Z06 manifold hype
Old Feb 24, 2008 | 06:55 PM
  #41
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by JLINDSEY2
A tuned set of headers-vs-gm manifolds, err, that's a no brainer.
I'm lovin my LG's
That's because you can afford to love them. Again, no one said the Z06 were better. This is about bang-for-the-buck.
  #42
dennis50nj's Avatar
dennis50nj
Originally Posted by Tom400CFI
I can't beleive you guys are defending a "guy" (who has done nothing but post an [subjective] opinion), when dyno results [objective] have already been posted.
Tom i am defending spin because he is right. and he has a lot of knowledge and common sense, all his ideas that he has came up with i have used a few and they have shown great results for me the common sense part is 30 mote rwhp on a dyno it has to be a mistake or a lie. like i stated if you add all that to the c6 it will have almost the same hp as the zo6. the 30 for exhaust the 100 mm maf has shown 20 hp in the c5 section now dri sump and whatever else can be transplanted from the zo6, you would have the same hp with a smaller cubic inch motor. see the common sense part. spin is tough and licensed to carry, i want to be on his side
Old Feb 24, 2008 | 06:58 PM
  #43
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by 6Speeder
A couple points from the entire thread: 30 to 35 hp gain with LG headers ALONE on a Z06? No way. We tried them, tuned the whee out of them and gained 2 rwhp peak. The Z06 exhaust system is very good, it's basically a shortie header from GM.
Exactly. Most I've EVER seen on this forum from a stock Z06 w/headers and a tune only is 15hp. That is what you could get from the tune alone.
Old Feb 24, 2008 | 07:05 PM
  #44
NYC6's Avatar
NYC6
Originally Posted by vetracer
I went from LG headers and high flow cats with a Z06 borla touring cat-back (complete 3" system) to a stock Z06 manifold and exhaust system on my 06 A6 with a H/C package. The Borla and everything else but the headers went on my new Z (the headers for the Z are different). Anyhow, after retuning and another dyno run my A6 went from 458 RWHP to 420 RWHP. That's a loss of almost 40 horsepower over the LG header system. Maybe there are other variables at play here but in any case there was a big difference.
Just curious, why would you remove LG headers and put on cast manifolds? And who talked you into that?
Anyone able to post a dynojet printout of these remarkable gains with the Z06 manifolds? I cant find one anywhere. All I hear of is one guys claims.
Old Feb 24, 2008 | 07:11 PM
  #45
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Z06 maniflods are not made of cast iron.
"A rarity for production engines--and even racing engines--the exhaust manifolds are made from hydro-formed tubular steel. The individual runners of the header tubes meet at a unique quad-outlet collector, which is said to smooth exhaust flow and reduce backpressure."
  #46
Maklar's Avatar
Maklar
The dyno has been posted twice in this thread...
Old Feb 24, 2008 | 07:12 PM
  #47
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Ok so we have proof of one car that showed a 30rwhp increase with the Z manifolds only. We also have another car that only showed a 10rwhp increase with the Z manifolds only. This is why we need more tests, so we can get an average acceptable estimate of HP/TQ gains.
I agree that LTs are expensive but currently the market can support the price. I understand why some would not want to spend the money. I think the Z manifolds if purchased for a good price($500+/-) and self installed can be another solution. However I see a slight flaw in this logic and this is the part of Spin's opinion that I agree with. I understand the want to save money for future mods. But just about any mod you do after that (other than gears/trans) will only be obstructed by the Z manifolds as opposed to LTs. This will most likely cut down on your potential power output. Let's say you're only 15rwhp less with Zs than with LTs. That's on a stock motor. You add heads/cam/intake or S/C to that motor and the restriction will be greater than 15rwhp. It kind of makes whatever mods you are going to perform after the Zs not as beneficial and certainly less efficient. I don't see how that is a good practice in HP per $.
Although, most looking to do Z manifolds as opposed to LTs are probably not concerned with absolute power gains. On a stock or very mildly modded motor (ie: CAI/tune) the Zs seem to be a decent pennywise alternative(pending more results). But I think any mods done after that just makes it illogical. JMO, which doesn't account for much.
Old Feb 24, 2008 | 07:16 PM
  #48
NYC6's Avatar
NYC6
Thanks for learning me something today.
Old Feb 24, 2008 | 07:19 PM
  #49
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Good point, which I agree with...and you answered your own question. W/the C6, I'll never be able to afford a "max motor" or even 1/4 of the stuff that guys like Spin have done. If I had C4, it would (and has been) a different story. I need max Bang-for-the-buck mods, and this is one of them. I will NEVER lay down $1.5k on a set of header. Won't happen for me. I'll fab my own LT headers before I do that, but instead along comes the Z06 option. Looks pretty attractive to me. That's where a guy like me is coming from.
The fact that the ZO6 mani's support 505 hp and LT's show minimal peak gains, tells ME that they aren't much of a "restriction" even at that level. I've got a ways to go before I'm putting out 500 CHP.
Old Feb 24, 2008 | 07:23 PM
  #50
'06 Quicksilver Z06
For some people its going to be getting around the drawbacks associated with long tubes.
Depending on the car owner, each can be anything from a big headache to no problem at all.
1. Cost.
2. Emissions.
Z06 manifolds can probably be had for a lot cheaper than a set of long tubes, they look like original equipment, can probably be run with no tune right away, and not have to worry about a CEL. The last three can be important for emissions.
On the down side, they probably won't make as much power as long tubes, especially in the mid ranges.
But that might be an acceptable trade off for some people here who are concerned about costs and emissions testing or warranty.
While there is no guarantee that your warranty will remain intact with a set of Z06 manifolds on your C6, because they are not original equipment, you might have a better chance of not running into warranty issues with a set of Z06 manifolds on, vs a set of long tubes.
I guess they are sort of like "OEM" shorty headers if there is such a thing. Not the power you are going to get from long tubes, but less hassle than long tubes though. And make no mistake, long tubes can be a hassle.
The way I see it is that its just another alternative for people who are interested in changing their exhaust system in an attempt to make more power. Each option has trade offs.
Old Feb 24, 2008 | 07:41 PM
  #51
johnodrake's Avatar
johnodrake
Moderator
For some people its going to be getting around to drawbacks associated with long tubes.
1. Cost.
2. Emissions.
That sums it up quite nicely, I think
Old Feb 24, 2008 | 07:47 PM
  #52
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
my 2 Cents
anyone taking the cheap way out of gaining HP by bolting/modifing "hand-me-down" parts (aka Z06 manifolds) shouldn't own or not even get into modding.........
LG Headers 1,800 expensive?
700 off Performance Headers for BMW E60 M5 and E63 M6
Get $700 off the normal installed price for performance headers for the
current generation BMW E60 M5 and E63 M6! These equal pulse headers have
larger primary tubing, unique collector, laser cut head flanges, two-stage
ceramic coating, and a 62% increase in flow. They're tuned for low and
mid-range power. This breaks down to $4499 for the headers and just $800
for the 15-hour install labor charge. This also includes a dyno run on a $60k DynoDynamics eddy-current dyno afterwards. Expires 11/9/07.
OK, $700 might be about right for the installation, but $4500 just for the headers? What are they made of..gold? I can buy a high performance American made engine for that price, including headers.
They're the cheapest ones on the market. Next cheapest is $7k (SuperSprint & RD Sport).
Average install is $2000, lowest competitor is $1500.
I have personally witnesed headers install on an M6, the whole front undercarrige needs to be dropped, also the cat-back for an M6 costs
and heres a "group buy" for tubi cat-back
Pricing:
- Tubi Style List Price: $2,350.00
- BeastPower Web Price: $1,995.00
- BeastPower Group Buy Price: $1,845.00
- Pricing is going up due to the appreciation of the Euro vs. the US dollar (a 6% increase across the board is expected).
Also for the E55 Benz, CAI, comp flash & a smaller pulley for the kompressor is.................$3,500
Old Feb 24, 2008 | 08:00 PM
  #53
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Really??? Show me where I can get LG's for $500 please. I'll buy thm the second you show me. Show me where I can get the entire Z06 system from the heads back for $500....I know a few guys looking for it.
Damn right I'll do the install myself. Obviously, anyone who post about getting "80% of the gain for 30% of the cost", is a DIY'er. People who pay other people to work on their own cars aren't reading this thread...I would hope, because they can afford the "boutique" parts and pieces....and the labor to do the easy R&R's. - Yes they are - many guys read here, buy stuff and bring it to shops to have it installed, believe it or not, I get alot more bolt on work where people bring in used parts than you'd imagine.
I don't believe that this ever happened. Spin said that. I've never seen that posted in the "For sale" section. Not even w/Z06 parts. Though it MAY have been at some time, and if it was, that's lame. - I agree, very lame - I have two customer's that came to my shop with the same story, from someone who was giving them a "deal" around $1,000 for the entire system - THAT's where I think it's a waste of time. If you can get the entire system for $500, you're lucky. I see the catback mufflers alone selling for that price. For $500, doing your own labor, and picking up some gains, and having some fun in the process, I say go for it....but for those thinking they are getting almost the same gains as headers, they are mistaken. That is also where I pointed out for $1,000, you;d be better off with the $995 LG Street Series Headers when they are on special.
I do agree w/teh part about warranty, and technically you are right about emissions. Fact is, no normal emission station would notice heat shielded, factory Z06 Manifolds on a C6. A Chevy dealer would - and I know of two dealers locally who love to break customer's chops by failing for stuff like that because they didnt get the install work. Im sure things are much different in Utah than here in the Northeast.
Answers above.
Old Feb 24, 2008 | 08:02 PM
  #54
'06 Quicksilver Z06
Originally Posted by C6 DVL
my 2 Cents
Its not just the $1795 which LGs go for C6DVL. And I have owned both LGs and KOOKS. Both great products if you can afford them.
But like I said, its not just the cost of the headers.
IMO, there is no point in investing in a set of long tubes unless you are going to get the car tuned and tuned well after the header install. So count on another 5 bills.
If you are handy with a wrench, you can put on your own headers and save some dough that way, but the tune is really what sets the headers off. If you are not good with a wrench, then prepare to pay someone to install them.
Some even like to get fancy with coating their headers as well, though I never coated either my LG Pros or KOOKS.
So those people can add a couple hundred more.
When its all said and done, the headers, shipping, (coating if you want to have them coated albeit probably not necessary), and the tune,.... the change you have left over from 3 grand won't even get you a set of drag radials amounted on a good set of rear wheels.
Now compare that to an entire take off Z06 exhaust system. Even if you only got half the gain, you still don't have near as much money into it, you don't have to worry about emissions, and your warranty may not be at as big of a risk as it would be with long tubes.
Now for some of the guys here, they couldn't care less about warranty.
But if for example, my starter goes out, I don't want the dealer bitching that it was due to the heat from my long tube headers, I want my starter replaced.
Old Feb 24, 2008 | 08:05 PM
  #55
saber's Avatar
saber
I disagree with this as the new ZR1 will have the same manifolds and produce 650hp!!!!!!!!!!!!!!!!!!!!!!
Old Feb 24, 2008 | 08:14 PM
  #56
saber's Avatar
saber
Just a note, GM has Supercomputers running CATIA based Computational Fluid Dynamics Analysis tools for designing these hydroformed manifolds.
I don't think one of these weld shops making headers has that!
Old Feb 24, 2008 | 08:34 PM
  #57
siffert's Avatar
siffert
I pretty much agreed with everything you said prior to this post, but on this one when talking $$$, you should have quit while you were ahead
I got my Kooks #6600-EX 1 3/4" headers with Hi Flo Cats from forum vendor MarylandSpeed for 1,380 with free Jet Hot Extreme 1700 coating and free shipping. Installed them myself with a pal for free, though I did pay $20.00 for new GM Gaskets. I also bought a HP Tuner for $500 but tuned other things (like tranny) than my headers so we'll call that $250.00. Adds up to $1650...far less than your 3K and the saved money could easily buy 17" DR's with C5 Z06 wheels (or 18" DR's on C6 oem front wheels), Vararam or Honker and still have money left over from 3K.
To Z06 manifold hype
Old Feb 24, 2008 | 08:37 PM
  #58
k0bun's Avatar
k0bun
'06 Quicksliver Z06 I agree with everything you said. If you add up all my posts in this thread they equal about what you said in yours.
my 2 Cents
Well everyone's budget is different so it's not fair to say they shouldn't be modding, etc.
And comparing BMW M series mods isn't an accurate comparison either. They are a foreign high-end automaker. Of course their prices will be high. I will admit that in absolutes that price is high for what the sum of the parts actually are. But I guess that's just how it is.
True. But then this result needs further looking into then.
His H/C LS2 making much less than the ZR1 showed almost a 40rwhp loss. Remember GM isn't designing motors for maximum power output.
No they probably don't but that doesn't really matter. The LTs are showing power gains. That is what matters.
Old Feb 24, 2008 | 08:38 PM
  #59
06C6FVR's Avatar
06C6FVR
[QUOTE=C6 DVL;1564251709]my 2 Cents
QUOTE]
You know, things said like this really make it that much easier to sell these parts at higher prices than they need to be. Apparently, you have plenty of money to throw around. Must be nice. Some of us are hard working individuals that earn a good living and enjoy modding our cars on a budget. These arent 100k cars like the benz, and if they were, many of us wouldnt have them. Who are you to say what someone should or should not do to their car. There are plenty of high priced exterior look items that look like crap IMHO...but I keep my mouth shut about it, because to each his own.
Old Feb 24, 2008 | 08:44 PM
  #60
glennhl's Avatar
glennhl
Originally Posted by Maklar
I have no idea why you keep ignoring my posts but maybe the third time is the charm? Look at the ls1tech link that was posted in the other thread. There is a dyno there.
Here is a link to it: http://www.ls1tech.com/forums/attach...6&d=1199325097
Take a look at the stock pull. The computer is pulling timing (car was probably hot) at 4200 to 4300. If you get rid of the dip, the difference is a lot less.
