Weight reduction
Old Dec 28, 2007 | 06:32 PM
ZO6 Fan's Avatar
ZO6 Fan
Default Weight reduction
Lookin to reduce weight in my 07 MN6 C6 -I know an aluminum flywheel will work, I've already swapped out my 19 x 10s out back w Lighter 17x9s w/ Drag Radials (reduced rotating mass). I was looking for a recent thread on here about Brembo 6 piston caliper brakes being lighter than the OEM 6 piston brakes for the ZO6. I'd like to know where that 411 was obtained since the Big brake kit will be a future upgrade for me. Any other suggestions will be cool-Thanks P.S. Not looking to strip out the interior
Old Dec 28, 2007 | 06:39 PM
VET4LES's Avatar
VET4LES
One member removed his window washer tank and pump. He claimed around 15 or 20 pounds.
Old Dec 28, 2007 | 07:02 PM
Silverton's Avatar
Silverton
Replace power seats with race seats (the Recaro Pole Position seats are quite easy to get in and out of) and save 20-25 lbs per seat. Install LG Pro headers and save maybe 30 lbs. Upgrading the brakes with 2-piece rotors might save 5 lbs per wheel, or 20 lbs total. The total weight savings might be as much as 100 lbs!
Old Dec 30, 2007 | 10:56 PM
ZO6 Fan's Avatar
ZO6 Fan
Thanks Any other ideas out there?
Old Dec 30, 2007 | 11:02 PM
ZO6 Fan's Avatar
ZO6 Fan
I know the ZO6 Widebody conversion kit w/ the carbon fiber fenders will shave some weight I'm hoping GM will offer the ZR1 Body kit w/ the light weight rear window
Old Dec 30, 2007 | 11:06 PM
805Z06's Avatar
805Z06
24 Hour Fitness
Old Dec 31, 2007 | 11:35 AM
carpe dm's Avatar
carpe dm
Originally Posted by 805Z06
24 Hour Fitness
One of the best, but also one of the hardest to achieve!
Old Dec 31, 2007 | 11:40 AM
TurboLuigi's Avatar
TurboLuigi
That is why Callaway offers the Dymag Carbon Fiber/Magnesium wheel as an option for C6 Corvettes and standard on their C16 Corvette. The outer shell is made of carbon fiber and the center spokes are made of magnesium and attached to the rim with titanium hardware. A 20 x 12 wheel weights about 16 lbs. You can easily lift it with one hand.
This wheel alone easily removes 20-30 lbs of weight from each corner of the car depending on what the car originally wore.
-Luigi
Old Dec 31, 2007 | 11:41 AM
timd38's Avatar
timd38
Group 51 Optima in the trunk. It has a vent tube port so you don't have to worry about fumes getting into the passenger compartment. If you need the vent port elbow, just send me a PM and I will sent you next week when I go back to work.
Old Dec 31, 2007 | 12:51 PM
dennis50nj's Avatar
dennis50nj
by the time you add number 1 or 2 cable to the back, you dont save any weight. just better transfer
Old Dec 31, 2007 | 04:00 PM
timd38's Avatar
timd38
Very true, I think the Z06 has almost 20 pounds of cable, but a group 51 under the hood will save you weight. You will just need a longer puck to hold it down.
Old Dec 31, 2007 | 04:31 PM
dennis50nj's Avatar
dennis50nj
i think their was a guy on here that put a real small like 16lbs battery and its fine. xstang i think was his name
Old Jan 1, 2008 | 10:04 AM
ZO6 Fan's Avatar
ZO6 Fan
-Luigi
Wow -Those are cool-what do they run $$ ??
Old Jan 1, 2008 | 10:36 AM
bowmanized's Avatar
bowmanized
Wheels/Tires 40lbs
Battery 35lbs
Seats 25-45lbs
Brakes 20+
Headers 30lbs
Old Jan 1, 2008 | 10:38 AM
bowmanized's Avatar
bowmanized
Reducing unsprung weight like the wheels tires and brakes are going to have a more dramatic effect from a performance perspective because it's unsprung weight.
Old Jan 2, 2008 | 02:50 AM
satans csex's Avatar
satans csex
I removed a lot of metal from the bottom of my car, yet again im crazy like that hahahahaha......when i take it to the tracks i even take out my battery and throw in a 12 volt motor cycle battery in there........ i take out the passenger seats, all of the plastic covers on the motor, radio
glove compartment, mufflers, seat belts and a whole bunch of plastic from the inside of the car, basically everything i can that will allow the car to work properly, and when i get back home im too lazy to put it back onill drive my car for a week get sick of the way it looks and rebuild it myself, i can guarantee almost a full second of time i gain from the weight i lose
Old Jan 2, 2008 | 03:12 AM
ZO6 Fan's Avatar
ZO6 Fan
Jeez! Don't think I want to strip out the interior like that. hey you know I read these C6 Can be driven on the chassis w/o the bodies, maybe u should try that -u can shed a few hundred pounds! lolol!
To Weight reduction
Old Jan 2, 2008 | 03:20 AM
LS1LT1's Avatar
LS1LT1
True
Old Jan 2, 2008 | 12:42 PM
C6V3tt3's Avatar
C6V3tt3
dont forget the tire valve caps. lol
Old Jan 2, 2008 | 02:42 PM
BRIANSC6's Avatar
BRIANSC6
I have heard some members talk about significat weight savings before going to the track by the ingestion of exlax the night before.
Though I have heard the same members talk about accidents at the track the following day.
