C6 1/4 Mile Performance Challenge
Old Mar 21, 2007 | 03:49 PM
  #1421
dennis50nj's Avatar
dennis50nj
looks like the Mercedes fell apart
Old Mar 21, 2007 | 04:27 PM
  #1422
Pontiaker's Avatar
Pontiaker
Typical sub par German engineering Both women came out of it ok, it was really a hard hit with both of them moving towards eachother.
Iam driving this crappy rental dodge magnum, I want a Vette back!
To try and stay on track with this thread, if they total Iam thinking of a used 06 A6.Sounds like the Vig 2800 converter will be out soon, then headers, Vararam and tune. You think this combo will do better than my 05 A4 at 11.80's?
Old Mar 21, 2007 | 05:00 PM
  #1423
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Maybe I missed it but where did the Z06 times go?
Old Mar 21, 2007 | 05:11 PM
  #1424
LS1LT1's Avatar
LS1LT1
Those were separated out quite a few months ago, there was some unrest and it became a bit of a hassle to manage so those few that were listed were removed.
I think they have their own list in the Z06 section though maybe?
Old Mar 21, 2007 | 05:55 PM
  #1425
dennis50nj's Avatar
dennis50nj
I think it should!! but only time will tell. with the lower gearing it might have traction problems. with the higher stall it might go first to second so fast, that your not going fast enough speed yet, and lose transfer and spin more.
Old Mar 21, 2007 | 06:45 PM
  #1426
Pontiaker's Avatar
Pontiaker
Yeah Iam really tempted to just get another 05 with the tried and true A4, but I will make sure to get the 3:15 gears this time!
Old Mar 22, 2007 | 12:04 AM
  #1427
glennhl's Avatar
glennhl
Sorry to see that a Mercedes took out your Vette. Really glad your wife is OK and it sounds like you have a great attitude. Man, the Vette really won that fight, the Mercedes looks a lot worse.
If you get another Vette, remember the A6 in third gear is equivalent to a 3.92 gear ratio. Get the 2006.
Old Mar 22, 2007 | 12:45 AM
  #1428
Pontiaker's Avatar
Pontiaker
To be honest the A6 I drove felt like crap. I have been racing at the track with several and it seems like they all run low 13's at best. Look at the top fast cars in the external mods list, the fastest A6 is number 10 on the list and its running a 12.15 with no converter.Thats probably what my 2:73 A4 car would run without my converter, actually I got 4/10ths from my vig 2800 but still its right there. Iam just not sold on the A6 right now. Damn if this would have happened a couple years down the road I would be getting a Z but I just cant swing it right now. The Z would solve the problem of wife driving my Vette, she wont drive a stick
Old Mar 22, 2007 | 12:53 AM
  #1429
LS1LT1's Avatar
LS1LT1
Yes, I do.
I like the Vig 2800, it's a great street converter but it still rips at the track.
Old Mar 22, 2007 | 12:56 AM
  #1430
LS1LT1's Avatar
LS1LT1
Give it some more time, we need to see some more well modded, properly tuned A6s first to know for sure whether it's the real deal for going truly fast or not.
Old Mar 22, 2007 | 12:59 AM
  #1431
Pontiaker's Avatar
Pontiaker
Yep your probably right
Old Mar 22, 2007 | 08:06 AM
  #1432
8850's Avatar
8850
The A6 tranny has an awfully tight factory stall. I can only brake stall mine to 1500 rpm. A converter should do wonders to the A6 equipped cars.
They do run better than low 13s. Mine ran a 12.65 with just a tstat. The problem with most guys is idling in the staging lanes. The PCM takes out lots of timing when the IAT get warm.
Old Mar 22, 2007 | 12:03 PM
  #1433
Pontiaker's Avatar
Pontiaker
Thats kind of strange, my car actually runs faster hot, especially if Iam hot lapping it on a slow day at the track.
Old Mar 22, 2007 | 12:13 PM
  #1434
8850's Avatar
8850
If you are hot lapping your IAT is probably cooler than sitting in the staging lanes idling. Or even with the engine off the IAT starts to rise from radiated heat from the engine. Until you get some flow back to the mass air body, as happens when hot lapping, the IAT will be warm. With stock programming timing starts to come out at 86 IAT. By 113 you've taken out 7 degrees.
Old Mar 22, 2007 | 04:09 PM
  #1435
procs2v's Avatar
procs2v
what page is the list on?
Old Mar 22, 2007 | 04:46 PM
  #1436
dennis50nj's Avatar
dennis50nj
page 75 is the most recent
Old Mar 22, 2007 | 10:55 PM
  #1437
LS1LT1's Avatar
LS1LT1
Here it is:
CORVETTEFORUM.COM C6 Corvette ET Rankings
Times are received from all over the country and are not corrected. Because track and weather conditions vary, this list ranking does not, and can not, identify the fastest cars or drivers in any particular order. It only lists the recorded times, regardless of conditions, in order from quickest to slowest. In cases where ET is the same, the higher MPH determines list order.
Showroom Stock
12.21 @ 115.45 - LS1LT1- 06 A6
12.23 @ 115.58 - 06C6FVR - 06 Z51 M6
12.31 @ 114.82 - CYA Vett - 05 F55 M6
12.42 @ 113.90 - DrRichie - 05 Z51 M6
12.42 @ 112.99 - Jlking - 06 A6
12.49 @ 114.90 - Jschindler - 05 Z51 M6
12.53 @ 113.00 - Wicked07C6 - 07 Z51 M6
12.54 @ 113.74 - Tony96LT4 - 06 Z51 A6
12.54 @ 113.24 - NineBall - 05 Z51 M6 - tstat
12.56 @ 113.39 - Red Sleeper -06 A6
12.56 @ 112.00 - Orange C6 - 05 Z51 A4
12.65 @ 111.65 - Zippin Zee - 05 Z51 M6
12.69 @ 112.32 - Silverlx -06 A6
12.70 @ 112.43 - Jelsis - 06 Z51 A6
12.71 @ 111.00 - Demented - 05 Z51 A4
12.72 @ 111.98 - SR0707 - 06 A6
12.74 @ 108.67 - Shooter 49 - 05 A4 3.15
12.75 @ 109.25 - Ponchorello -05 A4 3.15
12.76 @ 112.57 - C5Pilot - 07 Z51 A6
12.79 @ 112.17 - Jchazr - 05 Z51 M6
12.81 @ 112.83 - Vette-oholic - 05 Z51 M6
12.83 @ 109.44 - Tommy D - 05 A4 3.15
12.85 @ 114.53 - Mr Z51 - 06 Z51 M6
12.85 @ 110.00 - Soldsyclone - 06 A6
12.90 @ 114.83 - Normlunt - 05 Z51 M6 - tstat
12.92 @ 112.92 - Prankster - 06 M6
12.93 @ 111.40 - DiggyMoe -07 M6
12.97 @ 109.98 - Joe G - 05 Z51 M6
12.97 @ 108.00 - Ginny C6 - 05 F55 A4
12.98 @ 108.00 - Tampa Vet - 05 A4 3.15
12.99 @ 111.70 - C64ME - 05 Z51 M6
13.04 @ 109.15 - TMyers - 06 A6
13.05 @ 113.31 - RDunn - 06 M6
13.10 @ 108.70 - Rothchilds - 05 F55 A4 3.15
13.12 @ 110.40 - JDWK - 05 Z51 M6
13.25 @ 110.60 - C6 Matt - 05 Z51 M6
13.26 @ 108.59 - Sfadchi - 06 Z51 A6
13.26 @ 105.30 - Joeking - 05 Z51 A4
13.30 @ 107.00 - Shurite44 -06 Z51 A6
13.35 @ 108.10 - Phatpharmd - 06 A6
13.43 @ 105.88 - AngeloC6 - 05 A4/3.15
13.62 @ 106.18 - Rich28 - 05 Z51 A4
External Engine Modifications (Bolt-Ons)
11.62 @ 117.48 - Dennis50NJ - 05 Z51 A4 - CAI, catback, headers, converter, tuning, DR
11.76 @ 117.00 - NastyC6 -05 Z51 A4 - CAI, converter, gears, headers, tune
11.85 @ 117.93 - Joe G - 05 Z51 M6 - CAI, headers, gears, ported intake
11.87 @ 112.99 - Cucchiara - 05 A4 - CAI, catback, headers, converter, tune, DR's
11.94 @ 117.99 - JimSpeed - 06 Z51 M6 - CAI, catback, headers
12.01 @ 116.00 - Mr Z51 - 06 Z51 M6 - CAI, catback, headers, ported intake, tune, DR
12.03 @ 118.50 - Serendipity - 06 M6 - CAI, catback, headers
12.04 @ 114.01 - 06C6FVR - 06 Z51 M6 - Mufflers, tune, DR
12.05 @ 117.02 - CYA Vett - 05 F55 M6 - headers
12.15 @ 116.17 - Joe G - 05 Z51 M6 - CAI, ported intake, DR
12.17 @ 119.00 - RHecox - 06 Z51 A6 - CAI, catback Headers
12.21 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter & DR
12.26 @ 119.40 - Dstage - 06 M6 - CAI, catback, Headers & Intake
12.26 @ 116.65 - Waveblaster785 - 06 Z51 A6 - Catback, headers, Intake
12.37 @ 117.67 - Nicodemus - 05 M6 - CAI, catback, headers, gears, tune
12.37 @ 112.29 - CTVette05 - 05 A4 3.15 - catback, headers
12.41 @ 115.00 - Soldsyclone - 06 A6 - CAI, headers
12.41 @ 115.40 - Icebourg - 05 Z51 M6 - CAI, catback
12.41 @ 114.85 - C5Pilot - 07 Z51 A6 - CAI, DR
12.41 @ 112.07 - WS6JJP - 05 Z51 M6 - catback
12.42 @ 116.12 - YellowVette22 - 05 F55 M6 - CAI, catback, headers, DR
12.43 @ 112.78 - Ponchorello -05 A4 3.15 - CAI, Tune
12.46 @ 113.92 - 8850 - 07 A6 -Stat, Tune
12.48 @ 114.92 - Tony96 LT4 - 06 Z51 A6 - CAI, TB
12.48 @ 113.00 - Demented - 05 Z51 A4 - CAI
12.49 @ 114.43 - Colinsmom -06 A6 Z51 - CAI, catback & headers
12.49 @ 113.50 - 12 Oh - 06 A6 - CAI, catback, headers, tune, DR
12.50 @ 118.00 - Larry Chip - 05 M6 - CAI, catback, tune
12.50 @ 115.20 - Flooznie - 05 A4 - tune
12.50 @ 114.10 - Toptoneone - 06 Z51 M6 - Catback, DR
12.51 @ 113.56 - Jelsis - 06 Z51 A6 - CAI
12.52 @ 114.43 - Glennhl - 06 Z51 A6 - CAI, headers
12.54 @ 113.63 - Anky1631 - 05 M6 - CAI, catback
12.55 @ 115.85 - Yell03 - 06 M6 - CAI, catback
12.55 @ 114.95 - Shurite44 - 06 Z51 A6 - CAI, catback, headers
12.55 @ xxx.xx - FLC6 - 06 A4 3.15 - CAI, catback
12.57 @ 113.04 - Jschindler - 05 F55 M6 - catback
12.57 @ 110.67 - Yell03 - 05 A4 3.15 - catback
12.55 @ 111.98 - 2003Anniversary - 05 Z51 A4 - CAI, catback, headers
12.60 @ 114.00 - SScamaro - 05 Z51 M6 - CAI, catback, headers, tuning
12.63 @ 112.35 - Lusky - 06 Z51 A6 - CAI, 325 tires
12.65 @ 111.39 - Sditch - 05 Z51 A4 - CAI
12.77 @ 110.18 - CMB13 - 05 Z51 M6 - catback, DR
12.78 @ 112.50 - dan-t - 06 A6 - tune
12.80 @ xxx.xx - Thanos - 05 Z51 A4 - catback
12.83 @ 111.00 - TMyers - 06 A6 - CAI, Tune
12.88 @ 112.50 - MickyC6 - 05 M6 - CAI, catback, tune
12.89 @ 112.57 - Bunk22 - 05 Z51 M6 - CAI, catback, headers rockers. tune
12.89 @ 112.00 - Tom400CFI - 05 Z51, M6 - catback
12.93 @ 110.64 - C6Vette -05 Z51 M6 - CAI, catback, tune
12.93 @ 108.60 - 1955 Belair - 05 Z51 A4 - CAI, catback, headers, tune
12.97 @ 111.22 - Zoli007 - 06 Z51 M6 - catback
12.97 @ 109.00 - Tsnipe11 - 05 Z51 A4 - CAI, Headers, Tune
12.99 @ 111.25 - Parkev - 05 Z51 M6 - catback
13.30 @ 110.00 - Chempowr - 05 F55 M6 - CAI, catback
13.32 @ 108.87 - CorvettePilot - 05 Z51 M6 - catback
Internal Engine Modifications
10.76 @ 128.59 - MCV -05 M6 - Callaway 550 package gears, DR
10.87 @ 125.33 - Tek-Newbie - 05 A4 - CAI, catback, converter, H&C, headers, gears, intake, tune, DR
11.50 @ 125.76 - BlownV6 - 06 A6 CAI, catback, headers, H&C, tune, slicks
11.53 @ 124.97 - Boiler RXC6 - 05 F55 M6 - CAI, catback, H&C, headers, intake, tune
11.68 @ 122.42 - RDD41 - 06 A4 - LPE 403 package
11.76 @ 116.76 - 1955 Belair - 05 Z51 A4 - CAI, catback, converter, H&C, headers, intake, tune, DR
11.80 @ 123.50 - Xstang - 05 Z51 M6 - CAI, H&C, headers, gears, tune, DR
11.98 @ 120.87 - Mr Z51 - 06 Z51 M6 - CAI, Cam, gears, headers, ported intake, UD pullies, DR
12.05 @ 119.18 - Evilways -06 Z51 A6 - Cam, headers, tune
12.06 @ 113.56 - Blue Racer - 05 Z51 A4 - catback, converter, H&C, headers, tune
13.12 @ 119.00 - Mitchell242 - 05 M6 - CAI, catback, H&C, headers, intake, tune
Power Adders (supercharger, turbo, nitrous)
9.93 @ 136.88 - Tekhombre - 05 M6 - supercharger, Cartek custom fuel system, H/C, high flow cats, larger radiator, & tune
10.29 @ 138.17 - BlownV6 - 06 A6 - nitrous, CAI, catback, headers, H&C, tune, slicks
10.86 @ 125.30 - JerryMuniz - 05 A4 - nitrous, CAI, catback, headers, gears, converter, tuning, DR
10.89 @ 129.93 - DTE - 05 A4 - Gears, Mufflers,Twin Turbo, DR
11.18 @ 125.42 - Stuart3232 - 06 Z51 M6 - nitrous, CAI, catback, DR
11.21 @ 127.82 - Schilitj - 05 Z51 M6 - Supercharger, Cat back, Headers, Heads & Cam, Cat back
11.37 @ 126.64 - Nine Ball - 05 Z51 M6 - magnacharger, cam, headers, catback, tuning, DR
11.58 @ 122.78 - MCV - 06 A6 - Magnacharger, Cai, catback, tune DR
11.89 @ 120.20 - FLC6 - 05 A4 3.15 - nitrous, CAI, catback
1/8 mile (All entries)
8.35 @ 90.72 - Bunk22 - 05 Z51 M6 - Cai catback, headers, ported intake, rockers & tune
To C6 1/4 Mile Performance Challenge
Old Mar 23, 2007 | 07:25 AM
  #1438
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Absolutely true. I verifed it with HP Tuners. My buddy's C6 Z06 with cai had 152 air in the staging lanes, my Vararammed C6 had 93. Ambient was 84. By 80 mph he was 94, by 100 I was ambient.
Just look how much timing is pulled with a stock tune. That is why, IMHO, the vararam is so effective.
Old Mar 23, 2007 | 03:47 PM
  #1439
Evilways's Avatar
Evilways
Man...posting that list makes me want to head to the track, I know i can't get the first two slots on internal mod list, but I want #3......I think I can with stickier tires....I'll at least climb a little next time down the track
Old Mar 23, 2007 | 05:14 PM
  #1440
k0bun's Avatar
k0bun
I didn't see the times for the Z06s in their section. Are they completely gone?
