Down shift to fast and car accelerates
Old Jan 6, 2008 | 05:58 PM
robvuk's Avatar
robvuk
Originally Posted by JmpnJckFlsh
Hmmm...I'll have to read up on this "Engine Drag Control".
I can't imagine a situation where adding throttle automatically without the driver's participation would be a good idea...The driver might be trying to get the vehicle stopped using every means at their disposal...antilock brakes, engine drag, dragging their sneaker.
If Thelma and Louise had been driving a Corvette, and changed their minds at the last moment, they might have gotten a little extra boost at the end to keep the tires from skidding.
It's only there long enough to stop the rear tires from skidding, which could cause loss of control.
Old Jan 6, 2008 | 06:24 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I think if you downshift properly you will avoid this 'problem.'
Old Jan 6, 2008 | 06:28 PM
robvuk's Avatar
robvuk
I think I said that in my very first post.
Old Jan 6, 2008 | 06:40 PM
Brett Hunter's Avatar
Brett Hunter
However a poor tune is the reason it does not behave the way it did stock.
Mine has been recently re-tuned and I tested the AH and EDC yesterday to ensure everything was still operable. It all works fine.
Old Jan 6, 2008 | 07:47 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Perhaps GM programmed it such that if the brake system is pressurized, EDC does not engage. Most of their controls seem to be well thought out.
Old Jan 7, 2008 | 10:07 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Yeah, I'm sure there must be some kind of if/then logic programmed in. The engineers actually do a pretty good job of thinking through the safety implications.
Sometimes, it just seems like too many driver functions are being taken over by the machine in order to keep us from sticking our head down a cannon muzzle and pulling the lanyard. I lean more to individual responsibility and Darwin's Law myself.
I'm reminded of my son's adherence to the PC idea of turning the water heater thermostat way down to protect young children from burning themselves with hot water. On the surface, it seems like a good idea...but then, no one in the household ever has hot water, and children grow up to be adults ignorant of the idea that really hot water CAN come out of a faucet.
Old Jan 7, 2008 | 10:43 AM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Hey Jimmy stop beating on that poor tranny.. Decelerate with the brakes man... <---Jimmy beating on the tranny...
Old Jan 7, 2008 | 12:18 PM
pTr73's Avatar
pTr73
Originally Posted by BAADC6
It has happened to me when downshifting a little too quickly and not blipping the throttle.
That also wears the clutch out a bit if you keep downshifting without bliping the throttle.
Old Jan 7, 2008 | 07:28 PM
need-for-speed
CI 1-4-5-8-9-10 Vet
it's a lot cheaper to replace brake linings than clutch linings, although braking doesn't sound as cool as downshifting
Old Jan 7, 2008 | 10:38 PM
C6Coupe's Avatar
C6Coupe
I appreciate all the advise on down shifting, and I'm fully aware of the dangers to the tranny. the reason I asked was, after about 5 months with the new tune I noticed the problem for the first time and was just wondering if it was normal? If I want to beat on a car I'm sure Cameron will let Me use His Just messing with You Buddy
Old Jan 8, 2008 | 08:19 AM
pTr73's Avatar
pTr73
Exactly! I only downshift if I wasnt coming to a complete stop. The car is in lets say 4th gear, I see a red light up ahead and I brake and throw the clutch in right before the car comes to a complete stop.
BTW improper downshifting is bad for the car!
