Is it necessary to install high flow cats with long tube headers? What would be the difference with the cats installed and not installed if it is not necessary.
Happy New Year to all
You can, of course go without, but it is a federal felony. Probably wouldn't get caught, depending where you live........
Installing the high flow cats with the headers is no big deal.
They:
1. don't create any real significant loss of horsepower (maybe 5 hp or less).
2. allow you to pass emissions testing.
3. allow you to run without switching off or tuning out the O2 warning sensors, and
4. help in minimize nasty emissions smells that can be sucked into the cabin while cruising.
Guys,
I had LT Kooks and the Hi-Flo cats installed on my '07 A6 and honestly I have not had, nor any of my family ever smelled anything at all. If I did not see them installed I would not know they are there....EXCEPT that I also had the Corsa Sport cat back exhaust installed as well at the same time and MAN, it sounds luverly. LOL
I am aware that they can indeed increase emissions, but it is my hope that the tuner can do some magic before the test. I had to do the same thing years ago with my '69 Hemi Charger (before the laws changed) and had to IMMEDIATELY change back to a more streetable tune. But seriuosly with about 2500 Summer and Fall miles since that work and NO smell whatsoever. Honest INJUN!
Fran
They:
#2 and #3 isnt correct..
Hi flow cats are 2-way cats and you will not pass smog, will fail the NOx sniff test. With high flow cats your 02 sensors will pick it up and WILL trigger the Check Engine Lights, not right away but eventually it will.
I know people with high flow cats that passed the sniff test. I passed it with a 406 carburated small block with headers and NO cats.
Let me know when mine will trigger the CEL. I have had high flow cats on both of my vettes with a running total of 7 years and did all my own tuning and have never bypassed a single code ever. No CEL. Every car I tune with them has the codes intact too...no CEL.
My 2001 had them and passed the sniffer. NY now has no sniffer and its just a PCM ready test. With all codes intact, I passed.
The power difference as per LG for their HF cats is 3hp and 9rwtq.
I have had my Kooks and High flow cats with over 3000 miles and no lights have ever came on. Your tuner can take care of all of those issues the first time you have it tuned.
I had CEL about 20 miles after I had my Kooks, Hi-flo cats and Corsa cat back installed. I was told to expect it and that it would not harm anything. After my tune, (a couple of days later) including TM turn off I have gone 2500 or so miles and I have not gotten any CEL yet.
Fran
Fran
The CEL would be from it not being tuned. They lean out the car too much in closed loop.
Im talking about the CEL being on when your car isnt tuned. Also here in CA, when your car is being smogged, your cars OBD port is connected to the smog machine and will detect any pending code. Now, I dont know how strict NY sniffer test is, but here in CA, I doubt it if you can pass the sniff test with high flow cats
I keep reiterating the reason for the CEL not for you but for the readers that skip though threads without seeing what was stated before. Some think even tuned, the CEL would appear and that is not true. Many tuners just turn off the CEL code for the rear cats instead of tuning it properly to have the codes intact in case of a real cat issue.
So for the benefit of those not reading through and not to annoy you: a properly tuned car should have no codes bypassed and there will be no check engine lights even with high flow cats.
In NY the inspection is also connected to the OBDII port and the car with all codes intact with high flow cats will have no codes pending (actually called 'immature' in the scans) with any properly tuned cat, high flow or other. A as per my friends in the republic of Khali-phor-Nia, who share my love of DIY tuning (yes you Alex and Steve), their cars pass the sniffer but fail the visual inspection, but eyesight is usually not so good in the presence of dead presdients. I have tuned enough cars here with H/C and good sized cams to know it can be done. My car is a prime example. I dont even know if my CEL light bulb works. Just kidding of course since it turns on when you start the car as a test.
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
No tune, No Codes. (Doesn't mean she wouldn't benefit from a tune though)
...can't imagine a situation where cats aren't necessary - required by law. Like others have stated, I've been running by Kooks w/hfc for 3-years and absolutely no problems - no emissions issues, etc.
