El Toro L92 427 Complete Engine @ SDPC
Old Jan 23, 2008 | 01:08 PM
bg-sdpc's Avatar
0bg-sdpc
Former Vendor
Default El Toro L92 427 Complete Engine @ SDPC
We are now offering out L92 El Toro in a complete engine. The engine comes complete intake to pan so you can drop it in and stand on it.
Comes with:
L92 Block
L92 Cylinder Heads upgraded with Patriot Xstream Valve Springs
L76 Intake Manifold
Scat Crank and Rods
Manley 2618 Forged Pistons
Ackerly & Childs "Hell Fire" Ring Set
Clevite "H" series bearings
SDPC Street Thumper 4 Camshaft
LS7 Lifters
Manley Pushrods
N-Motion Billet Timing Set
GMPP Oil Pump
Powerbond SFI Approved Balancer
Oil Pan of Your Choice (See pricing below)
Stock Valve Covers
Stock Coil Packs
GMPP Plug Wires with NGK Plugs
$8499.95 Base Price
+$ 500.00 for CNC Heads
+$ 200.00 for Manley Stainless Steel Valves
+$ 300.00 for Callies Comp Star Crank and Rod Upgrade
+$ 300.00 for NW Cable Controlled 90mm Throttle Body
+$ 300.00 for C5 Corvette Oil Pan
Water pump and exhaust manifolds not included.
Dyno results listed below for base engine and CNC upgrade.
If anyone has any questions just message me or call at 806-798-4000 ext 354.
Old Jan 23, 2008 | 01:15 PM
NYC6's Avatar
NYC6
Im sure alot of people would like to know whats under 4500 RPM
Old Jan 28, 2008 | 06:08 PM
SDPC's Avatar
0SDPC
Former Vendor
TTT! With 427 cubes low end toque is not going to be an issue
Old Jan 28, 2008 | 06:47 PM
johnodrake's Avatar
johnodrake
Moderator
What is the bore and stroke?
Old Jan 28, 2008 | 07:08 PM
SDPC's Avatar
0SDPC
Former Vendor
4.100 stroke
4.068 bore
Old Jan 28, 2008 | 07:44 PM
johnodrake's Avatar
johnodrake
Moderator
4.100 stroke
4.068 bore
4.068 bore is the stock L92/LS3 bore, correct?
Old Jan 29, 2008 | 10:36 AM
Atomic-Punk's Avatar
Atomic-Punk
Is the 427 available in a shortblock?, if so how much??
Old Jan 29, 2008 | 10:55 AM
SDPC's Avatar
0SDPC
Former Vendor
4.065 is the stock l92 bore
We do have the shortblock as well, it runs $4989
Old Jan 29, 2008 | 12:05 PM
Tuner@Straightline's Avatar
Tuner@Straightline
Cam specs? I might have somebody interested in one . . .
Old Jan 29, 2008 | 12:37 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
Can you give me a guesstimate as to what else you would need to buy to drop this in a basically stock 2005 MN6 Z51? I've been looking at FI but as cool as 600-700 HP would be I can't imagine being able to use all that power. ( I know that sounds wierd because I'm usually in the "if more is good too much is better" camp)
This looks like a great combo that would live longer than FI on my stock bottom end. I could also sell my running LS2 or use it somewhere else!
Old Jan 29, 2008 | 01:41 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
What else is needed to have this up and running in the car? Sounds like a good deal so far...how would this work with an A6?
Old Jan 29, 2008 | 01:58 PM
Tuner@Straightline
Depending on the cam spec's, you might need a converter with the A6. From the looks of it, all you'd need is D-Flange manifolds/headers. You'll cary over all your accessories and sensors off you're old motor.
Old Jan 29, 2008 | 02:35 PM
SDPC's Avatar
0SDPC
Former Vendor
The cam is a 232/246 .595/.613 and I believe it is on a 115. Great HP yet very drivable
Old Jan 29, 2008 | 04:07 PM
Tuner@Straightline
How do I get one with a bigger cam?
Old Jan 29, 2008 | 04:09 PM
SDPC's Avatar
0SDPC
Former Vendor
Ask us for a bigger cam
To El Toro L92 427 Complete Engine @ SDPC
