Brembo Gt
Gigantic Monoblock 6-Piston Calipers
Huge Caliper Piston and Piston Bore
380mm or 355mm 2-PC Iron/Aluminum Lightweight Rotors (16.9lbs for 355mm)
McLaren Floating Hardware
8.1lbs in rotor weight savings per corner
Goodrich Stainless Lines with Banjo Bolt Connection
Rear:
Monoblock 4-Piston Calipers
Brand New Design with Thicker Pads, Bigger Pistons and Enhanced Piston Bore
Adds Additional Rear Brake Bias Over Previous 2-pc Rear Setup
345mm 2-PC Iron/Aluminum Lightweight Rotors (16.9lbs for 355mm)
Additional Weight Savings over Stock
Available in Red, Yellow, Black, or Silver
Can be shipped with Racing Pads Installed
Ferrodo DS3000 front Race Pads
Pagid Blue Rear Race Pads
Street Pads Included
Tremendous Temperature range, huge pad thickness and volume that Lasts
Now Taking Orders
Aftermarket wheels required. CCW makes wheels that clear the 14" kits easily. I also carry Forgelines any flavor
I'd recommend getting the ones that you think are the BEST. That way you won't be disappointed. The CCW Wheels are very reasonably priced and they hold their value well. Also I carry Iforged, HRE, and Forgeline. The best set of wheels I've done is a Forgeline. The street series forgline is actually a better wheel because it gives you more clearance due to the single lip vs the double lip.
I carry
Brembo GT Monobloc 380mm, 355mm
StopTech 15"/14"
Alcon Monobloc 14"/14"
I believe you'll be happiest with one of those kits.
I hope John at CCW let's me design a wheel.
