Anyone know the difference between stoptech Z06 BBK vs regular C6?
Old Jan 25, 2008 | 01:56 AM
greentank's Avatar
greentank
Default Anyone know the difference between stoptech Z06 BBK vs regular C6?
I did a widebody conversion on the rear, and have forgeline wheels all the way around. Will a C6Z stoptech BBK fit my car? What is the difference?
Old Jan 25, 2008 | 10:26 AM
User 81424's Avatar
User 81424
It should, what do you mean what is the difference?
Old Jan 25, 2008 | 11:17 AM
StopTechX123's Avatar
StopTechX123
Cruising
The front piston sizes on the C6Z06 kits are different from the standard C6 kits, other than that, the rest of the components are the same.
Old Jan 25, 2008 | 11:27 AM
greentank's Avatar
greentank
So, the C6Z BBK kit should fit my application? Is there any downside in using the C6Z kit?
Old Jan 25, 2008 | 01:42 PM
StopTechX123
Cruising
It will bolt up just fine and have a more forward overall bias than a standard C6 kit. You wont get the full benefits of the specifically engineered kit but it will still be a big improvement over stock....balance wise, its better than bolting up C6Z06 stock brakes to your car.
Old Jan 25, 2008 | 02:26 PM
User 81424's Avatar
User 81424
So the front of a C6Z06 is heavier than a C6 and the forward piston of the Stoptech C6Z06 calipers is bigger?
Old Jan 25, 2008 | 02:35 PM
greentank's Avatar
greentank
Will this cause any material braking inefficiency? ie, the front tire locking up but the rears not? If not material, I'm fine with it. Just dont want to create a dangerous or unpredictable situation.
To Anyone know the difference between stoptech Z06 BBK vs regular C6?
