C6 1/4 Mile Performance Challenge
Old 08-18-2018, 03:25 PM
  #7361
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Originally Posted by Gxpz06
do agree ., and drag radials do make much funner and better starts obsvously yet there’s something to be said about a true street tire launch and technique ., adding to that I completely gave up on my c5z with f1s yet when I got into GS and ls7 cars they do a lot better with oem tires then the older ones
ps to centinennial ., your 1st gear is a 2.97 (which makes 2nd and 3rd come sooner in this transmission gearing) you will for sure need to grab 4th .,if you were a ls7 car for instance where 3rd is deeper especially with 20” wheels then you could ride out 3rd since also ls7 rev limiter is higher .,
Always shift at redline...there is an old thread proving this out in this forum using Dyno sheets. If you can stay in third through the traps and not hit the rev limiter, then do so.
Here you go, more reading from long ago.
https://www.corvetteforum.com/forums...eleration.html
Gxpz06 (08-18-2018)
Old 08-20-2018, 09:20 PM
  #7362
centennialGS
centennialGS's Avatar
Ok Gents, here is my update.
Ran the car a total of 5 times, Messed up one so didnt get a printed time. I launched it at too low of an rpm (2000) and just dumped the clutch, so i bogged twice, and then got too much wheelspin on times when i launched it with a higher rpm. I need to practice some more. But it was A LOT of fun.
It was 86 degrees and humid, so everyone was complaining that their cars were running slow.
Best of my 5 runs was a 13.2. The trap speed is low because I never shifted to 4th because my synchro sometimes grinds in 4th only (thanks to stupid skip shift)
I also let my girl run it by herself one time. She didnt launch it and granny shifted it and got a 14.2. Not bad for someone who barely ever drives stick
Old 08-23-2018, 12:28 PM
  #7363
C6ness
C6ness's Avatar
Manuals are hard to launch at the track. Takes practice (if your clutch holds up). Got to find the right combo of rpm and clutch slip to not bog but not spin. . Dumping the clutch just results in bogging if too low rpm or spinning if too high rpm (as you found). You have to raise rpms and quickly slip the clutch. Or you could get some drag radials. That would give you traction at a more aggressive clutch engagement. However, 13.29 at about 102 is a good ET for that mph. Shifting cleanly into 4th would have broken 13 seconds.
centennialGS (08-23-2018)
Old 08-23-2018, 01:34 PM
  #7364
Joe_G
Joe_G's Avatar
St. Jude Donor '08
It takes practice, but it’s fun. Here is how I do it.
The following 2 users liked this post by Joe_G:
centennialGS (08-23-2018), Underachieved (02-19-2019)
Old 08-23-2018, 07:02 PM
  #7365
centennialGS
Yes, and last thing I want to do is break my car on the track. So, I just need to find that sweet spot. I did shift into 4th on the run where I got a false start, so I never knew my time but my speed was def more then 102.
Wow that was an awesome run. I feel like I learned quite a bit from this video. I watched it 3 times lol
Old 08-23-2018, 07:33 PM
  #7366
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Thanks! Took me a while to get the nerve and skill to launch that high.
Old 08-31-2018, 11:19 AM
  #7367
FNBADAZ06
FNBADAZ06's Avatar
LOL word on that !!!
I'm hoping to finally get back out on the track this fall with my new combo.....and 3.90 rear gears !!!! YAY !!!!
Hope all is going well, my 6 speed drag racing brotha
Old 08-31-2018, 01:25 PM
  #7368
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Nice to hear from you buddy! Still have the Vette but don't have anyone to race here in Missouri (I moved back home).
I heard you can now get gears for the Z06 rear, who did you have install them? They are a great mod as you know.
Old 09-18-2018, 04:13 PM
  #7369
smd001
smd001's Avatar
11' GS vert with BB Bullets and a foam filter.
Stick with MGW shifter
Michilin Pilots.
Middle aged fat guy driver.
I need to find my slip(in the car somewhere) but went to a different track last week and ran 13.19 @ 111.1.
Previous best was a 13.2? at 108. Spins/wheel hops in second and the DA was almost 2600. All in all I think that is in the ballpark for a stock GS with a crappy driver.
centennialGS (09-19-2018)
Old 10-18-2018, 09:54 AM
  #7370
CaptainFalcon
CaptainFalcon's Avatar
Is there anyone else who wants to see the list updated? I have everything that is currently on the list plugged into an excel sheet and I plan on using the Weather Underground history to try to get DA for as many times as I can.
Just wondering if I'm doing this for myself or if anyone else would benefit from a better/updated list?
Old 10-18-2018, 10:07 AM
  #7371
lazerlemonta
lazerlemonta's Avatar
Love to see the list
Old 10-18-2018, 01:14 PM
  #7372
Z51LS3
Z51LS3's Avatar
yeah do it!
Old 10-18-2018, 04:17 PM
  #7373
HOXXOH
HOXXOH's Avatar
Received 2,061 Likes on 1,505 Posts
Three things to consider.
1. Post as a new thread, since CF won't allow anyone to take over this thread without the current authorized users permission and that hasn't happened for 2 years now.
2. Use the same format and requirements for new entries and updates to your list to keep the results compatible with earlier and current data.
3. Forget DA. Drag Times uses airport data that may be 20+ miles from the track. WU uses data from private residential stations, that according to their locations can easily vary by as much as 600' of DA in as little as a mile. It would be nice if every track had station data transmitted from mid-track sensors and printed on time slips, but I don't see that happening soon.
BTW, you'd also need to go on Google Earth to verify elevation, since DT info is rarely correct and WU's data is where the station is located.
Old 11-08-2018, 11:18 PM
  #7374
Darksun280
7th Gear
Darksun280's Avatar
LS3 Internal modifications Grandsport
1. Your entire profile completed & read Instructions:
2. A copy of your entire time slip posted to the thread as in post # _____
3. The complete the details of your pass using this template in your post:
4. Year Corvette: 2013 Grand sport
5. Type of Trans: M6
6. Type of Suspension: Stock
7. Stock Performance options NPP Exhast
8. Tires utilized: Mickey Thompson ET streets
9. Modifications if any: Cam/ARH/Vararam CAI/ Tuned by Fran @ RPM
10. Dyno numbers if you have them 513whp 473tq
11. 27.5 inch tire. Car was 3305 w/Half tank 93oct, 3585 with me in it.
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track: Atco Raceway NJ
___ Date of the pass & weather conditions 10/29/18 58 degrees cloudy
___ 60'.............1.741
___ 330'........... 4.796
___ 660'...........7.349
___ 660’ mph....97.79
___ 1000'.........9.516
___ 1320'.........11.366
___ 1320’ mph…121.41
Old 02-16-2019, 09:21 PM
  #7375
PRE-Z06
PRE-Z06's Avatar
Received 2,054 Likes on 1,306 Posts
Category: Stock Grand Sport with drag radials
2. A copy of your entire time slip posted to the thread as in post # _____ posted below
4. Year Corvette 2010
5. Type of Trans MZ6
6. Type of Suspension Koni shocks/ZR1 front sway bar
8. Tires utilized Hoosier 315/35r17
9. Modifications: None
10. 400rwhp
11. 20 psi in drag radials on C5Z front wheels, 40 psi in non run flat fronts and 1/4 tank of gasoline
___ Name of the Track Texas Motorplex
___ Date of the pass & weather conditions 2/16/19 cold damp -300 DA
___ 60'.............1.768
___ 330'...........4.998
___ 660'...........7.688
___ 660’ mph....90.92
___ 1000'.......... 9.984
___ 1320'..........11.917
___ 1320’ mph….116.41
Old 02-16-2019, 09:27 PM
  #7376
asd_srt
asd_srt's Avatar
Originally Posted by PRE-Z06
Mods, track details, anything about it?
Old 02-16-2019, 10:25 PM
  #7377
InfernoOrange
InfernoOrange's Avatar
Default Raceway Park Englishtown NJ
About 82 degrees. Totally Stock, best time of day, all controls on.
To C6 1/4 Mile Performance Challenge
Old 02-18-2019, 03:07 PM
  #7378
centennialGS
10. 400rwhp
https://youtu.be/Gyhg6A0ol9o
Wow that was an awesome time. Was the car in Competition mode? I'm assuming you didn't use launch control, just launched it yourself?
Old 02-18-2019, 07:03 PM
  #7379
PRE-Z06
PRE-Z06's Avatar
Thanks! No, I drive with everything off. No, I haven't even tried launch control yet. Prefer to not rely on the computer as I like a challenge and don't want it hiding any input flaws I may make.
centennialGS (02-18-2019)
Old 02-18-2019, 11:41 PM
  #7380
truggiero19
truggiero19's Avatar
You are correct. The factory launch control wont come close to your 1.7 60' mine went 1.9-2.1 with launch control and I've done a best of 1.69 without. I still have work to do.
Quick Reply: C6 1/4 Mile Performance Challenge
