Ported Fast Is Really A 92mm
Old Feb 23, 2008 | 09:49 PM
jhester's Avatar
jhester
what black paint was used? the texture seems to match stock fairly well?
Old Feb 23, 2008 | 09:58 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default What Color Paint ?
I know it looks almost identical to the stock manifold. I have to call my tuner tomorrow and get the exact paint info for you, Ill also post a pic side by side the stock intake.
Old Feb 24, 2008 | 11:10 AM
LEAVINU's Avatar
LEAVINU
Originally Posted by LSCHLEM
Here is the dyno Sheet making the comparisons. Spin previously mentioned not to get hung up on peak numers but the midband is so impressive.
what is this dyno for? non-ported FAST against ported FAST?
Old Feb 24, 2008 | 11:24 AM
LSCHLEM's Avatar
LSCHLEM
Default Pics Of Color
Here are the pics of the manifold along side oem . The one has a little glare from the flash.
Old Feb 24, 2008 | 11:26 AM
LSCHLEM's Avatar
LSCHLEM
NO the dyno sheet here is PORTED OEM VS PORTED FAST. We will have more dyno results of various combos in about 2 weeks.
Old Feb 24, 2008 | 11:32 AM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
I bet you can`t wait
I know i can`t
Old Feb 24, 2008 | 11:38 AM
LSCHLEM's Avatar
LSCHLEM
Default Fast Install
I know i can`t
Mine goes on march 6th . Ill post dyno sheets right after. Yup I cant
wait that thing is sitting on my cherry wood kitchen table.
Old Feb 24, 2008 | 11:40 AM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Mine won`t be in till the end of March, beginning of April....
Old Feb 24, 2008 | 11:46 AM
LSCHLEM's Avatar
LSCHLEM
You mentioned that you were installing fast along with other things.
What other things are you contemplating ? Cartek stage 2 H& C ??
Old Feb 24, 2008 | 11:48 AM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Sending a pm.
Old Feb 24, 2008 | 08:04 PM
LSCHLEM's Avatar
LSCHLEM
Default Fast Looks + Hp
Sending a pm.
The FAST will work wth any combo. Im looking for HP/TQ that will be quite noticible
Old Feb 24, 2008 | 09:17 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
I'd like to make a suggestion and modification to the placing of the brake hose when doing the 'spinmonster' mod.
Bond an extra piece of plastic to the lower portion of the intake, this gives the fitting more 'meat' to bite into, also, use a 90* fitting and place it at the rear of the lower monifold. There is ample room and it fits the brake hose around the OP sending unit like stock. It will place the fitting almost in the stock location.
Old Feb 25, 2008 | 06:43 PM
  #33
LSCHLEM's Avatar
LSCHLEM
Default `rear Fitting Too Close To Oil Sender
Im glad you highlited the possibility of the rear fitting having clearance
problems with the oil sender. I know mine is about 15 degrees more
towards the oil sender than spins original design. Probably a real clearance problem. Its an easy fix mounting it on the other side and
putting a pipe plug where it originally was. Thanks much.
Old Feb 25, 2008 | 08:38 PM
  #34
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Another installed pic from a very happy camper
Old Feb 25, 2008 | 10:47 PM
  #35
LSCHLEM's Avatar
LSCHLEM
Who's cool vette is this with the painted fast ?
Old Feb 26, 2008 | 09:48 AM
  #36
Craigster05
I wonder......
I think the Alt Cover gives it away....
Old Feb 26, 2008 | 10:50 AM
  #37
LSCHLEM's Avatar
LSCHLEM
I wonder......
CRAIGMONSTER that sounds good
To Ported Fast Is Really A 92mm
Old Mar 2, 2008 | 12:51 PM
  #38
LSCHLEM's Avatar
LSCHLEM
Here is the pic of the final rear fitting for brakeline hose. The way I originally mounted it would go right smack into toe oil sender. I moved it to the other side. Should have no clearance problems.
Old Mar 2, 2008 | 09:16 PM
  #39
SnapperDragon's Avatar
SnapperDragon
What's with buying an intake and needing to modify it?
Old Mar 2, 2008 | 09:38 PM
  #40
LSCHLEM's Avatar
LSCHLEM
Default Is all the aggravation worth it for the FAST
Well you make a good point. That being said it could concievably cost
$1,300 to get the FAST, get it ported & painted, Do the necessary mods to accommodate the C6 like the firewall, MAP relocation & Fuel
rail. Then get it tuned. Why didnt comp cams just make a pure bolt on
Manifold for the LS2. They let it to us to sort out and many have ruined their manifolds trying to get them to mount and work. Now they
are comming out with one for the LS3 in the springtime. I wont know if its all worth it till I see my dyno numbers and SOTP performance. I commend those who have tried to mahe it work and were able to get
a good performance gain.
