rear end noise
Old Jan 9, 2008 | 08:35 AM
philiphere's Avatar
philiphere
Default rear end noise
What is downside for doing nothing? My 06 coupe makes short term noise when cold and moving out of garage. Once under way, no more noise.
Old Jan 9, 2008 | 09:15 AM
07CSicks's Avatar
07CSicks
Might be time for some fluids to the differential...
Not an uncommon problem though...
Old Jan 9, 2008 | 11:04 AM
carpe dm's Avatar
carpe dm
You may be OK for awhile, but if it gets worse, I would do the diff change and fluid add. High friction levels will cause clutch pack damage and there have been cases of cover plate distortion, leakage, etc.
Old Jan 10, 2008 | 01:15 AM
calemasters's Avatar
calemasters
Just the annoyance. I do not think the clutch stick/slip condition will lead to a failure.
Old Jan 10, 2008 | 01:54 AM
budgreen3564's Avatar
budgreen3564
TSB CORVETTE DIFFERENTIAL NOISE
You only want the #?
Rear Axle Chatter Shudder on Turns - keywords differential fluid noise oil #PIP3559 - (Sep 22, 2005)
1999-2006 Chevrolet Corvette
2004-2006 Cadillac XLR
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Rear axle chatter or shudder on turns on Chevrolet Corvette and Cadillac XLR.
Recommendation/Instructions:
If this is the first complaint for this condition flush and fill the rear axle with P/N 89021669 (in Canada 89021670) gear lube and 4 ounces of the friction modifier additive P/N 01052358 (in Canada 992694).
If this is a repeat complaint or the condition persists after the flush and fill, replace the right and left rear axle clutch packs following published service procedures.
After clutch pack replacement use 1.6 l (1.69 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455). and 4 ounces of the friction modifier additive P/N 01052358 (in Canada 992694).
Note: 2006 Z06 equipped vehicles require 2.55 l (2.70 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455) and approximately 190 ml (6.4 oz) limited-slip differential lubricant additive GM P/N 1052358 (Canadian P/N 992694).
Note: Export vehicles use 2.01 l (2.12 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455) and approximately 150 ml (5.1 oz) limited-slip differential lubricant additive GM P/N 1052358 (Canadian P/N 992694).
Once the axle fluid has been changed the car must be driven in 8 - 10 SLOW figure eights to work the fluid between the clutch plates.
Old Jan 10, 2008 | 06:30 AM
Hooked4Life's Avatar
Hooked4Life
Mine always chattered a bit first thing in the morning backing out of the garage. It was easy to fix, I put a 4.10 rear in.
Old Jan 10, 2008 | 12:21 PM
T Scott P's Avatar
T Scott P
Just had the clutch packs changed in my 06, no more noise. I did the fluid change drill twice, and after about 3000 miles, the noise came back. Gm changed the clutch packs under warranty.
Old Jan 10, 2008 | 07:38 PM
JACK FRISSINA's Avatar
JACK FRISSINA
CLUTCH PACS.
Old Jan 10, 2008 | 08:56 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Here is the most recent GM TSB regarding this condition:
2005 - 2007: Service Bulletin: Rear Axle Clunk and/or Chatter Type Noise on Turns
Subject: Rear Axle Clunk and/or Chatter Type Noise on Turns (Drain/Refill Rear Differential Fluid and Add Specified Limited-Slip Axle Additive)
Number: #07-04-20-002
Date: (04/16/2007)
Models: 2004-2007 Cadillac XLR (Including V-Series and Export)
2005-2007 Chevrolet Corvette (Including Z06 and Export)
Condition
Some customers may comment on a clunk and/or chatter type noise from the rear of the vehicle while making turns.
Cause
This condition may be caused by slip/stick of the posi-traction clutch plates due to insufficient limited-slip axle additive. As plates slip and stick, a jumping or jerking feel occurs accompanied by a clunk noise.
Correction
Important: DO NOT remove the differential cover from the rear or the two sides. It is not necessary to flush the old fluid from the differential.
Drain and refill the rear differential fluid using the procedure listed below. Add the increased amount of limited-slip axle additive specified below.
89021677 (89021678 In Canada)
Synthetic Axle Lubricant
Quantity: 2
(3 for Z06 and Export)
1052358 (992694 In Canada)
Quantity: 2
General Motors bulletins are intended for use by professional technicians, not a "do-it-yourselfer". They are written to inform those technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions and know-how to do a job properly and safely. If a condition is described, do not assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See a General Motors dealer servicing your brand of General Motors vehicle for information on whether your vehicle may benefit from the information.
© Copyright General Motors Corporation. All Rights Reserved
Old Jan 12, 2008 | 04:06 PM
philiphere's Avatar
philiphere
Thanks very much for your detailed response to my question on rear end noise--very helpful...
Old Jan 12, 2008 | 06:01 PM
Vito.A's Avatar
Vito.A
It is important to differentiate between differential clutch pack chatter and gear whine caused by excessive backlash from the ring and pinion.
The clutch chatter will happen primarily when you are turning in a tight radius. Gear whine is usually worse when you let off the gas pedal, but are driving straight.
Either way, I would have it taken care of before your warranty expires.
To rear end noise
