Fueling problem
Old Feb 7, 2008 | 11:29 PM
cabovaquero's Avatar
cabovaquero
4th Gear
Default Fueling problem
I just put fuel in my 2008 coupe for the first time. I did get 20.5 Mile per gallon. The first 7 gallons of fuel went in without a hitch. the last 8 gallons took about 5 minutes to get in to the tank. Nozzel kept shutting off. the only way i could get fuel in was at a trickle. Anybody have the same problem? There must be a fix for this, any ideas
Thanks SKIP
Old Feb 8, 2008 | 05:26 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Many times the problem is the pump nozzle, not the car. Try others or different gas stations. If it persists, try rotating the nozzle to a 45 degree angle when filling. There are some previous threads on this which you might search for.
Old Feb 8, 2008 | 05:38 AM
keyplyr's Avatar
keyplyr
Old Feb 8, 2008 | 05:39 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
I always shut the engine off when fueling mine,never had any problems at the pump, don't know if that will help your situation though.
Old Feb 8, 2008 | 09:49 AM
blackvette101's Avatar
blackvette101
Thanks SKIP
I had this problem when I first got my car. It's something wrong with the way ithe pump sits on such a low car. How I fixed it was I held the pump with my hand and pointed it down into the gas tank.
Old Feb 9, 2008 | 08:41 AM
foremaw's Avatar
foremaw
To Fueling problem
