********Header Install Question*********
Old Jan 31, 2008 | 10:41 AM
ground zero's Avatar
ground zero
Default ********Header Install Question*********
I bought kooks 17/8 long tube headers with a catless x pipe. I am going to be using a Diablo Predator (U7194) for the tuning, my question is do you even need to install the rear o2 sensors being they are tuned out anyways?
Old Jan 31, 2008 | 01:47 PM
ground zero
Hello, anyone?????
Old Jan 31, 2008 | 09:49 PM
GMRULZ's Avatar
GMRULZ
If you turn them off then you don`t need them, however you will need to plug the bung holes w/ a pipe plug..
Old Jan 31, 2008 | 11:18 PM
Vito.A's Avatar
Vito.A
It is your choice to install or not install as long as you do not have to pass a visual emissions test.
I believe the O2 sensor bungs are 18MM.
Old Feb 1, 2008 | 10:31 AM
timbo79's Avatar
timbo79
I have the 1 7/8 as well. AND I have the predator tune. I installed the sensors with the extensions, but the tune turns them off.
Main reason was for looks. (smog, even though no check needed here for 5 more years)
The extensions came wth the setup, so I installed rather than getting bung plugs. Not a big deal.
To ********Header Install Question*********
