Callaway Honker
To start I'm offering the Air Intake, Shifter, and Carbon Fiber Wheels with Magnesium Centers. Please PM me for pricing.
Callway Air Intake
Increases airflow by 34 percent. Adds 12 bhp in stock LS2's.
The Honker C6 provides reduced airpath restriction, accesses cooler air from outside of the engine compartment, and locates the air entry at a higher-than-ambient pressure area (relative to vehicle speed) to generate increased horsepower.
• Smooth internal surface and CAD-designed contours engineered to maximize laminar flow.
• Rigid filter element base ingests cooler, denser inlet air from outside of engine compartment.
• Easy-to-install duct attaches to OEM mounting locations at top of radiator support.
• OEM-grade polymer remains unaffected by severe under-hood temperature excursions.
• Low-restriction K&N filter element is washable and reusable for reliable service.
• Supports additional engine and vehicle modifications.
• Works with all OEM engine management sensors.
• Premium quality hardware used throughout for extended durability.
Dyno testing verified the airflow test results, indicating an increase of 12 bhp on an otherwise stock LS2! At the dragstrip, simply bolting a Honker into a stock 2005 coupe dropped its 1/4-mile ET by three full tenths and increased top speed by 2 mph!
The Honker C6 System includes CAD-designed air inlet duct, low restriction, washable and reusable K&N air filter element, rigid filter element housing, comprehensive installation instructions, and all required hardware for easy installation.
A fellow Corvette owner installed a honker on his already stout LS2 and picked up 15rwhp at the wheel. Keep in mind this car had EVERYTHING modded already before the CAI.
There's more than enough air flowing into this area to go through the radiator and into the air intake system. GM engineers designed this area to provide engine cooling air; we've actually measured slightly higher-than-ambient air pressure in this area that's proportional to vehicle speed.
Bottom line is consistent 0.25 to 0.30 seconds quicker than OEM intake in 1/4 mile in back-to-back LS3 testing. An unusually quick pass, we've run a 11.562 @ 118.82 with a stock 279 mile LS3 coupe with nothing but drag radials and a Honker. We also hear regular reports of at least three-tenths improvement with the C5 design, where we eliminated the air bridge and relocated the MAF sensor, close-coupling it with the throttle body.
The 11.56 time slip:
http://i72.photobucket.com/albums/i1.../08wHonker.jpg
I have an Xcelerator closed system CAI, similar to the Honker. On a 80 degree day in Fall I made testing runs in scan mode with my HP Tuner. My IAT's were at 95 degrees after purposely running a very warmed up car (and at stock fan settings) and for some time at idle prior to hitting the freeway. At the start of a rolling 20 mph WOT run they were down to 91 degrees and I then ran WOT. At 30 mph it was 88, at 40 mph it was 84, at 60 mph it was 79, at 80 mph it was 75 and stayed that way pretty much to the end of the run at 115 mph at 73 degrees IAT!!...dropping 7 degrees below ambient. Back down to steady cruising at 70mph it settled in nicely at 84 degrees IAT, 4 degrees over ambient.
My testing show under normal driving conditions while moving at any speed (except WOT), that it runs on average about 4 to 7 degrees over ambient. Thus, it shows the Honker & Xcelerator type CAI closed systems indeed get lots of cool air rammed into the intake at WOT and nicely pushed into it at normal speeds. Running a 160 t-stat and changing fan settings fixes any idling heat problems that might develop.
Definitely looks like a good design and way better than the hot air intakes (K&N style etc.) out there. But I guess I just have some issue with the sharp turn that air must have to make to get into the MAF and the contrarian concept that air coming from low in the very nose of the car simply has to be cooler/cleaner?
This is where the "free air mod" propped open shroud shines. Only problem is the cold & clean air goes into warm air filters....unless you close off the filter area like Modshack or 12secondCV did.
More direct air flow means more power(Engine/Pump
. As far as dirt goes, i don`t have that problem that you speak of. But i will say that the filter is doing its job as all cai`s filters do....Clean the air coming into the motor, i hope i cleared that up for you!
