOY - 07 A6 Z51 – LS7, conv, 3.42, hdr, tune, DR - (4194)
10.470 @ 130.89 - Craftfox - 07 A6 Z51 – 440cid, conv, fast, 3.42, hdr, tune, DR - (4444)
10.529 @ 138.03 - Icevettez06 - 05 M6 - 402cid, apsTT, alky, fast, hdr, qual, tune, DR - (5297)
10.689 @ 133.21 - Schilitj - 05 M6 Z51 - 402cid, SC, cb, H&C, hdr , tune, DR - (3525)
10.761 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (778)
11.439 @ 124.43 - Sheesnaz - 06 A6 Z51 - 416cid, conv, pfast, H &C, ptb, tune, Nitto Ivos - (3736)
11.689 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (658)
1/8 mile Please submit complete 1/8 mile time slip (All entries)
6.114 @ 118.10 - Shoaf85 - 07 M6 – Upp Twin Turbo, drag pk, fuel sys, twin disk, 3.90, tune, DR - (6523)
6.354 @ 108.68 - Thesubfloor - 07 A6 - CAI, cam, conv 3.42, hdr, tune, & more DR - (6963)
6.894 @ 104.37 - Rmac6 - 11 M6 GS - CAI, cb, drag pack, ported heads hdr, tune, DR - (6876)
6.945 @ 106.14 - Pmj341 - 07 A6 – CAI, conv, 427, fast, H&C, ptb, 100maf, tune, DR - (4357)
7.005 @ 908.18 - Racerxrick - 10 M6 GS - CAI, cam, hdr, p/tb, tune DR - (7039)
7.19x @ 97.56 - Socalz06 - 08 A6 - CAI, cam conv, hdr, DR - (3782)
7.145 @ 97.67 - Carlrx7 - 06 A6 - CAI, cam, conv hdr, tune, DR - (6393)
7.213 @ 95.10 - Joe G - 05 M6 Z51 - CAI, cam, 3.90, pfast, hdr, tune, DR - (3788)
7.279 @ 98.71 - XStang - 08 A6 Z51 - CAI, conv, hdr, ptb udp, tune, - (3786)
7.275 @ 92.27 - Sparo2 - 05 M6 Z51 – CAI, Cb, afw, ewp hdr, pi/tb, C5-3.90, tune DR - (4530)
7.342 @ 96.69 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, tune, DR - (3052)
7.353 @ 94.30 - Tiresmoke69 - 13 A6 - Conv, tune, Dr - (6808-6809)
7.36x @ 98.03 - StageIt - 08 M6 Z51 -Cb, fast, hdr, 3.90, Et Street - (2863)
7.50x @ 99.47 - Vettechictwins - 08 M6 Z51 - CAI, cam, cb, pi/tb, hdr, tune PS2s - (3081)
7.65x @ 93.64 - C5Pilot - 07 A6 Z51 - CAI, pi & tb, hdr, tune Dr - (3558)
7.676 @ 94.37 - DavetteGuy - 08 A6 - CAI, Ptb tune - (5064)
7.835 @ 92.14 - Bunk22 - 05 M6 Z51 - CAI cb, hdr, pi, nitto ivos - (4160)
7.866 @ 92.80 - Brywood - 08 A6 - Cai, cb, hdr, tune (6801)
8.096 @ 91.07 - Carmos - 08 A6 Z51 NPP - (4042)
8.215 @ 102.13 - ATLS2 - 06 A4 - SC, meth, cam. cb, hdr, tune, DR - (6837)
8.428 @ 85.00 - ByByBMW - 05 A4 3.15 – CAI, cb, tune - (1660)
A better 60' without wheelhop and I know it would've ran 11.1x's todayCongrats on your new best.
Wheel hop ??? Atco usually has excellent track prep. Was someone policing the water and stuff on the track. If the track was good then it is time to check the car.
Hoosier Dr while lighter than MT don't last as long, then there is the rear suspension: shocks, all the rubber bushings, trans mounts and etc...... Good Luck
Thanks Tommy, Yeah I'm not sure what's going on with the constant wheel hop. I've been running my car at Atco for a couple years now and never had this. My tires are really brand new, I bought them in the beginning of this year and have only used them at 3 rentals. The first time I used them in the spring the car left great. The other 2 this fall have been terrible. I haven't had a chance to get the car up in the air yet but there has to be something wrong. The only thing I changed on the car from the spring was a re-tune from a new shop. The car has Hinson mounts, ECS rear brace, C5 axles and a stage 4 RPM diff with the Quaife, so I've got just about everything to avoid wheel hop.
https://youtu.be/bmzk9cgNfYw
might be wrong forum to discuss, they are pretty strict on the rules in here.
And z51ls3 is right, you'll get a lot better response if you start a new thread with the title "Wheel hopping like Bugs Bunny running from Elmer Fudd.....HELP!!" or something like that.
Burying your valid concern in post 7088 of a 10 year old thread isn't the best place to advertise for help.
I know this isn't the place for a discussion about it. I was just responding to a question that was asked and I posted a vid of my best run. I've got other videos where it was much worse, that run I was able to keep it under control a lot more. The discussion will end here. I was actually going to post a thread like that but after doing a search I saw someone recently made a thread with a title just like that.
I think it was wheel hopping like a rabbit or something.
