vararam question
Old Feb 2, 2008 | 12:25 PM
azneric85's Avatar
azneric85
Default vararam question
i just ordered The VR-SC1, for my automatic c6
and i just wonder do i have to get a precut shroud
or can i install it with out shroud? cuz i am just tyring to install it when i am gonna recieve the order..
what is the difference between getting the precut shroud and not usding the shroud when i am going to install ..
can it be install with out shroud ?
Old Feb 2, 2008 | 01:21 PM
mcwire's Avatar
mcwire
As I understand, the pre-cut will not work, with your 07, A6. -- Do a search on this. -- --
Old Feb 2, 2008 | 01:25 PM
Evilways's Avatar
Evilways
even if it worked, the precut is tons more work that just taking the template and cutting the shroud with a box cutter. Be sure to have a thick piece of cardboard behind to protect other componets.15min job with a sharp cutter and strong wrist. I used a white china marker to outline the template, removed the paper and cut, test fit, trim a little ,and final fit. No issues at all, not even excess dust and derbis in the engine bay.
Old Feb 2, 2008 | 01:57 PM
LS1LT1's Avatar
LS1LT1
Yes that is KEY advise, do not go too far through it and puncture your condensor.
Old Feb 2, 2008 | 02:04 PM
HuskerBullet's Avatar
HuskerBullet
I actually removed the stock shroud, cut it and reinstalled it back in.
DON'T DO THAT, because it was a major PITA! I wanted to do a nice clean job with the cutting, which I did, but wow what a job that was to remove and replace, so I agree with the above guys...be real painstaking when cutting it while it's still in there!
Old Feb 2, 2008 | 02:11 PM
slvr76's Avatar
slvr76
Definitely just cut the stock shroud with it in the car. Be careful, but its much easier this way.
Old Feb 2, 2008 | 02:58 PM
azneric85's Avatar
azneric85
so cut it in the car ? u mean dont take it out and do it in the card board
just cut it as how is placed in the car?
Old Feb 2, 2008 | 02:59 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
I have the VR and the pre cut shroud. It going to be installed on Monday by a local shop. The shop wanted the pre cut. I called VR tech and they said that the pre cut will work with the C6 A6.(not bad for a Saturday) It's the Z06 that has the oil lines going through the side of the shroud.
Old Feb 2, 2008 | 04:50 PM
slvr76's Avatar
slvr76
Yes, just cut it in the car. place apiece of cardboard between the shroud and condensor. Be careful not to cut too deep, so you will avoid hitting the condensor. Its a little nerve racking, but really not that hard. if you choose to remove the shroud, this will be much more difficult and time consuming.
Old Feb 2, 2008 | 04:58 PM
1954's Avatar
1954
Thanks for the good info. I ordered mine without the precut shroud but wasn't sure at the time if I did the right thing. The directions for removing the shroud looked a bit hairy.
Old Feb 2, 2008 | 05:19 PM
slvr76's Avatar
slvr76
Yep. I talked to the folks at Vararam, and they rcomended just cutting the shroud. I'm in the paint/bodywork business so I wasn't too concerned about getting the stock shroud out and replacing it, but why try to re-invent the wheel? In the instruction pictures from Vararam it looked like you had to bend the bottom of the bumper quite a bit to remove the stock shroud, which concerned me from a paint fracture standpoint.
Old Feb 2, 2008 | 06:23 PM
goatts's Avatar
goatts
Cut the shroud in the car with a razor knife. Put something between the shroud and condenser so you don't poke a hole in it. You may have to trim several times before the unit fits the way you want. If you're not comfortable with the install then get a shop to do it for you. A number of people have botched the install and blamed it on Vararam.
Old Feb 2, 2008 | 11:01 PM
07C6Z51's Avatar
07C6Z51
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
I don't know about the Z06, I have the Z51 package and Steve at Vararam told me the pre cut shroud would not work, due to the transmission lines running through it.
Old Feb 3, 2008 | 04:07 AM
Evilways's Avatar
Evilways
No lines through my Z51...on ZO6 it makes sense as the dry sump is near there.
Old Feb 3, 2008 | 08:16 AM
Vetteoholic's Avatar
Vetteoholic
Let us know how it goes I may go with the Vararam system for my C6. I really like this system.
Old Feb 3, 2008 | 01:39 PM
FUNTRUN's Avatar
FUNTRUN
Default Heat up the plastic shroud
When I installed my Vararam I had bought the precut shroud and decided not to use it because of the hassle of removing the factory shroud. I have an 08 C6 Z51 and there are lines going into the shroud. I did find out that it made a huge difference to heat/soften the plastic shroud before I started cutting. I used a heat gun but I'm sure a hair dryer would also work.
The whole install went well, a lot easier than I thought after reading all the negative posts on the forum.
Old Feb 3, 2008 | 03:19 PM
FEAR's Avatar
FEAR
great now i am all scared about putting mine in, i bought the shroud from vararam, we'll see, ill be doing it wed night
To vararam question
Old Feb 3, 2008 | 03:22 PM
NEV3R L8's Avatar
NEV3R L8
I just installed mine without using the template or precut shroud in about 30-45 min. It was very very easy. Especially love the whistle it makes now.
Old Feb 3, 2008 | 03:34 PM
pc07vette's Avatar
pc07vette
After all the complaints about Vararam templates being the wrong size why not get the precut shroud and use it as a template. At least the hole will be cut the right size the first time without having to re-cut.
Old Feb 3, 2008 | 05:48 PM
FUNTRUN's Avatar
FUNTRUN
That is exactly what I ended up doing with my pre cut shroud. Used it as the template.
