what stall speed should i get!!!
Old Feb 24, 2008 | 07:43 PM
tcrcuda5's Avatar
tcrcuda5
Default what stall speed should i get!!!
i have a 05 w/an a4 and 3:90 gears n it. wondering on what aftermarket stall to get and which 1 u guys like best. thanx
Old Feb 24, 2008 | 07:57 PM
UNKNOWN's Avatar
UNKNOWN
Banned Scam/Spammer
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
tcrcuda
please post a review about the 390 in the a4 in the meanwhile
where are your dead zones and drone if any?
ty
Old Feb 24, 2008 | 08:09 PM
tcrcuda5's Avatar
tcrcuda5
pm sent!!
Old Feb 24, 2008 | 08:29 PM
SoldSyclone's Avatar
SoldSyclone
Depends on your mods, tires and goals, what does it 60' now?
Old Feb 24, 2008 | 08:31 PM
tcrcuda5's Avatar
tcrcuda5
mods r 1 7/8 kooks with x pipe and 3" bullets and vararam with the 3:90 gears tires r 345's n rear
Old Feb 24, 2008 | 08:33 PM
tcrcuda5's Avatar
tcrcuda5
it dyno tuned and ended up with 416 rwhp/ 408 rwt
Old Feb 24, 2008 | 08:38 PM
RWSjr's Avatar
RWSjr
A4 w 3.90's oughta pull hard. I got a 3000 stall w 3.15's and took away the dead area after shift. Low speed/cruising won't be the same.
Old Feb 24, 2008 | 08:40 PM
tcrcuda5's Avatar
tcrcuda5
it pulls pretty hard. i havent tested it at the track but i want 2. just curious what stall will complement my gears best?
Old Feb 24, 2008 | 08:42 PM
RWSjr's Avatar
RWSjr
How'd you do that? Big #'s for so little mods
Old Feb 24, 2008 | 08:44 PM
tcrcuda5's Avatar
tcrcuda5
the tuner i have is very good. he uses hp tuners. he has tuned my other vette 01 and got 824 rwhp/ 765 rwt
Old Feb 24, 2008 | 08:47 PM
RWSjr's Avatar
RWSjr
Wow. I doubt i have any more than you got with all my Mods...i wish i knew the secret in tuning.
Old Feb 24, 2008 | 08:48 PM
tcrcuda5's Avatar
tcrcuda5
i read ur sig and with the same mods ive seen 500 rwhp
Old Feb 24, 2008 | 08:53 PM
RWSjr's Avatar
RWSjr
with the G5X-3 cam i made 441/404 at LG Motorsports. I don't make as much now, TQ conv makes it feel faster(and is on launch etc) but overall i've lost top end and pk #'s.
Old Feb 24, 2008 | 09:00 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
I don't care how good he is 400+rwhp/tq from a geared A4 LS2 is not happening with just headers, intake, and mufflers. I have no doubt your car runs strong and is fast but you are not making 400+rwhp with those mods, sorry.
Old Feb 24, 2008 | 09:15 PM
tcrcuda5's Avatar
tcrcuda5
thats fine and all but that is what it said. it was done on a dynojet. so i guess there is always a bit diff #'s from dyno to dyno.
Old Feb 24, 2008 | 09:24 PM
k0bun's Avatar
k0bun
There's not a 50rwhp/tq difference from dyno to dyno though. Perhaps the numbers weren't corrected?
Either way that wasn't the point of your thread and I apologize for taking it briefly of topic.
I'm not sure as to what stall you should go with. You might want to speak with dennis50nj. He has done some remarkable things with his A4 LS2. He can probably suggest a proper stall for your intended goals. Good luck.
Old Feb 24, 2008 | 09:46 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Mine's a 2400 percision 3 dics.
I'll let You'all know how I like it!!
To what stall speed should i get!!!
Old Feb 24, 2008 | 10:09 PM
tcrcuda5's Avatar
tcrcuda5
wont mine be diff stall rpm bcz of the gearing?
Old Feb 24, 2008 | 10:27 PM
TLewis4095's Avatar
TLewis4095
Yes, what cam grind, what gear ratio, what tires, spray, no spray. What are you using the car for....street? strip? road course? Every TC should be designed for your specific application. Call a shop that specializes in that use to get some good advice. I'm strong on drag applications, but not an expert on road course. There are several shops on here that campaign road course cars that would be the ones to ask on that. Different shops have different specialties even though we all "do it all", some just have that special area of performance where someone there excels like in medicine (brain surgeon doesn't do the best knee replacement, but all are good doctors).
Old Feb 24, 2008 | 10:41 PM
tcrcuda5's Avatar
tcrcuda5
it would be street/strip combo for drag racing.
