HID Install **HELP**
Old Dec 29, 2007 | 05:15 PM
mnf8688's Avatar
mnf8688
Default HID Install **HELP**
I just bought new HIDs for my headlights in my 2007 C6 coupe and need help changing the stock 4300K bulbs to the new 8000K bulbs... the only problem is that im not too sure of even where to begin!
Can someone help guide me in the right direction of changing the bulbs with some instructions and even if im lucky, with some pictures?
Thanks!!
Old Dec 29, 2007 | 05:39 PM
tjl5709's Avatar
tjl5709
There is an access cover inside the front wheel well, in front of the tire. It is held inplace with pins that you pull. Removing the tire makes it easier. Once you pull the access cover, you will gain access to the light assembly. I beleive the low beams are the middle light. There is another rubber cover over LB light hook up. Once you remove that, you will see the igniter that is attached to the rear of the bulb. You will need a torx driver to remove the 2 screws that hold the ignitor to the bulb. Remove screws, remove the bulb clip, and pull out the bulb. Replace with your new bulb. Reverse the procedure.
Do not touch the bulbs with bare hands. If you did, wipe with alcohol to remove oils.
Old Dec 29, 2007 | 06:11 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
You know you're decreasing your light output, right?
Old Dec 29, 2007 | 06:46 PM
mnf8688's Avatar
mnf8688
i have everything done right now but i dont know what size torx driver it is... everything i try doesnt seem to fit!
Old Dec 29, 2007 | 07:10 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Check it out:
Old Dec 29, 2007 | 09:50 PM
mnf8688's Avatar
mnf8688
8000k might not be the brightest light output but it damn sure looks the best!!!
Old Dec 29, 2007 | 10:14 PM
calemasters's Avatar
calemasters
Thanks!!
8000K is way too far in to the ultra violet spectrum for automotive lighting. 8000K might be good for growing some wacky weed. I would not go over 6000K for HID automotive lighting.
Old Dec 29, 2007 | 11:47 PM
GotVett?'s Avatar
GotVett?
Originally Posted by calemasters
. . . 8000K might be good for growing some wacky weed . . .
Old Dec 29, 2007 | 11:51 PM
HeadPapago's Avatar
HeadPapago
Old Dec 30, 2007 | 09:58 AM
LLWS's Avatar
LLWS
8000K = Almost Purple IMHO.
To HID Install **HELP**
