TORQUE Lug Nuts ?
Old Mar 1, 2008 | 03:44 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Default TORQUE Lug Nuts ?
What is the specified pounds of torque to apply to lug nuts ?
Old Mar 1, 2008 | 03:45 PM
07MontRedcp's Avatar
07MontRedcp
100 ft/lbs
BJK
Old Mar 2, 2008 | 11:14 AM
Red Rochester
Originally Posted by 07MontRedcp
100 ft/lbs
BJK
Old Mar 2, 2008 | 01:52 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
140 N-m (100 lb ft).
Old Mar 2, 2008 | 02:02 PM
Larry R's Avatar
Larry R
100 ft-lbs. It is in the owners manual, but not too easy to find. It is not a bad idea to check them periodically.
Old Mar 3, 2008 | 09:53 AM
CMY SIX's Avatar
CMY SIX
tight
Old Mar 3, 2008 | 06:42 PM
Red Rochester
Originally Posted by CMY SIX
tight
How tight is it??
Old Mar 3, 2008 | 10:25 PM
Charley Hoyt's Avatar
Charley Hoyt
Make sure you you do a dry torque...if you torque it wet you will damage the threads (believe it or not).
Old Mar 4, 2008 | 01:22 AM
peterpeter211's Avatar
peterpeter211
It is very important to correctly torgue them. Dont take lessons on how to use the torque wrench from the guerilla at the tire shop. The most important reason to torque them is because the rotors by disapating the heat into the atmosphere and through the rims. If you have one nut at 90, and the other at 100, the heat will pass to the rim more efficiently at the point with 100 ft/lbs, then the 90, causing the rotors to warp.
Old Mar 4, 2008 | 01:35 AM
GreggO909's Avatar
GreggO909
Dose any one know the size of the socket for the rear nuts?
Old Mar 4, 2008 | 04:47 PM
sux2bme's Avatar
sux2bme
3/4 or 19mm??? i think
Old Mar 4, 2008 | 06:19 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
The size is 19mm, I'm told by a very good source, which is very close to 3/4".
However, in taking my lug nut to Sears, both the Craftsman 3/4" and 19mm fit the same (or seemingly so). I chose the 3/4" because it has 6 points vs. 12 for the 19mm.
To TORQUE Lug Nuts ?
