corsa x-pipe.
Old Mar 4, 2008 | 01:08 PM
greg k.'s Avatar
greg k.
Default corsa x-pipe.
Hey guys.I have the corsa exhaust but currently have the stock h pipe still.I want to purchase the corsa x-pipe,and was just curious what benefit the x-pipe will have...Will it make the exhaust tone louder,for example...thanks
greg
Old Mar 4, 2008 | 03:20 PM
w.f.tracy's Avatar
w.f.tracy
Smooths out the sound and reduces popping on the overrun.
Old Mar 4, 2008 | 07:04 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
The X-pipe will soften the "popping" on deceleration. If you do decide to make the change, consider adding an aftermarket tunnel plate (Elite Engineering) which will be easy to install once you have the H-pipe out. My experience in my '05 Vert is that the plate made a noticible difference in chassis stiffness & with the heat reflective coating, reduced heat coming up thru the tunnel into the passenger compartment.
Old Mar 4, 2008 | 09:28 PM
MARSC6's Avatar
MARSC6
When you decide to get headers a lot of the kits include a x-pipe.
Old Mar 5, 2008 | 12:21 AM
c6 batmobile's Avatar
c6 batmobile
the x pipe will also have a tendency to give you a little more exotic sound.
Old Mar 5, 2008 | 01:10 AM
peurifoy's Avatar
peurifoy
Added the Elite Engineering tunnel plate + Corsa X-Pipe to my Extremes. Really toned down the "popping" on deceleration. No "Carb Legal" long tubes in the Wonderful State Of California so I did not add these which come with most of the models I looked at.
Enjoy!
To corsa x-pipe.
