How Much HP??
Old Mar 9, 2008 | 05:39 PM
C6Antwon's Avatar
C6Antwon
Default How Much HP??
Can a stock 2005 C6 clutch hold without slipping?
Thanks for your help!
Old Mar 9, 2008 | 10:01 PM
kaislick's Avatar
kaislick
i'm somewhere between 440 and 450 rwhp and it definately didn't handle even two passes at the drag strip on stock run craps.
Old Mar 9, 2008 | 10:21 PM
BAADC6's Avatar
BAADC6
I had 33K on mystock clutch......16K was with 463 rwhp. It seemed to work well. I only upgraded when I put on a supercharger and hit 604rwhp.
Old Mar 10, 2008 | 12:45 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Depends on what you do with it...I'm a hair under 500 RWHP with my built, naturally aspirated Lingengelter 403 motor. I like running road courses instead of drag racing. I run the snot out of it but I don't really load-up and drop it right off the line...pretty close some times but not an all out drag race launch.
My stock clutch works fine.
Tires will make a huge difference as well. Tire spin will help save your car...especially your differential. Put on DR's and really get some bite and you greatly increase the odds of breaking something.
For what I do my stock clutch has held up well. If I was a drag racer I'm not so sure it would.
Old Mar 10, 2008 | 11:43 AM
andreas g.'s Avatar
andreas g.
Held 461rwhp/435rwtq just fine no issues.
Old Mar 10, 2008 | 11:56 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
471/415 I went with a HD Clutch just for peace of mind and blew a rear.
To How Much HP??
