Thinking about upgrading clutch...suggestions?
Old Mar 13, 2008 | 10:31 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Originally Posted by Bludog
Does anyone know how much horsepower a Z06 clutch can handle?
Lots of guys here with 500 rear wheel without issue.
Old Mar 13, 2008 | 10:58 PM
Jimmyz28's Avatar
Jimmyz28
FWIW, my 2000 Camaro SS has a 383 storker LS6 in it w/490+rwhp. I've had a Cartek, Excedy single and now an LS7 with Fidanza LW FW in it.
The LS7 is by FAR the best daily driver clutch w/o question IMHO.
Done several 1.7 60ft. (i suck @ drag racing) launches with it at the track on Nitto DR's and then driven it home. I highly suggest this setup for a mainly DD car.
Old Mar 21, 2008 | 12:30 AM
GasTiresandOil's Avatar
GasTiresandOil
I had a Cartek in my GTO that I just took out after 18K and 18month of abuse. I drag raced it, road raced it, autoxed, and street drove it. 1.5 60's with ~650rwtq, lasted well over 200 passes. Little bit of chatter but well worth the holding power.
Old May 6, 2008 | 05:10 PM
yellowc6ohio's Avatar
yellowc6ohio
does anyone know anything about the LS9 clutch, would it work in an LS2 since it's a twin-plate 260mm clutch instead of the Z06 290mm single plate? has anyone tried it?
Old May 6, 2008 | 05:48 PM
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by JLINDSEY2
I have a RPS clutch-and LOVE it!
I'm happy with mine.
Old May 6, 2008 | 08:38 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Originally Posted by C6400hp
Looks like I will end up going the LS7 route.
However, I wonder what the specs on the ZR-1 clutch is (ANYONE?). I have 420rwhp and 400rwtq with 4.10's. Love the stock clutch and hasn't failed yet at 26+ k..
I am also interested in this thread. I would really like to know the specs on the ZR-1, clutch peddle feel ETC..
Old May 6, 2008 | 08:40 PM
welcome2try
St. Jude Donor '08
Awesome clutch is what u suggesting?
Old May 6, 2008 | 08:45 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Originally Posted by schilitj
I have the RPS stage 4+ clutch and flywheel in my SC C6 = 586rwhp/506rwtq. Have launch the car on the track with DRs at 5000+rpms
Another happy RPS customer. I use the RPS clutch in my C5 and its great for both the street and track - very reliable and holds plenty of torque.
Old May 6, 2008 | 09:50 PM
OCCOMSRAZOR's Avatar
OCCOMSRAZOR
FWIW, I just went through this process for my dedicated track car.
Unless there is a specific problem that you are trying to solve because of an extremely high horsepower motor, the decision I came to was to go with the LS7 clutch with a Findanza aluminum flywheel.
It may not be the most "heavy duty" or exotic combination out there, but it is a tried and true combo, good for 500 rwhp, at a reasonable cost.
Old May 6, 2008 | 10:20 PM
Jorday's Avatar
Jorday
I've pulled some 1.65 60' times with my LS7 clutch with nearly 500 rwhp. I wouldn't recommend it on a daily basis, but it is capable of it.
The LS7 clutch is a good option unless you are well above 500 rwhp or the car is going to see a lot of racing...high rpm launches in particular.
Old May 7, 2008 | 08:54 AM
Jimmyz28's Avatar
Jimmyz28
I read somewhere is will not work. Anyone?
Old May 19, 2008 | 04:11 PM
YardDog's Avatar
YardDog
Based on what I have read here, I'm leaning toward the Fidanza/LS7 clutch combo as a replacement in my C5 Z06. If I go that route, which throwout bearing should I use the LS6 or the LS7, or are they the same?
Old May 19, 2008 | 04:58 PM
  #33
C6400hp's Avatar
C6400hp
to early to know.
Old May 19, 2008 | 05:31 PM
  #34
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
has anyone just upgraded to the aluminum flywheel? notice a rougher idle? harder to "slip clutch"? do you like it?
what would someone need to upgrade a stock ls2 to the Findanza aluminum flywheel and the c6 z06 clutch disk? just those parts? pilot bearing? throwout bearing? slave cylinder? new shift fork? special tools?
