Does CAI and Cat-Back require a tune?
http://www.gmhightechperformance.com...sts/index.html
Do they mean you need a tune to get the full benefit or are they saying making these changes causes the timing to get pulled and you actually may loose power?
This is the part I'm talking about:
Dan points out that that is important because the factory spark tables are based on airflow. As such, the stock computer tends to pull timing (stock GM timing for this engine runs right at 28 to 29 degrees) when it senses an increase in intake air or decreased backpressure with a better exhaust. (This also tells us that bolt-on exhaust and cold-air kits will need a companion tune to maximize horsepower.) Because of this, Dan estimates another 10 to 15 hp could be left on the table with the stock LS2 because there was timing getting pulled during our test runs
However, this means the PCM is at or near its limit of corrective capabilities. Ideally you want re-tune tune to again put the PCM in the middle of its range of corrective capabilities. Doing this is where the 10-15 extra horsepower comes from.
Not totally sure if this will help at all but here's my experience. I have an '07 A6 that I had one shop put on Corsa cat backs, Kooks headers and Kooks hi-flo cats. Was told to expect the engine light to come on but I could drive it till I got it tuned and it would not hurt anything. Had already discussed this with my tuner. Brought to the 2nd shop (tuner) about 3 days later for the tune and all I can say is that SOTP speed and performance went WAY up. It was more responsive and had a hell of a lot more power.
From what I hear on the forum about stock dyno #'s being around 337RWHP, I gained 30 RWHP. Not sure if that's good, great or so-so, but it was way better than stock. And more fun!! Hope this helps a little. Good luck!
Fran
I'm interested to hear what some of the experienced guys have to say about this one.. It's always been said, despite what the mfg lit says, that you won't gain much from just exhaust (maybe a couple rwhp)..but LOSING power?!! Not gaining much..fine..Losing power? Don't want to do that!!
pkstr
pkstr
CAI can change things, but not a lot unless you pull your maf screen out (I don't recomend that). Don't really need a tune for a CAI.
Headers are ok without a tune but you'll get a MIL for P0420 and P0430 most likely, cat inefficiency code. Really should get a tune if you get headers or you're missing a lot of the potential gain.
A tune is an excellent mod even if you are stock. CAI and a tune will be worth .4 and 3 mph in the 1/4 most likely. They make a big difference and I highly recommend a tune.
Here's some great reading for you.
http://forums.corvetteforum.com/show....php?t=1900057
if basicmods (exhaust, air filter, intake) are made and it is tested immediately, yes, a loss can be noted. it takes at least 50 miles of continuous use before the pcm will begin to detect the changes and make adjustments.
even though the computer is able to compensate for some modifications does not mean that more power cannot be obtained with a proper tune.
a good tune will always result in more power, even if it hasn't been modded.
I note you are using C5Z06 TI's - they are pretty restrictive on stock cubes and must be a real bottleneck on that ride of yours. I noted a solid .05 gain on the track going from TI's to my Stingers on my H/C C5.
The dyno sheet below is a buddy's C5Z with a G5x2, no other mods.
The dyno sheet shows through the Z06 TI mufflers and with his QTP cutouts open. Almost 10 rwhp/tq gain across the board with the cutouts open.
