Kooks Header Install Question?
Old Jan 20, 2008 | 01:00 AM
Mike V.'s Avatar
Mike V.
Default Kooks Header Install Question?
I followed Corvette Mags install of Kooks on the Zip Mule C6, & they mentioned use supplied gaskets which I naturally assumed they ment the ones that came from Kooks. Then it stated first go to 11lbs of torque, then back through at 18. I noticed all the threads/post stating the steel oems gasket were the way to go, that said are the torque specs the same? Also, should anything go on the bolts? Thanks in advance.
Old Jan 20, 2008 | 01:43 AM
SpinMonster's Avatar
SpinMonster
I always use antiseize and TQ to 18. Never an issue. I have used the stock gaskets over and over again. Toss the ones they give you with the headers.
Old Jan 20, 2008 | 05:52 AM
timd38's Avatar
timd38
The shop manual says TQ 11 then 15 for 2006.
Old Jan 20, 2008 | 09:48 AM
Finster07's Avatar
Finster07
After much research and a couple of calls to Kooks, I decided on using the original/stock gaskets, using anti-seize instead of thread lock (that is what kooks recommended,) and going with the 2 articles I had suggesting 11 ft lbs on the first pass and 18 ft lbs on the final pass. I did start a post on this about 3 months ago about anti seize versus thread lock. Personal preference. The risk with thread lock is possibly damaging the threads on the aluminum block if you ever want to remove the headers. That is why I went with anti seize. No problems whatsoever for 3 months now.
Old Jan 20, 2008 | 10:12 AM
Redline Motorsports's Avatar
Redline Motorsports
Exactly! You'll NEVER have an issue!
Old Jan 20, 2008 | 11:58 AM
Mike V.'s Avatar
Mike V.
Default Thanks!
Thank you gentlemen, I sure wish I read all the posts on using the OEMs b/f I installed them. My garage is'nt heated but it is insulated, so it should be warm enough. I guess today's as good as any!
Old Jan 20, 2008 | 08:54 PM
Vito.A's Avatar
Vito.A
I used the 3M hi temp anti-seize on the header bolts. GM uses a yellow thread locker that that I have not seen before. Most use either blue for bolts or red for studs and green for small screws.
Old Jan 21, 2008 | 02:32 PM
3 Z06ZR1's Avatar
3 Z06ZR1
You still want to re-Tq them after about 3 heat cycle's.I had several working loose. I waited till about 500 miles to check them.
To Kooks Header Install Question?
