No long tube headers are EPA legal for the C6. It violates EPA regulations to move the Cats from the OEM location or to replace the OEM cats with other than OEM unless the OEM is defective. Used to be, all that it took to pass smog test was to get the right numbers on the sniffer. Now (in most places anyway - including NOVA) smog testing is done via the OBDCII connection, a Gas Cap pressure test and - importantly - a visual. If the tech is up to his task, you WILL fail with headers.
Reportedly, Callaway was trying to get shorty headers that used the OEM cats in OEM location CARB approved but from what I hear, they discontinued from lack of sales interest.
I assume then most who install headers take their car to private garages to state inspection?
In New York you have to pass the sniffer . They will pass the sniffer with high flow catts, just tell your tuner that you are concerned about passing emissions and it shouldn`t be a problem. Now as far as the visual inspection goes....Well just find the right shop.
I know its not apples vs. apples but the car I sold to get this Vette was a 2003 Mustang Cobra and it had the OBD2 connection.
I had that bastard so modified it was hilarious. Kenne Bell 2.8L High Output Twin Screw Supercharger, 60# Injectors, Bassani X-Pipe with NO cats, Magnaflow Exhaust, and a tune from Bob Kurgan that put almost 600HP to the back tires.
I passed the EPA test in Crystal Lake, IL with flying colors.
Laughed my *** off.
Probably will look at something different with a 08 Vette I am not sure. I just know all he did was plug the connection under the dash for a few minutes and I was good to go. No lifting of the hood or mirrors under the car for me.
Good luck in your state though they are all probably a little different on how strict they are.
One other note: The OP question was are headers considered legal, not what can you get away with. I'll bet 80% of the time you can get away with headers...
What are the options to remove the stock manifolds...to upgrade performance, all while keeping the car street legal for state inspection?
This was posted recently on LS1Tech:
Over the Christmas holiday I installed a 2007 C6 Z06 exhaust system (manifolds, Cats, H pipe) plus Corsa Z06 3 inch Sports on my 2006 C6 A6. I did a pre and post dyno run on a Dynojet 248 for comparasion. The car was tuned (A/R ratio, timing, etc) to the same level for each dyno pull. Pre Z06 exhasut was 343 rwhp and post was 373 rwhp. There are a bunch of Z06 guys putting headers on the Vettes. The shop I use had 4 pairs just collecting dust. However, the Z06 guys tend to keep their NPP mufflers, but Corsa, B&B and Borla all make 3 inch Z06 mufflers. The installation was not difficult. I bought GM LS7 manifold gaskets and some O2 sensor wire extensions for the forward O2 sensors. The clearance around the A6 transmission is tighter than I want, so I will get some minor exhaust pipe work. Manual transmission C6's should be no problem at all. Bottom line. I think this is a good 30 hp mod for C6 Vettes if you can get your hands on a discarded Z06 exhaust system.
There is a very high probability that this would pass visual inspection since it is a stock manifold albeit from the Z06. The gains are very close to those reported for headers.
That is very good information, thanks for the heads up. I only had 386/378 with headers and ported intake through 3.90 gears in a MZ6, so those figures in an automatic are as you noted right on par with headers.
I noticed in the Corvette Factory show on Discovery the other day, the LS7 builder made a special point to state how complex and expensive those welded Z06 manifolds are.
Z06 Exhaust system end to end is what I am using on my build LS3.
Over the Christmas holiday I installed a 2007 C6 Z06 exhaust system (manifolds, Cats, H pipe) plus Corsa Z06 3 inch Sports on my 2006 C6 A6. I did a pre and post dyno run on a Dynojet 248 for comparasion. The car was tuned (A/R ratio, timing, etc) to the same level for each dyno pull. Pre Z06 exhasut was 343 rwhp and post was 373 rwhp. There are a bunch of Z06 guys putting headers on the Vettes. ..................Bottom line. I think this is a good 30 hp mod for C6 Vettes if you can get your hands on a discarded Z06 exhaust system.
Wow !! That's an interesting concept! 30 HP and it would pass a visual inspection. No way would a smog tech know the difference. This could be promising.
You will not pass the visual in The People's Republic of Kalifornia. Therefore, it is illegal in California.
Maybe I was just lucky...but I had LT headers on my old C5 for 5+ years and it passed inspection every time. I was nervious the first time...but there were no issues.
Charley
Yes you were lucky. I put headers on my motorhome and have been ask a couple of times for the CARB approval sticker. I had it stuck to the air cleaner. Most of the time they don't know what their looking at.
This is the sticker for the K&N air charger on my C6.
Is the key word here 'defective'?? Would a screw driver accidentally though a Cat cause it to be defective? Therefore . . . .
