'08 engine ping
Old Jan 11, 2008 | 04:04 PM
loflite's Avatar
loflite
Default '08 engine ping
Just curious if anyone notices if their '08 engines ping. My '07 does a little and it drives me nuts. I'm running 93 octane, changed brands and been to the dealer and to no avail. Not looking for solutions, just curious if the '08 pings a little too.
Old Jan 11, 2008 | 04:08 PM
andreas g.'s Avatar
andreas g.
If it's really pinging or knock. It shouldn't not if the knock retard is working. That's it 's job. Take it to the dealer.
Old Jan 11, 2008 | 04:13 PM
LS1LT1's Avatar
LS1LT1
Plus the '08s have a slightly lower compression ratio (10.7:1 versus the LS2's 10.9:1), though I highly doubt that tiny bit would be enough to have one detonate any more/less over the other.
timd38's Avatar
timd38
Don't laugh, but could it be lifter noise?
Old Jan 11, 2008 | 04:15 PM
Hooked4Life's Avatar
Hooked4Life
My 07 would have occasional knock on the stock tune with 93 octane. I tuned it out with HPTuners.
Old Jan 11, 2008 | 04:43 PM
loflite's Avatar
loflite
It's definitely a ping. Again, not really looking for a solution because I don't think there is one without getting a tune or replacing the car. Just curious if the '08s ping too.
Old Jan 11, 2008 | 05:46 PM
carpe dm's Avatar
carpe dm
You might want to try a decarbonization procedure just in case... won't hurt to try.
Old Jan 11, 2008 | 06:02 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
??????? Why do you think there isn't a solution? A stock 07 should not ping on 93 octane gas......period. 91 shouldn't ping either. Try a new dealer. If they can't fix the problem have GM replace it.
Old Jan 11, 2008 | 06:19 PM
loflite's Avatar
loflite
Tried chevron cleaner with techron. Did help a little. The reason I say there is no solution is that the pinging is minor and is compensated for by the computer very quickly. That is normal within specs even according to the owners manual. BTW, silverspeed, every '07 I've ridden in or driven which is boxstock pinged occasionally. My older vettes never, ever pinged. Unfortunately, I've got really good ears.
Old Jan 11, 2008 | 06:36 PM
11secondGP's Avatar
11secondGP
No pinging here on 91 pump. If it really is knock I would do something about it. Take it to the dealer and/or use a better air intake...
To '08 engine ping
