Cat removal with header install
Old Feb 12, 2008 | 02:58 PM
z060ntrack's Avatar
z060ntrack
Default Cat removal with header install
I'm being told by a very reputable engine builder / tuner that there are no long tube headers available for the C6 / Z06 that don't require the removal of the cats! This was never an issue with the C5 so I just assumed that you could install long tube headers and keep the cats in place and in stock location.
Any insight here would be helpful
Old Feb 12, 2008 | 03:05 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Our headers are available with and without cats.
You do have to replace the factory cats however, and this is true for any true long tube header, not just ours.
Old Feb 12, 2008 | 03:21 PM
z060ntrack's Avatar
z060ntrack
Anthony, are some tuners reluctant to do that because of State and Federal laws that the replacement cats are not OEM or certified?
Old Feb 12, 2008 | 03:25 PM
csun213's Avatar
csun213
Fed laws does not allow the relocation of the cats. Since all long tube headers are longer than the stock man therefore the cats must be moved in order for the headers to be installed. So there is no long tube header that is acceptable for smog.
Old Feb 12, 2008 | 03:31 PM
Vito.A's Avatar
Vito.A
Default Headers/Cats
The C6 catalytic converters bolt directly to the cast iron exhaust manifold outlets. With the hood open, you can see the catalytic converters from above. Then the factory H pipe bolts to the catalytic converter and extends back to just in front of the rear axle.
The long tube headers take up the space previously occupied by the cast iron manifold and the catalytic converter. Most quality aftermarket header companies also offer an optonal H or X pipe with high flow cats.
Old Feb 12, 2008 | 04:04 PM
z060ntrack's Avatar
z060ntrack
Ahh, I get it and yes most of the reputable header manufactures do offer an X pipe with cats. So I guess some tuners are unwilling to walk that "relocate" line depending on what State they are in.
To Cat removal with header install
