Windows final roll-up
Old Jan 18, 2008 | 08:40 PM
mmartin105's Avatar
mmartin105
Cruising
Default Windows final roll-up
My windows on my 2005 conv roll up fine but will not automacally roll up to seal. Is this a code problem or a limit switch? How do I read out the codes and find a code Description?
Old Jan 18, 2008 | 09:11 PM
ROD BROWN's Avatar
ROD BROWN
Default Windows not indexing
Page2-18 of your owners manual tells you how to program the windows to seal. Rod
Hope this helps
Old Jan 18, 2008 | 09:13 PM
johnodrake's Avatar
johnodrake
Moderator
Have you tried re-indexing the windows?
Power Window Initialize
After a power reconnect such as battery replacement, the
window index-up feature will not function until the system
is initialized. Once power is restored, do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds and
release.
Old Jan 18, 2008 | 10:31 PM
Vette_DD's Avatar
Vette_DD
1. Close the door.
release.
And that's on page 2-17 of the 2005 owner's manual, not page 2-18 as posted above.
Old Jan 19, 2008 | 08:49 PM
mmartin105's Avatar
mmartin105
Cruising
1. Close the door.
release.
Thanks-I'll do it
Old Jan 19, 2008 | 08:50 PM
mmartin105's Avatar
mmartin105
Cruising
1. Close the door.
release.
Thanks-How do I display codes and get a list?
Old Jan 19, 2008 | 09:04 PM
johnodrake's Avatar
johnodrake
Moderator
To read codes, you have to use a code reader that is compatible with the CAN-OBDII standard. Pick one up at WalMart or Autozone. C5 could display codes, C6 will not.
To Windows final roll-up
