Down shift to fast and car accelerates
Old Jan 5, 2008 | 05:08 PM
C6Coupe's Avatar
C6Coupe
Default Down shift to fast and car accelerates
I have noticed that when I down shift a little two aggressively and cause the engine drag light to come on that the car will accelerate hard for a split second. I'm sure it has to do with the tune that was done and was wondering if anyone knows where to start looking.
Other then that the car runs like an animal
I forgot to mention that its an M6
Old Jan 5, 2008 | 05:19 PM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
a4 a6 or m6 ?
Old Jan 5, 2008 | 07:10 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
too fast. Sorry to be a grammar ****. Carry on.
Old Jan 5, 2008 | 07:37 PM
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by C6Coupe
I have noticed that when I down shift a little two aggressively and cause the engine drag light to come on that the car will accelerate hard for a split second I'm sure it has to do with the tune that was done and was wondering if anyone knows where to start looking. Other then that the car runs like an anamal
You need to blip the throttle a bit before the down shift to match the revs. Your engine rpm is too low when you get to the lower gear.
Old Jan 5, 2008 | 09:20 PM
C6Coupe's Avatar
C6Coupe
You **** anamal, thats a capital N in ****
Old Jan 5, 2008 | 09:47 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Or 2 fast.
Old Jan 5, 2008 | 09:49 PM
BAADC6's Avatar
BAADC6
It has happened to me when downshifting a little too quickly and not blipping the throttle.
Old Jan 5, 2008 | 10:25 PM
C6Coupe's Avatar
C6Coupe
Thanks Guys, funny that I never had this problem before
Old Jan 5, 2008 | 10:59 PM
robvuk's Avatar
robvuk
You don't even have to blip the throttle. You're probably just shifting too early or at least a lot earlier than necessary. It won't do it if you don't try to down shift to a lower gear while still going too fast. Stay in the higher gear and let the drivetrain drag slow you down, then shift down just before you need to accelerate. It's a much better habit for roadracing too even if you know how to heel-toe shift.
Old Jan 5, 2008 | 11:10 PM
robvuk's Avatar
robvuk
Furthermore, it's easier on your synchros and much less dangerous to your engine.
Old Jan 6, 2008 | 11:48 AM
yfzmotox21's Avatar
yfzmotox21
mine pretty much wont downshift inless the rpms are close to being matched. is this a problem?
Old Jan 6, 2008 | 12:02 PM
johnodrake's Avatar
johnodrake
Moderator
With a 6 speed - May be. I can downshift mine whenever I want to - you CAN overrev if you aren't careful/don't know what you are doing. Computer will protect you from overrev going up but not down.
Old Jan 6, 2008 | 12:29 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Someone here is confused...either the poster for saying the CAR accelerates after a downshift (assuming no addition accelerator depression), or others for thinking the engine speed is mismatched. Or, maybe I'm confused because I don't understand how any of this ties together.
A. If the CAR is accelerating after a downshift, and you're not depressing the acclerator, then you may have a problem (poltergeists?). To my knowledge, factory MN6 cars have no way to control engine overspeed (kaboom!) due to shifting into too low a gear...maybe your tune did add a new dimension here, and it's danged complicated.
B. If the ENGINE is accelerating to higher rpm without additional accelerator input after downshifting, then that's what happens when you shift a manual transmission into a lower gear...happens every time. If you shift with mismatched RPM, you will get a distinct SLOWING lurch until the engine is brought back up to speed...the engine goes to idle during the shift unless you're holding the accelerator positon.
Old Jan 6, 2008 | 12:44 PM
thomas walters's Avatar
thomas walters
This has happened to me as well. Scenario: RPMs in the 3,500 range in 3rd gear, foot off the gas pedal and decelerating, then a downshift to 2nd (even with a rev between gears), and the car accelerates for a fraction of a second (maybe 1/2 of a second). It was unsettling the first time this happened to me. Talked to my tuner about it, and he is dumbfounded. Love to hear about any causes/solutions if anyone has figured this one out.
Old Jan 6, 2008 | 01:05 PM
robvuk's Avatar
robvuk
Since Corvettes have throttle by wire, they are able to do lots of amazing things not possible before. When you down shift too early, the engine creates excessive drag on the rear wheels. Depending on how badly, this could be a dangerous situation in slippery conditions. The computer senses tire slip, just like traction control, and boosts the throttle to the engine just enough to put traction back in all 4 wheels. Normally this gives a message in the DIC that it has done so.
Down shifting to second from 3500 to 4000 rpm in third and letting the clutch out suddenly can easily cause rear tire slippage and very high engine revs. This system just helps keep these kinds of mistakes from being dangerous. It of course will not help if you down shift from 5,000 causing a physical over rev condition which could mechanically damage the engine. There's no safety net for idiotic.
Old Jan 6, 2008 | 01:33 PM
Brett Hunter's Avatar
Brett Hunter
My guess is your TM settings are too high. I have enclosed a quote from a SAE paper on how the engine drag control system works.
Originally Posted by Enhanced Vehicle Stability with
Engine Drag Control
Keith Beyer, Eric Krueger and Mark Sonnenberg
Delphi Automotive Systems
Torque Subtraction Term - In addition, there is a torque
subtraction term applied to the PID result. This is an
additional safety measure that slowly decays the engine
torque to ensure that EDC control exits after a certain
period of time
Old Jan 6, 2008 | 01:44 PM
Brett Hunter
The C6 is equipped with "Engine Drag Control". EDC will increase the TP to prevent rear wheel spin if the engine drag is greater than tire friction.
To Down shift to fast and car accelerates
Old Jan 6, 2008 | 01:58 PM
robvuk's Avatar
robvuk
If you are driving properly, you should never see the engine drag control get activated. That's why so few people are even aware of it.
Old Jan 6, 2008 | 03:33 PM
calemasters's Avatar
calemasters
Did you answer you own question.
Old Jan 6, 2008 | 05:26 PM
JmpnJckFlsh
Hmmm...I'll have to read up on this "Engine Drag Control".
I can't imagine a situation where adding throttle automatically without the driver's participation would be a good idea...The driver might be trying to get the vehicle stopped using every means at their disposal...antilock brakes, engine drag, dragging their sneaker.
If Thelma and Louise had been driving a Corvette, and changed their minds at the last moment, they might have gotten a little extra boost at the end to keep the tires from skidding.
