Nav Screen Problem
Old Jan 8, 2008 | 10:15 PM
locoracer83's Avatar
locoracer83
Default Nav Screen Problem
I have a 2005 C6 with navigation system. Given the time of year/season, I'm not getting much use of the car. The last two times I've jumped in for a drive the Nav screen is dark. However, after the car gets warmed up the screen will come on, and stay on. Radio works even when screen is dark.
Is this a major problem? Anyone else deal with a similar issue? I have an extended warranty. Thanks in advance for any comments.
Old Jan 8, 2008 | 11:22 PM
Bludog's Avatar
Bludog
What was the temperature when you started up the car?
Old Jan 9, 2008 | 07:17 AM
locoracer83
It is garage stored (unheated but connected), so not any cooler than 45-50 degrees.
Old Jan 9, 2008 | 10:14 AM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
I've seen this even in the summer if the car has sit for an extended period. I'm guessing it's related to the battery being low after sitting so long. Like you said, drive it a bit, shut it off and restart it and it comes right up.
Old Jan 9, 2008 | 10:21 AM
Skunkworks's Avatar
Skunkworks
I've noticed some dimming when cold, but certainly not dark. Oh, 07 but don't think it makes a difference as LCD screen is likely the same.
Old Jan 9, 2008 | 11:26 AM
BrooklynC6's Avatar
BrooklynC6
aka allbottle¬hrottle
From: Brooklyn New York The DVL and the chicken sleep with the fishes....
St. Jude Donor '08
Happens to mine as well - Except none of the controls work , its frozen to whatever it was doing before I turned it off .... Two minutes later , no problems ..Very weird .
Old Jan 9, 2008 | 10:04 PM
Bludog's Avatar
Bludog
Wow, I have never seen that on mine yet
Old Jan 9, 2008 | 10:28 PM
GEOVETTE's Avatar
GEOVETTE
My car does the same but it's because the garage is dark and it takes a few minutes of driving before the lights go off and the screen changes.
Old Jan 9, 2008 | 10:30 PM
JACK FRISSINA's Avatar
JACK FRISSINA
Same thing on my 06 , they replace radio, thats the fix , check with your service dept.
To Nav Screen Problem
