Need differential plug thread size
Old Jan 2, 2008 | 10:10 PM
J.Yo's Avatar
J.Yo
Default Need differential plug thread size
Does anyone out there know the thread size for the two plugs in the differential case (the drain and the fill plugs)? I think they're the same size, but I don't know for sure.
I took a look at a picture of the plugs next to a quarter (posted by another forum member) and it looks like a M18X1.5, but I need to be sure. If anyone knows, it would help me out a lot, in that I won't need to yank out the plugs just to measure them. I need to know the thread spec for a differential cooler that I'm working on.
Thanks in advance.
Old Jan 3, 2008 | 12:00 AM
Vet's Avatar
Vet
Howdy... the drain and fill plugs ARE the same exact size... same exact plugs... interchangeable... at least on my `06 Z51 coupe. Unfortunately I had neglected to measure the thread size when I had the plugs out. I'm sure another forum member has this info for you.
Old Jan 3, 2008 | 12:12 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
The diff has M20 x 1.5 threads. I needed to find a 1/8 npt adaptor to M20 x 1.5 for my diff temp gauge. I ended up buying a magnetic diff drain plug from Ecklers and drilling it out and tapping it.
Here's some more info on diff coolers. My diff runs hot - it can get close to 280 on track before I shut down. Wish the Z51 had a diff cooler like the Z06. My Z51 trans cooler works well, runs 200-220.
http://forums.corvetteforum.com/show...ial+temp+gauge
Old Jan 3, 2008 | 01:16 AM
ZO6 Fan's Avatar
ZO6 Fan
Hey Joe G -left you a PM
Old Jan 3, 2008 | 11:36 PM
J.Yo's Avatar
J.Yo
Awesome! This is exactly the information that I needed. You guys are the best.
Old Feb 9, 2013 | 08:45 AM
gorilla1969's Avatar
gorilla1969
Default Need Plug Details / Specifics
Looking for a part number or detailed specs for the rear differential fill/drain plugs used on both the C5 and C6 vettes. Zip corvette sells them (see link below) but gives very little tech info (thread size, OEM pn, etc). I know it uses a 10mm hex.
My '05 has a stripped head on one (courtesy of the last repair shop) which I need to replace. I'd like to see if I can find one at a local auto parts store.
Any info would be appreciated. General web searches have proved of no help.
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid={653c4373-1bcd-4ca6-b878-eea1c0d79e42}&gid={585d2a1e-1a41-4a55-a829-1f1e289a686b}&GroupName=C6+Differential+ Components&pname=97-13+Differential+Plug&Referer=&Alias=&ptc t=SGR-SR&CTitle=&
Old Feb 9, 2013 | 08:50 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
See my post above. I could not find the m20 x 1.5 bolts anywhere. I had to buy a magnetic plug from Zip or Ecklers.
Old Feb 9, 2013 | 03:07 PM
JCtx's Avatar
JCtx
If you're going to put an OEM cooler, my GS dry-sump does not have a drain bolt. It's a special fitting where the oil cooler line goes in. You drain the oil by pulling a 'C' clip then pulling the line out. I'm almost sure the fill plug was larger than those posted, and it required a T-55 Torx socket, rather than being hex, like the pictured ones. Once you buy the plugs, put them thread vs thread and you'll know if it's the same pitch depending how they fit against each other. Good luck.
Old Feb 10, 2013 | 06:19 AM
gorilla1969
Thanks all.
Does anybody know a a good tool to remove this type of stripped screw?
I'd need something that works with very tight screws (as many know, this screw is very stubborn, even with a perfect hex feature). I'm tempted to just take it to a shop and let them deal with it but, at the same token, like doing things myself and don't like paying for something I could do myself.
Thoughts? Thanks again.
Old Feb 10, 2013 | 08:29 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Thanks all.
Since there is a crown on the plug, I have used a pair of pliers to loosen mine (in my setup with a c5 rear, you can't get to the hex socket, the leaf spring is in the way).
My suggestions are standard for removing stripped bolts. You might try a pair of good vice grips. Or, an easy out that fits would be another choice - don't drill the plug, just find an easy out that will get a bite in the existing plug. You could also try hammering in a allen that is a little too big. If you happen to have an impact screwdriver with replaceable tips, you could use the slightly too big allen tip - the hammer/twist combined action of the tool often gets the job done.
To Need differential plug thread size
