nitrous isn't spraying
Old Dec 22, 2007 | 10:34 AM
michelin man's Avatar
michelin man
Default nitrous isn't spraying
123
Old Dec 22, 2007 | 10:42 AM
dennis50nj's Avatar
dennis50nj
to much bottle pressure solenoid stuck
Old Dec 22, 2007 | 10:59 AM
michelin man
suggestions on reducing pressure?
Old Dec 22, 2007 | 11:05 AM
dennis50nj's Avatar
dennis50nj
open line crack open valve to reduce pressure, then hook back up turn nitrous heater off keep out of hot car sunlight get bottle blanket
Old Dec 22, 2007 | 01:09 PM
michelin man
well, i'll be...
car is stupid fun on the bottle!
thank you
Old Dec 22, 2007 | 02:48 PM
dennis50nj's Avatar
dennis50nj
well, i'll be...
thank you
you ought to see how much fun it is at 1350 lbs of bottle pressure better noids are available
Old Dec 22, 2007 | 05:40 PM
SpinMonster's Avatar
SpinMonster
I hope you tuned this set-up. You would have seen a rich or lean condition as the reason for the stumble.
Old Dec 22, 2007 | 06:00 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Michelin,
It looks like the coupler to the vararam in the picture is off, didn`t know if you noticed that. Oops, just seen the little print under the photo
Old Dec 22, 2007 | 08:00 PM
michelin man
car was tuned before i purchased it.
smoked my neighbors srt-10 truck a few times today.
Old Dec 22, 2007 | 11:57 PM
SpinMonster
You have to tune it with the spray so you know what is going on during the shot. Cars cant run the same tune with a big shot. Timing should be pulled, it should run richer (tuned with the fuel jet size in your case) and its a good idea to run a heat range colder on the plugs.
If you had a tune with 13:1 a/f ratio with an aggressive high octane timing table, you are not in a good position for a 100+ shot.
To nitrous isn't spraying
