part num help
Old Jan 11, 2008 | 04:37 PM
excessive81's Avatar
excessive81
Default part num help
i am trying to finish my ls2 and can not find a few part numbers:
front cover bolts
rear cover bolts
oil pan bolts
ls3 rocker arm bolts/stubs and nuts
ls3 rocker pedastel bolts
valve cover bolts
"dumdbell" oil plug
cam retainer plate
cam retainer plate bolts
water pump bolts
cam gear bolts
coil brackets to valve cover bolts
crank pulley bolt
THANKS
shane
Old Jan 11, 2008 | 07:22 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Shane,
If you're going to purchase all of this stuff and purchase from me I can take care of you.
Thanks, Gene.
