Cam question
Old Mar 3, 2008 | 09:14 PM
NO1Z51's Avatar
NO1Z51
Default Cam question
Is there anything wrong with getting a cam and no heads? I want that extra power of the cam but I am not willing to spend all the money for those heads out there...so is it stupid to put just a cam in my C6. I have kooks headers with corsa sports...just looking for that sound and performance of a cam.
Also, how much would a cam with installation cost? And for a daily driver, and 24,000 miles at the moment, averaging about 10, 000 miles a year, what kind of a cam would I be looking for?
Thanks!
Old Mar 3, 2008 | 09:42 PM
ProgGod's Avatar
ProgGod
Thanks!
Cam should be ok without heads. However you may want to replace your springs and valves. Defintely make sure you get a tune
Old Mar 3, 2008 | 09:50 PM
SSPerformance's Avatar
SSPerformance
it depends on the duration and lift if you have to change springs....if its only 5-10 degrees in duration more and 10 thousandths lift more then it should be fine.....just will need a readjustment of your valve lash and a tune..
Old Mar 3, 2008 | 11:08 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
http://youtube.com/watch?v=IQUqxclQoGY
This is mine, with the same mods (at the time) Yours should sound similar. no issues whatsoever and no heads.
Old Mar 3, 2008 | 11:36 PM
08 silver vette's Avatar
08 silver vette
What cam do you have NavyC4s? That thing sounds WICKED!! Give me some specs. Did you have to do springs? Kinda new to the game. thanks
Old Mar 3, 2008 | 11:45 PM
NO1Z51's Avatar
NO1Z51
And how much did you spend for everything...(cam, accessories, installation)?
And did it void your GM warranty. I have all bolt-ons at the moment and I have full warranty...im pretty sure I would have to sacrifice my warranty for a cam. correct?
Old Mar 3, 2008 | 11:47 PM
NEV3R L8's Avatar
NEV3R L8
I checked but couldn't find a website for Race Proven Motorsports
Old Mar 4, 2008 | 12:27 AM
ProgGod's Avatar
ProgGod
It will void your engine warranty for sure. May also void your transmission, drivetrain warranty as well. Since they could always claim that caused the damage. if a window motor fails you should be good though
Basically if your mods could have caused the damage to something, legally they don't have to cover it. However if it could not have caused the damage, they must still cover the warranty item.
Old Mar 4, 2008 | 01:45 AM
jogar80's Avatar
jogar80
Yes you can install a cam without doing heads, unless its a really wild cam. Yes you do HAVE TO change out your springs with whichever cam you choose. Depending on your area, you can do a cam swap for maybe 1500-1800 with parts and labor.
Old Mar 4, 2008 | 09:46 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Valve springs are the weak link. Up grade the CAM, and you should do springs to be safe. COMPCAM’s Beehive Springs are better than OEM but not quite up to par. Run an upgraded CAM with OEM Springs and you’ll float the valves. Get HD Dual Springs & Retainers.
Cam’s retail for about $350-400. Install ? Plus $500 or so for springs & retainers.
The dilemma you face is that for an extra $1500 in parts (P&P Heads), you’ll see 20-40 more RWHP over the CAM only install.
Can you do it w/o heads? Absolutely. But it is not wise from a $ to HP point of view. No more labor just $1500 for heads.
Old Mar 11, 2008 | 01:00 AM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
We are now a sponsor.... www.RaceProvenMotorsports.net
Old Mar 11, 2008 | 06:09 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Here is my cam only write up with lots of info and video if you are interested.
http://forums.corvetteforum.com/show....php?t=1769681
To Cam question
