ls9 Supercharger
Old Dec 24, 2007 | 04:58 PM
c6dreamvette's Avatar
c6dreamvette
Default ls9 Supercharger
Does any one know when this will be able for us to purchase and will it mount up to the l92 heads
Old Dec 24, 2007 | 05:13 PM
timd38's Avatar
timd38
Based on what I have read, it appears that it will bolt on, but you don't have the bigger headbolts and other items that are required to make the thing live for more than a couple of hundred miles.
Old Dec 24, 2007 | 05:24 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Not to mention the accessories are all mounted differently.
San
Old Dec 24, 2007 | 09:38 PM
tjwong's Avatar
tjwong
You will have to buy the whole front end accessories, including the crank hub which is keyed the the LS9 crank. Or you can have a aftermarket ATI pulley made for driving the blower. Its not going to be cheap to do but is possible.
Old Dec 24, 2007 | 10:59 PM
BLUZ's Avatar
BLUZ
Default cost on LS9 s/c
It may be costly but a heck of a lot cheaper than the 100 grand plus for the ZR1. For that matter, a crate LS9 motor will be cheap as opposed to the ZR1
Old Dec 24, 2007 | 11:28 PM
Maui's Avatar
Maui
St. Jude Donor '08
I would expect the LS9 crate with blower to come in around 30k. Not a whole lot different than the original ZR-1.
Old Dec 25, 2007 | 01:21 AM
tjwong's Avatar
tjwong
I bet it will be lower than that, I am thinking around $20 maybe a bit more. Do you want me to get one for you
Old Dec 25, 2007 | 06:48 AM
timd38's Avatar
timd38
And it is not built by a boat manufacturer!
Old Dec 25, 2007 | 11:32 AM
08 Vett's Avatar
08 Vett
It will be coming out soon. I don't know when, but it will be a direct bolt on to the LS3 engine. I'd say changing pistons & head bolts would be a good idea. I guessing it would be real hard on head gaskets. My 2 cents.
Old Dec 25, 2007 | 12:05 PM
tjwong's Avatar
tjwong
Ten PSI of boost is going to be hard on headgaskets. That is why GM upsized the head bolts. I would think using studs and MLS gaskets would be just as good as upsizing the bolts 1mm. Swapping to forged pistons would be a good idea on any blown application. Then you can drop the CR down to 9:1 as it is now your LS2 or LS3 engine is nearly 11:1 and at 10 PSI that is going to be way to high for that compression.
Old Dec 25, 2007 | 03:32 PM
08 Vett's Avatar
08 Vett
Who said anything about 10 psi? Where did 10 psi com from?
I'm confused!
Old Dec 25, 2007 | 06:04 PM
c6dreamvette
Are the l92 heads and ls3 heads the same the reason i ask is because i am going with l92's on my ls2 and i want to know if the supercharger will mount up to my engine
Old Dec 25, 2007 | 06:47 PM
timd38's Avatar
timd38
I believe the heads will match up. Don't take this personal, but you are very naive if you think the major issue is matching up to the blower to the heads. If you want to get the 620HP you will need to beef up the bottom end and relocate all of the accessories, and put in bigger head bolts to take the pressure, dry sump oil system, etc. All can be done, but then you need a diff upgrade and brake upgrade, etc...
Let us know how it works out.
Old Dec 26, 2007 | 02:46 PM
c6dreamvette
Yes i know it would take alot more than just mounting up to the heads but as long as that can be dune i think the rest would just fall into place and as far as longer head bolts how hard can that be my car is a z51 so i dont think stoping will be a problem but yes you are probably right about the diff i dont think the a4 will hold up
ps if are when i do the project ill let yall know
Old Dec 26, 2007 | 03:47 PM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
After reading all the changes to the ls3 theydid to make the ls9, a crate ls9 sounds like a lot better idea. But I don't think you'll get one for $20k.
GM
Old Dec 26, 2007 | 03:50 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Let us know how you come out, and how well your A4 transmission holds up under the new power.
Old Jan 3, 2008 | 12:56 AM
C6LSx's Avatar
C6LSx
St. Jude Donor '08
For my money and warranty peace of mind; I would wait for Magnuson Products to release a new positive displacement Maggie SC for the 08 LS3 engine platform.
The Maggies are tried and true and usually good for an additional 130 more HP on a stock motor; they are plug and play vehicle specific applications and they offer a 3 year/36000 mile power train warranty.
LT Headers and a Maggie on an LS3 engine with a hot tune should easily put you at 650+ BHP.
Old Jan 3, 2008 | 12:47 PM
TurboLuigi's Avatar
TurboLuigi
That is right on the money with what Callaway is specifying with the Callaway/Magnusen SuperCharger on the LS3/2008 C16. With a Callaway install on a new car they match the 5 Yr/100K GM power train warranty.
-Luigi
To ls9 Supercharger
