How Does The LS2 Ignition System Work?
-David
This is the link to the other thread I started about the P0300 code -> Click
Also I did just install headers. But I don't see any loose wires or anything and I checked over my install pretty good but maybe I missed something. Any ideas?
Have you checked for a cracked spark plug since you recently installed the headers. It will be a fine crack along the porclene.
If you can get a Tech 2 or any such scanner it would help narrow down the cause.
You can observe individual cyl misfires, bank to bank leak conditions, and do a cyl balance test.
The ignition system itself is a good system. The coils have power during Key On/Run and the PCM supplies ground to trigger the coils.
The Simplistic Answer
The PCM gets a signal from the Crank Sensor (CKP) and the Cam Sensor (CMP) to determine RPM and which cylinder it is on. The PCM crunches the numbers based on the parameters built into the software and other inputs . It then grounds the coil to cause spark.
The in-cylinder explosion causes a smile on the face and it all starts over again.
I'm not sure of your mechanical prowess so go with caution. If you don't know what you are doing then seek help. Not trying to be offensive, I just don't want to suggest you test stuff and have you fry something and get mad at me. Let us know what you find and we will go further, but let us know if a known good coil fires there, if not do you have a signal to the coil etc...
You said there was nothing at the wire. Remember it needs ground to fire or spark. You need to get the wire close to a ground to see the arc jump. I usually use a tester or a small screwdriver inserted in the boot and making good contact with the metal end. Then hold it close to, but not touching a good ground source. Sorry for the dumb statements but its tough to know the level of the poster.
Its very easy to crack a plug druing header install. Put a known good plug in the suspect wire, ground the thread portion and see if it fires.
Let us know.
On a side note, did you ever own a red 911? I used to talk to a guy that had one with the same plate as yours.
I already bought a new coil so I doubt I got a bad new one but I'll double check it all.
I'm not exactly ASE certified but I do have some knowledge of what is going on. I just need an outsiders opinion cause I'm pretty stumped at this point. I'll double check for an arch maybe it wasn't close enough to arch. I'll let you guys know.
Edit: absolutely no arch. I think I have a meter I just have to find it and I'll let you know if I can determine if the coil pack is getting any power.
Any change I pulled a wire loose for just that coil. I know there is a harness on the top of the coilpack which is on there but I can't imagine what else it would be..
And no lol it wasn't me with the red 911
